Old 11-22-2022, 05:34 PM   #1
riz
C10 crossmember question
I have an 81 C10 short box pickup that I will be putting an LQ4 6.0 LS and 4L80 trans. into... will the stock trans crossmember work or will I need a different crossmember?
IF I need a different one, what crossmember should I buy?
RIZ
RIZ
81 C10 short box
82 K5 Blazer
riz is offline   Reply With Quote
Old 11-23-2022, 08:58 PM   #2
riz
Re: C10 crossmember question
nobody ????
RIZ
81 C10 short box
82 K5 Blazer
Old 11-24-2022, 06:20 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Go follow this guy on YouTube.
He has several videos on LS swapping a squarebody truck.
https://youtu.be/3BRI84MXS90
You can also ask your questions in the LS section,…
https://67-72chevytrucks.com/vboard/...play.php?f=206
Keith
Convert to disc brakes.
Old 11-24-2022, 01:18 PM   #4
Ziegelsteinfaust
You can slide the cross member back, and redrill holes.
I bought one of the adjustable versions with the double hump that I am disappointed in, and will just fab up something nicer when I get around to it.
Ziegelsteinfaust is offline   Reply With Quote
Old 11-24-2022, 07:01 PM   #5
Warrens69GMC
Warrens69GMC's Avatar
Some of these trucks have a crossmember that drops on the driver side and some are the "butterfly models.
driver drop
https://www.ebay.com/itm/22523006938...xoCPC0QAvD_BwE
butterfly style
https://www.ebay.com/itm/37424242574...Bk9SR_6C6L2VYQ
get one for your year of truck
might want to consider one of these
https://www.ebay.com/itm/37432045390...Bk9SR7L9gb6VYQ
Old 11-24-2022, 07:45 PM   #6
riz
thank you......... i will use the ls section from now on.
RIZ
81 C10 short box
82 K5 Blazer
Old 11-30-2022, 10:53 AM   #7
Hart_Rod
Hart_Rod's Avatar
Who's bracket if you don't mind me asking?
Hart_Rod is offline   Reply With Quote
Old 11-30-2022, 12:13 PM   #8
SCOTI
SCOTI's Avatar
Some questions can be answered in either section. No harm or foul utilizing a different section of the site if the question asked goes unanswered or not answered within your time constraints.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-30-2022, 02:47 PM   #9
Hart_Rod
Hart_Rod's Avatar
RIZ
It really depends on the LS conversion motor mounts use, as they all seem to have a different engine placement. Fortunately, if you have to modify or build something, the transmission mount is the easiest to build/modify. I'm getting ready to do an L86/8L90 swap in my 84 and am currently researching a complete motor/transmission mount kits. I used the Dirty Dingo setup in the 93 that I'm doing right now and it worked great. However, I haven't been able to get them to return my emails to see if their setup works as well in the Squarebodys. Will report back once I figure it out.
Rob
Old 11-30-2022, 09:28 PM   #10
1957 Chief
Proud Vet that loves the USA
Rob
Jamey @Metaltek for mounts.
Will send you a text.
Bubba
1957 Chief is offline   Reply With Quote
Old 12-01-2022, 02:40 PM   #11
Hart_Rod
Hart_Rod's Avatar
Bubba
Does he make them for 8L90s?
Old 12-16-2022, 02:32 PM   #12
PunishedC10
Not sure if you found the answer you are looking for but I have an ‘85 with an ls1/4l80e. I hated the factory cross member. Some of the bolts are under the body/on top of the frame, it’s odd shaped for the one exhaust pipe to clear….
I used one from TejasSteelWorks or something like that. I believe I have an old build thread on here that will have pictures
1964 Coupe Deville(cruiser)
1966 Chevy II Nova 2door Hardtop
1985 C10 LS1/4l80e, Ridetech coilovers,22”Coys
2019 F-250 Platinum-Deleted/Carli Supension 37” MT’s
2000 Trans Am WS6, LS1/T-56, too many mods to list
PunishedC10 is offline   Reply With Quote
Old 12-18-2022, 01:50 PM   #13
Ziegelsteinfaust
Summit racing I believe
It's one of the double hump fabricated ones they sell
