![]() Join Date: Mar 2015
Are 4 wheel drive and 2 wheel drive hot air stoves different?
I know the manifolds are but did they change the stoves also? What is the threaded hole in the top middle of the stove for? Seems only some of some of them have it? |
Re: Are 4 wheel drive and 2 wheel drive hot air stoves different?
I don't have ananswer to your question but do have what I think is an original air cleaner from a 72 c20 2wd in reasonably good condition. I do not need it and you are welcome to it if you need it
![]() Join Date: Aug 2014
Yes they are different
2 wheel drives are made for the curved ram horns and 4x4 are made straight Not sure what you mean about threaded top There is a sheet metal screw that holds the stove pipe in place on the top of the shield
Az |
