View Poll Results: What's on your 71-72 Chevy/GMC, for stock radio
Stock AM radio, Fixed mast - Know it's original or correct replacement 16 22.54%
Stock AM radio, Fixed mast - Don't Know if original or correct replacement 11 15.49%
Stock AM radio, Telescoping mast - Know it's original or correct replacement 17 23.94%
Stock AM radio, Telescoping mast - Don't Know if original or correct replacement 8 11.27%
Stock AM/FM radio, Fixed mast - Know it's original or correct replacement 4 5.63%
Stock AM/FM radio, Fixed mast - Don't Know if original or correct replacement 5 7.04%
Stock AM/FM radio, Telescoping mast - Know it's original or correct replacement 5 7.04%
Stock AM/FM radio, Telescoping mast - Don't Know if original or correct replacement 5 7.04%
Voters: 71. You may not vote on this poll
Old 06-08-2017, 11:36 AM   #26
A1971Blazer
A1971Blazer's Avatar
Re: Poll - Your Radio Antenna for 1971-1972 Chevy
Originally Posted by Grumpy old man View Post
I'm not sure how to vote ? Is the coat hanger with duct tape retainer considered "fixed mast or adjustable" ??
How about a potato stuck onto the broken stub....?
I just put a telescoping antenna on my K/5......it's advertised as "correct" factory reproduction.....I'm really not too concerned about the "correctness" as long as it works...it fit right and looks good....
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 07-07-2017, 02:10 AM   #27
wmurdock72
wmurdock72's Avatar
Can someone post pics of the routing of the antenna cable? Or explain?...thanks
1972 k10 396 8" suspension lift 3" body lift - build in progress
wmurdock72 is offline   Reply With Quote
Old 07-17-2017, 01:58 AM   #28
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I can only speak for 71-72. I imagine 67-72 were the same. My cable wasn't attached to the radio when I found it, but it just plugs in. First you have to pull the cowl panel. Other than that, here's what I have:
• Feed the cable into the cab hole from outside the cab. The hole is approx. 1" below the windshield. There was approximately 14" of cable outside the cab. The cab uses a grommet, inserted from the outside.
• The cable is retained by two rubber coated clips. These clip onto the ridge immediately below the glove box hole in the dash panel. Placement is approx. 1" inside each corner of the hole. The retainer portion faces the firewall and holds the cable down. The clips also retain the wire for the RH door jam.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 04-12-2020, 09:51 AM   #29
CS1972
CS1972's Avatar
I replaced my Retrosound Classic digital radio with a “Antique Automobile” AM-FM slide bar radio, new center speaker and also replaced the antenna with telescoping antenna as I did not like the non-factory look (digital and that it covered all the opening) and was getting tired of the mast “springing back and forth” every time I went into/out of the garage.
After searching “Antenna” I found this thread to be the closest to the subject matter / question I have.
Is the antenna I removed factory? …… see pics and information below.
Part #’s on the nut: 3943656 and 181 300
Part #’s on the base: PMG 3979307
Fixed antenna: 31” long from tip of ball to the base of nut
Ron
1972 Cheyenne Super 1/2 ton LWB 4x4 - Grapefruit Yellow / White
CS1972 is offline   Reply With Quote
Old 04-12-2020, 10:31 PM   #30
Richard2112
Richard2112's Avatar
That's what I'm planning. Would I need a 67-72 hanger?
Richard2112 is offline   Reply With Quote
Old 04-13-2020, 01:28 PM   #31
71CHEVYSHORTBED402
Looks right to me
Part #’s on the nut: 3943656 and 181 300 Correct for low crown nut
Part #’s on the base: PMG 3979307 I'll have to check, but your base looks right
Fixed antenna: 31” long from tip of ball to the base of nut Couldn’t tell you
The chrome bezel should be stamped 3898672.
The ground “bezel” on that body slips off right? It’s part number 3898673, might be stamped.
Tony
Old 02-15-2023, 01:27 PM   #32
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Bringing thread back up. Just got my original AM Radio back after having it converted to AM/FM Bluetooth etc. There is a note from the builder, see picture, saying if I have the original AM telescoping antenna on my truck, and I do, that it should be replaced with a fixed AM/FM Antenna. so its been a couple years since anyone posted in thisthis thread so wondering if anyone in that time has come across and ideally a fix mast antenna that would replave the telescoping one on my truck.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 02-15-2023, 01:59 PM   #33
Grumpy old man
Grumpy old man's Avatar
This replacement from Goodmark looks and fits exactly like the original , it also has the gromet seal and clips for the lower dash to install like an original , Best price I found was thru summit . Read the reviews on the Summit page
https://www.summitracing.com/parts/g...SABEgLwLPD_BwE
Old 02-15-2023, 03:25 PM   #34
Already Gone
Old 02-15-2023, 11:58 PM   #35
mr.mud1
mr.mud1's Avatar
my 72 Fremont built Cheyenne Super was a low miles,1 owner truck til me.it has an AM radio as per the build sheet,U63 P/Button radio and a telescoping antenna.the truck was in storage for 25 years and everything appears to be untouched.the cable to the antenna from the radio and routing don't appear to be altered or changed in anyway but i have no proof that it's original but it sure looks it.
mr.mud1 is offline   Reply With Quote
Old 02-16-2023, 04:12 AM   #36
Already Gone
Mine was a Janesville build and with the AM Radio and has the telescoping antenna like on your truck.
Old 03-15-2023, 08:25 PM   #37
71CHEVYSHORTBED402
I found my C10 AM with a high crown cap nut. I don't know where the mast came from. Word is these trucks came with high crown nuts with telescope masts, and low crown came with fixed masts. Personally I like the high crown with fixed mast, so I rebuilt the antenna as found adding a NOS fat ball fixed mast. That assembly was installed in 67 Corvettes.
Why wouldn't a fixed mast replacement install with your existing parts? Cosmetic? Unfortunately I don't have access to my truck for a pic.
Corvette replacement:
https://www.ebay.com/itm/39247236878...Bk9SR9zRovzcYQ
Truck replacement, it would seem. Perhaps it would look odd with the tall nut, hmm.
https://raybuck.com/product/1967-197...ed-whip-style/
Tony
Old 03-15-2023, 10:20 PM   #38
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Posting these instructions for fun.
Old 03-15-2023, 10:38 PM   #39
jocko
jocko's Avatar
all 71-72s I've had were factory am only radio trucks and all have had telescoping antennas (except for the occasional obvious retrofits by a PO of a horrible rubber antenna or a completely missing antenna). Unfortunately, I can't confirm any of the telescoping antennas were original, but when it comes to useful data, quantity has a quality all its own...
Old 03-16-2023, 02:05 AM   #40
Richard
My 72 truck had the original AM radio when purchased in 98. A fixed antenna with a stock looking mount on cowl and spring in the mast. While I have an in-box NOS telescoping antenna in hand. Will be installing the reproduction fixed mast with the factory AM/FM I obtained years ago.
Richard
