Active Member
![]() Join Date: Jun 2015
WTB Auxiliary Fuel tank gas gauge switch
All,
Looking for an auxiliary fuel tank switch, preferably with the knob, so I can switch gas gauge from main to auxiliary. The switch that mounts on the left side of the dash. Thanks, Rob |
Always on the hunt...
![]() Join Date: Sep 2006
Re: WTB Auxiliary Fuel tank gas gauge switch
Hey Rob, was thinking that you're currently working on an earlier K model build but if chasing this style of 1972 NL2 auxiliary fuel tank switch and knob (only controls the fuel gauge/tank senders), then we should be able to supply/offer you the parts in OE used. Will have a look and check back in here later today. Mel
***For any return/past customers & friends*** Before sending of any funds, please wait for a confirmed total and instructions for sending as our paypal account & info has been changed as of Jan. 2022. Thanks... |
Active Member
Frank,
Yes my truck is a 1970 with a "travel tanks" brand auxiliary fuel tank. I would like to replace the toggle switch, which no longer works, with the 1972 style. Will call you today. Thanks Rob |
Hi Rob, here is what we have on hand for the earlier mentioned OE used 1972 NL2 auxiliary fuel switch and harness setup for controlling the dash fuel gauge, we had two switches and one complete wire harness with connectors and firewall grommet pulled. These are the 72 style two position switches for controlling two tank senders, one switch has a deluxe knob and the other has a standard knob, switches have been disassembled, contacts cleaned, lubed, and come tested/guaranteed. $130. shipped on the switch and harness setup w/deluxe knob or $110. shipped on the standard knob switch and harness setup. Lmk, Mel
Active Member
Mel,
Will take the deluxe knob version. Will settle up with you via Paypal tonight. Thanks Rob |
#6 | |
Active Member
Mel,
Just paid. Thanks again, Rob |
![]() Join Date: Nov 2012
I have this harness but the blue wire to the fuel tank was cut. If possible could you measure it and give me total.
Thanks Roger
Roger Koop |
Hey Rob, the 1972 NL2 auxiliary fuel switch w/deluxe control knob and wire harness setup has been shipped off (w/core support hdwr & ashtray bumper set), your combined package went out via USPS priority on Thu. 02/09 and your expected delivery day is Mon. 02/13. Thanks again for your order and repeat business, let me know if we can help with any other 67-72 parts needs. Mel
