Old 12-30-2022, 10:04 PM   #1
jumpsoffrock
Do all SM465 have the exact same trans-to-bellhousing bolt pattern?
Locdoc saved himself from buying an adapter for his NV4500 swap by drilling holes in his NV4500 case using the original SM465 bellhousing as a "template"
http://67-72chevytrucks.com/vboard/s...d.php?t=673588
Do all SM465 bellhousings have the same trans-to-bellhousing bolt pattern?
I have a source on a bellhousing that mated a 350 to an SM465, and I might could use it, rather than having to tear my current trans out first and use it to drill the holes.
Thanks everyone.
jumpsoffrock is offline   Reply With Quote
Old 12-30-2022, 10:59 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Do all SM465 have the exact same trans-to-bellhousing bolt pattern?
Thanks everyone.
Yes, all small block Chevy SM465 manual bell housings have the same bolt pattern.
LockDoc
Leon
Old 12-31-2022, 12:34 AM   #3
KQQL IT
At the body shop.
KQQL IT's Avatar
Depending on your location in California.
I have a loose one you could have for mockup
Central CA here
Old 12-31-2022, 01:15 AM   #4
LockDoc
LockDoc's Avatar
Central CA here
The only thing you have to watch out for is that there are two sizes for the front bearing retainer hole. The small (4-11/16") diameter and the 5-1/8" diameter (needed for the NV4500 transmission). It would need to be a bell housing from a truck with the SM465 manual transmission. (1968 up)
LockDoc
Leon
Old 12-31-2022, 01:30 AM   #5
jumpsoffrock
Central CA here
Thanks man I'm close actually, however I already have one sourced for now, I appreciate the help.
LockDoc
Actually it's specifics like this that help the most, thats good to know the difference. Which applications used the smaller diameter?
Old 12-31-2022, 01:45 AM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
It's here on a shelf
I could measure it in the morning.
Mid seventies 454 tho
Old 12-31-2022, 02:36 AM   #7
jumpsoffrock
That'd be nice, thank you.
Didn't you used to drive a Yellow big Rig? You'd take pics of your travels sometimes and post them.
Old 12-31-2022, 02:42 AM   #8
KQQL IT
At the body shop.
KQQL IT's Avatar
Yep, still do.
Keeps me interested in truckin
Old 12-31-2022, 03:49 PM   #9
LockDoc
LockDoc's Avatar
Actually it's specifics like this that help the most, that's good to know the difference. Which applications used the smaller diameter?
The SM420, and possibly the three speed manual transmissions, but I don't know that much about the 3 speeds.
LockDoc
Leon
Old 12-31-2022, 03:51 PM   #10
KQQL IT
At the body shop.
KQQL IT's Avatar
Yours for the taking
Old 01-01-2023, 01:14 AM   #11
jumpsoffrock
LockDoc
Hey one last thing, I am using a big block in my truck, do they also use the same bolt pattern from bellhousing to trans?
Old 01-01-2023, 06:57 PM   #12
LockDoc
LockDoc's Avatar
Yes.
LockDoc
Leon
Old 04-02-2023, 08:08 PM   #13
KQQL IT
At the body shop.
KQQL IT's Avatar
Good to meet you this afternoon.
Hope the parts work out for you.
Old 04-02-2023, 09:45 PM   #14
jumpsoffrock
Good stories man! You son is really impressive for his age. I'll let you know whenever I get the NV4500, hopefully in a couple weeks. They guy made it sound like he has a few lying around, and that I could see them all and pick my favorite. We'll see how many he has in a couple weeks. Thank you for everything.
Here's a pick of my daily, hope I don't get banned for this.
Old 04-02-2023, 11:46 PM   #15
KQQL IT
At the body shop.
KQQL IT's Avatar
Thanks, we really have a good time fixing this old stuff.
Good luck with the 4500 project
Old 04-03-2023, 08:58 AM   #16
MJN
MJN's Avatar
One thing to keep in mind is the bottom two bolts that hold the bellhousing to the main case. Starting in '73 when they went to the cast aluminum bellhousing all four bolts thread into the bellhousing, prior to that the bottom two bolts went from the inside of the bellhousing and threaded into the main case.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 04-03-2023, 09:35 AM   #17
LockDoc
LockDoc's Avatar
That is correct. You can still use the later bell housings but to install the NV4500 like I did you have to drill out any hole that is threaded.
LockDoc
Leon
Old 04-03-2023, 09:37 AM   #18
HO455
HO455's Avatar
You might, there's not a lot of love for yellow trucks around here.
RIP Bob Parks.
Old 04-03-2023, 10:55 PM   #19
jumpsoffrock
LockDoc
Thank you MJN and Leon, I was actually a little worried because my bellhousing on the truck is cast iron and this one is aluminum and I was afraid it wasn't the same.
Thanks for the info; I'm a little surprised that such a heavy trans was hung from an aluminum bell...
haha. Well looking at your fleet, you seem like a fairly diverse car lover lol
Old 04-04-2023, 03:53 PM   #20
HO455
HO455's Avatar
My 52 F-2 is painted 73 Corvette yellow.
RIP Bob Parks.
