11-25-2022, 10:28 AM | #76 |
Re: My new Beater 1959 GMC
That s-10 axle is too narrow for your truck . It will require tubs and reverse rims along with relocation of the springs .
A nova rear axle would work without much work .
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
11-26-2022, 01:50 PM | #77 |
love the transformation! i prefer the 55-7 front end too!
11-29-2022, 02:18 PM | #78 |
Progress.
Posted via Mobile Device |
11-29-2022, 02:26 PM | #79 |
Rear axle is a 3:42 rear ratio out of a 6 cyl s-10.
I LOVE BURNOUTS:metal NO BOZO's |
11-29-2022, 02:28 PM | #80 |
Front end progress on the 59. These era trucks are real neat to play with, very simple how they all bolt together. 👍🏻👍🏻
12-04-2022, 11:21 PM | #81 |
Out of the box mustang 2 mock up dropped spindles and 5/8 narrowed A arms.
12-04-2022, 11:23 PM | #82 |
Tweaking it some, 2” additional lower and an additional 1/2 “ pushed front wheels forward…Me Likey!!!!!!!!! Time to make it permanent.
12-05-2022, 12:34 AM | #83 |
Nicely centered wheel. Check all the angles, tack, recheck before welding in. Digital level is really handy.
Antidive angle on top control arm pivot Lower control arm angles from front and side at ride height. What I do is extend the pivot shaft out through the front and place long level or straight edge between them, then digital torpedo level on top of that to ensure side to side on crossmember is level. Then torpedo level on one shaft at a time to get the fore to aft level. Then level the lower cross member side to side. Then check the upper control arm for side to side angle.a slight angle down to frame may be ok, up to you.it affects tire lean as suspension cycles. So tire doesnt hit fender. Anyway, it looks like you researched before starting. Keep posting up pics as you go. Maybe get some of us slackers off the couch. |
12-13-2022, 09:01 AM | #84 |
stretched ftw
12-13-2022, 01:33 PM | #85 |
Those front engine mounts resemble what I had done in m '57 years ago.
12-13-2022, 08:23 PM | #86 |
what will the clearance be at the front of the rockers? hard to tell from the pics, but curious what rake angle you chose.
12-24-2022, 06:59 PM | #87 |
12-25-2022, 10:21 PM | #88 |
last post was a blank screen.
12-26-2022, 03:36 AM | #89 |
Progress pics. Mock up motor and trans in finalizing location.
12-26-2022, 03:44 AM | #90 |
Can’t wait to do burnouts.
01-04-2023, 12:39 PM | #91 |
and we can't wait to see the vids!
01-05-2023, 10:28 PM | #92 |
Stock steering column mod. I like to run the stock steering wheel.
Wheel barrow bearing and shaft collar cost me $7.41 at the hardware store. Simple easy fix. Will shape end of steering shaft for Double D coupler. Posted via Mobile Device |
01-06-2023, 03:25 PM | #93 |
It will be interesting to see how your headers fit with the IFS and tires/wheels. What kind are they? Don't think I have seen ones with that big of a bend radius in them. I like the concept if it will work!
01-06-2023, 04:42 PM | #94 |
Nice, that's a $40 problem usually.. who knew?!
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
01-07-2023, 06:31 AM | #95 | |
01-29-2023, 07:23 AM | #96 |
Progress. Just having FUN!
01-29-2023, 11:22 PM | #97 |
Oh my love the white headers!! What did you paint them with?
01-30-2023, 03:44 AM | #98 |
More FUN! Alignment is of but you get the idea.
01-30-2023, 01:43 PM | #99 |
67-72 parts collector,…
Love it.
You got that front wheel in the perfect position. I see that done wrong SO MANY times. Engine and wheel/tire choice is spot on.
02-01-2023, 10:33 AM | #100 |
curious to see how the steering shaft fits through the header tunnel.
engine and headers look awesome. where will the exhaust dump out when you're all done? |
