No way to turn
I install one of those after market tilt column's in my 69 C10. The install went ok... Until I went to put the stock steering wheel back on. The shaft doesn't protrude enough to engage the splines before the wheel jams against the column...
![]() Join Date: Apr 2016
Re: No way to turn
I don't know how it is on aftermarket, but on my stock column I need to make sure the inner column shaft is fully out and the lower bearing is fully seated before doing final positioning and tightening down brackets that hold the out steering column in place on the firewall in the engine compartment and under the dash. It is possible when the column is loose and not yet attached to the dash and firewall to put the steering wheel on and hold it in place with the nut at least finger tight.
Re: No way to turn
I loosened the hardware in the engine compart but still not able to pull any length inward.
The Older Generation
Re: No way to turn
What happens if you just put the nut on the shaft and try to pull up on it by pulling on the nut? Can you move it any? LockDoc
Re: No way to turn
You're not trying to pull any length inward. You need to push the outer steering column toward the steering gear on the frame. That will result in the inner shaft lower bearing seating more and exposing more of the threads where the steering wheel attaches.
Re: No way to turn
Every aftermarket column that I have seen is set up for a 69/76 (maybe later than that) Car streering wheel or the adapter used to put and aftermarket wheel on one.
You would have to buy this Ididit column to have the original wheel fit. https://www.ididit.com/i-25048234-19...ft-chrome.html
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 04-28-2023 at 01:32 AM. |
