#51 |
![]() Join Date: Nov 2004
Re: 67-72 Bench seat lowering brackets ??
I just installed mine this past weekend. Wish I had done it months ago when I first bought them. After I redid my bench seat I was looking through the top of the windshield. I now have over FOUR inches of headroom (5'8").
As always, I still wish I could have 1 more inch of leg room, but without a thinner seat that's not possible. I have a cool set of box speakers I can't find anymore (look like these) behind the seat. They were so old the speakers blew, so I took them apart and swapped speakers out. My tank has long been out of the cab. The under seat space thing does suck a bit. All I could get under there was my jumper cable bag. I didn't realize at first you lost a couple mounting bolts as well, but once installed it feels solid and doesn't move. If you really wanted to, I guess you could order a 2nd set. And you can't see the logo when installed.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#52 |
![]() Join Date: Oct 2013
The full custom fabrication seat lowering brackets are legit. I just installed some on my 68 gmc and put together a video showing how it’s done. Hope y’all will check it out if you’re thinking of buying these brackets.
https://youtu.be/DNP0gx_E_Tw
- Robbie UNITED BY TRUCKS - classic truck video content YouTube: www.youtube.com/c/unitedbytrucks Instagram: @united_by_trucks Paw Paw '68 508 Dark Blue Custom C10 Teddy '68 GMC SWB 503 Light Green LS Build Mississippi Mud '75 Skyline Blue Patina SBC Build |
#53 |
I just dropped my bench off to get upholstered so measuring the current bracket height might be difficult. I see there are two different sizes to buy, what are the differences between the "short" and "tall"?
#54 | |
**READ THIS** These seat brackets are for lowering the stock bench seat in your 60-66/67-72 Chevy C-10 truck 2". There are two different height factory brackets, so you will need to measure the rear stand, "short" set is aprrox 5", "tall" set is approx 7"(see additional photos) so that you can order the correct set. The lower mounts are slotted to allow adjustment from all back to an 1 1/2" forward position. Install new brackets to seat using the outer holes on each side, with tabs to outside. CNC plasma cut from 12 gauge steel, quality powder coated satin black. sold as a pair.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
#55 |
Question, the lowering brackets take away the ability to adjust the seat backward or forward, or do they bolt to the slider?
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
#56 |
![]() Join Date: Nov 2018
#57 |
I just installed these brackets on my seat last week. Here are some pics. I know the brackets don't look like much, but they fit perfectly (if you order the correct version) and really do bring the seat lower by about 2.5"
Before: ![]() After: ![]()
#58 |
Ill buy a set when they use at least the front 2 mounting bolts on the floor. I can see only being able to reach the one outside on the floor on the rear, but with there being 2 bolts only on the outside, I don't see how these will prevent lateral movement in the brackets when cornering, or if in a accident.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
#59 |
![]() Join Date: Feb 2003
can anyone tell me if a high hump floor has any effect on these lowering brackets? thx in advance.
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
#60 |
#61 |
thx for reply
#62 |
Just stumbled on this thread. Has anyone installed these mounts with an amp under the seat. Didn't know if there's enough room to fit anything under there.
