Anybody using a 6l80 in their swap?
I want to keep the column shifter for the normal PRNDM/S. Is there a way to hook up something like a rocker switch or even a small hidden shifter when I want to manually shift the transmission in M/S mode?
Re: Anybody using a 6l80 in their swap?
The only thing I have seen aftermarket was a floor shifter with the tap shift feature.
Or people have fabbed in late model steering wheel assemblies to get the column shifter, and tap shift. |
You might want to check over on LS1tech. Lots of different swaps detailed over there.
This should work for what you want to do. https://www.speartech.com/product_p/tssb.htm
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#6 | |
I did find a couple others though, so I think I am good. Thanks! |
Mind sharing what you have found - I'm using a 6L80e as well just havent gotten that far... hahah
What did you do for your linkage? thanks
1972 K5 Build - plans - LS3-6L80e-One Tons..... 1971 CREWMAX Build.....at body shop for couple more years ![]() |
I was probably going to use the Lokar kit, but I haven't gotten that far either. I need to get a new column first, then I can go from there.
I always thought it would be cool to have a rocker switch on the console assuming a guy has buckets.
![]() Join Date: Dec 1999
PSI sells a wireless paddle shifter setup that gets power from the horn wire in the wheel. In my conversations with them they told me it works with the e67 ecm I am using (my engine harness is from PSI). Thinking about giving it a try for the 6L90 in my truck. Looks like for aftermarket wheels only. With a stock steering wheel would require a lot of modification, if it is even possible.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
You would think that you would just have to find the three wires in the harness and run them to a rocker switch. Do you have a pin readout for the E93?
The wires for the tap up/tap down go to the BCM, so not as easy as hooking them up to the ECM.
It looks like Swaptimeusa has a kit that will work and uses a rocker switch. Supposedly, you don't even need to reprogram the transmission, although that is probably not a bad idea if you are doing any modifications. Their set-up works with any ECM. Most of them seem to work with the E38.
I have some time on this yet, but it looks definitely doable! |
I'm running a PSI harness on my LS3 conversion as well, might reach out to PSI and see how much to add this harness on? Mine is a 58X harness if that makes a difference.
#15 |
I have the swaptime module, let you know how it goes.
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
#16 |
#17 |
Any update on this ?
thanks
#18 |
I am installing it this winter, so I will know if the unit works in the spring. The one from Swaptime is no longer available. He claims he could not get the chip needed to build the units any longer. Is there a chip inside?
There are a few other companies that make the unit. I am trying one of those. |
#19 |
Ended up purchasing the paddle shifter from PSI https://www.psiconversion.com/produc.../TAP-1000.html The paddle module is installed at steering wheel but I still have a lot to do. Have spoke to them a couple of times and the engineer there insists it will work in my application. Connects to trans by only one wire and requires changes to ECM. Hope to check out operation in a month or two.
#20 |
Following along.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#21 | |
I have no idea if it is accurate, but it does make sense. Good luck! |
#22 |
BMW & ASE Master Certified
Im not done with the swap, but HPtuners reads tap up and tap down correctly when in scanning mode. I usedthe Corvette wiring diagram, 3 resistors per that diagram and wired just like the diagram.
If you don't run the BCM, you have to change the settings in the tune for this to work. https://www.youtube.com/watch?v=34u5nH06x6Y hptuners link in site requires forum access, if you dont have it, uploaded it to my site since there is a limit on upload to here http://87chevy.com/share/6speed%20Ta...uck%20Tune.doc clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
#23 | |
#24 | |
@joyridin Should be able to avoid any complete reflashing. The main reason I got the engine, trans and ecm all from the same ZL1 Camaro. The TCM located in the 6L trans needs to be flashed if not matched to the ecm.
#25 | |
