Old 02-26-2023, 02:32 PM   #1
D-n-Tyke
Holley 302-1 vs 302-2 (again)
Looking at put my order in for my pan. However, after reading every thread I can fond on these pans I am still alittle confused on which one works best. I like that the 302-2 has a higher capacity and provides more clearance up front. But I am worried that because the sump protrude 2+ inches farther forward it might interfere with the cardle/crossmember. I am pretty positive the 302-1 will clear the cradle/crossmemeber but hear there might be clearance with the cross link. And the slightly lower capacity is not ideal.
What have you guys seen when installing these pans?
I am running the Blackheart engine mounts with their LS adapted clamshell mounts.
D-n-Tyke is online now   Reply With Quote
Old 02-28-2023, 04:00 PM   #2
Jason Banks
Jason Banks's Avatar
Re: Holley 302-1 vs 302-2 (again)
I have the Blackheart Engine mounts and trans crossmember and I'm using the 302-2, fits great. I think the 302-1 would be too close
Jason Banks is offline   Reply With Quote
Old 02-28-2023, 04:34 PM   #3
D-n-Tyke
Perfect. That was the response I was looking for. Thanks for the input.
Old 02-28-2023, 05:55 PM   #4
Jason Banks
Since I'm cheap. I actually have this oil pan:
https://www.supershops.com/products/.../parts/SS11004
Holley owns the Super Shops name and this thing looks and works identical to the 302-2
It uses the LS3 dipstick, which I found the dorman part numbers for and bought those instead, since they cost less.
When I got my pan, it shipped to me from the same address as other Holley parts I have ordered.
Old 02-28-2023, 06:00 PM   #5
Jason Banks
I was just looking at the Super Shops instructions and this is what is says about dipstick:
LS Dipstick & Tube Kit – Holley P/N 302-15
• LS Dipstick – GM P/N 12634547
• LS Tube – GM P/N 12625031
DORMAN 921045 (921-045)
DORMAN 921044 (921-044)
Old 02-28-2023, 11:25 PM   #6
D-n-Tyke
Yeah, I have a feeling all the "knock off" pand are actually made by the same manufacture just with the holley name removed from the castings.
Thanks for posting those part numbers. I have been searching for those for a bit.
Old 03-19-2023, 01:42 PM   #7
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
I started off with the 302-1 oil pan. It cleared my cross member, but hit my rack & pinion. I ended up going to the 302-2, with no problems at all.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 03-19-2023, 07:54 PM   #8
toddoky
As a former Holley Engineer until recently, I can verify that the knock-off Holley pans are not made from the same castings. Their geometric features are different in areas that make no usage difference in some applications (like the C10), and huge differences in others (GM A-body cars for example). The Supershops pan is sourced from the same factory as all the knock-off pans and Holley offers it to get their share of sales from the cheap pan market.
toddoky is offline   Reply With Quote
Old 03-20-2023, 03:00 AM   #9
D-n-Tyke
Originally Posted by toddoky View Post
As a former Holley Engineer until recently, I can verify that the knock-off Holley pans are not made from the same castings. Their geometric features are different in areas that make no usage difference in some applications (like the C10), and huge differences in others (GM A-body cars for example). The Supershops pan is sourced from the same factory as all the knock-off pans and Holley offers it to get there share of sales from the cheap pan market.
Hey Toddoky. Thanks for the clarification.
