Has anyone ordered the Holley Blackheart Trans-crossmember
Hello,
I know there are quite a few of the Holley hooker blackheart transmission crossmember's (PN 71222024HKR-1) on back order. Anyone else ordered this unit? If so; When and have you rcvd yet? Thx
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations |
![]() Join Date: Mar 2015
Re: Has anyone ordered the Holley Blackheart Trans-crossmember
Here is an Ebay copy? Or Holley copied them?
https://www.ebay.com/itm/19373958981...Bk9SR8r_0bfBYQ It's less than half the price and has free shipping I believe it's made in Texas. I used one on my truck. Wish the bolts that retrain it to the frame were 3/8" like the factory. They were clearanced for at least 1/2". That was too big for me. I just used hardened washers and drilled the holes 3/8" any way. I did grind the welds to pretty it up. Otherwise it was fine. Only issue I had was with the exhaust tucked up that far the E-brake cable rubbed the exhaust. Cheers |
I had one of the ebay crossmembers in my '70. Didn't really care for the frame fitment or the e-brake cable interference. I sold it and picked up one from Dirty Dingo. Nice fit and the adjustable height transmission mount helps when dialing in pinion angles.
https://www.dirtydingo.com/shop/prod...oducts_id=1795 |
![]() Join Date: Aug 2004
Speedway has one now too. It might be good, other things I've purchased from them have been.
https://www.speedwaymotors.com/1967-...er,474035.html
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
![]() Join Date: Dec 1999
May70 do you need one specifically for a 4L80?
I have one and it is installed with a 4L80, I bought it very early when you had to order a separate spacer for the trans mount. The 4L80 require a 1 inch spacer. I didn't buy the Holley one, I made one from 1" aluminum bar stock. Seems like you could order any of them they have in stock(after typing this I went and looked and it looks like none are in stock....) Come to think of it I think I told you this in another thread... |
#6 | ||||
Highly likely I tend forget a lot. Now I am finishing up my seat swap project so im ready for the next thing... which is to get a cross member... Being reminded of these options I may just go with one of these. Don't want to be held up any longer. Was hoping to get a feeler out for other waiting on it.
low n' slo
![]() Join Date: Mar 2009
I went with this one for my 4l60...bolted right up no issues. I had to rig up some stuff for my e brake, but I had to tuck my exhaust up high because of the air ride, and that interfered with e brake cables. yours may not.
https://www.ebay.com/itm/26581387116...mis&media=COPY
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
I've got a G-Force Performance crossmember with a 4L80 on my muscle car. It's the s**t! I know they make them for our C10s but don't have first hand knowledge how the fitment is. You may want to check them out.
