05-02-2023, 09:34 PM | #1 |
My 572 doesn’t fit!
If only I would have left it a stock 572....but nooooooo....I gotta jack around, and try to make more power....(Extended Power)
So after almost two years of ordering parts, and hitting stumbling blocks at every purchase for this thing, I finally get it hoisted into the engine bay to fit it into its final resting place. Only the engine had a completely different idea. Lowering it in, the passenger side valve cover hits the heater box, AND the fire wall....and looking at the engine mounts, it says it still has to go back another inch....NOT gonna happen. The heater box can be taken out, and go with Vintage Air afterwards, but I have no idea what engine mounts I can use that will bring the engine forward enough to clear everything. The reason it’s too big: Sold the stock GM Performance heads, and went with AFR 335v2. So already, it’s a tall deck, with taller heads. Then with the cam I went with, I installed a stud girdle....with which the stock 572 valve covers don’t clear... So I had to purchase a set of spacers...which equals more height/width. I could pull the girdles off, and the spacers, then change the rocker arm nuts to shorter ones, and redo the valve lash....again. (Mechanical roller) I don’t really want to do this, as I want the added strength and reliability from the girdles. Who else has fought with fitting a tall deck BBC into these trucks? I’m ready to sell this damn thing already.
"If it ain't broken, fix it 'till it is!" Last edited by Extended Power; 05-03-2023 at 12:54 AM. Reason: Adding pictures |
05-02-2023, 11:21 PM | #2 |
Re: My 572 doesn’t fit!
If the paint on your firewall isn't perfect, a well placed smack with a hammer will get the clearance you need. Another option is to cut and weld an opening.
If that won't work for you, could you fab up some new mounts?
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
05-03-2023, 07:10 AM | #3 |
Really cool engine!! Don’t give up
71 C10 72 K20 72 K10 Super Kirk |
05-03-2023, 07:16 AM | #4 |
Get rid of those things on either side.
You don't need those. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
05-03-2023, 08:08 AM | #5 |
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
05-03-2023, 09:10 AM | #6 | |
The heater box enclosure is coming out today. The brakes...yeah, I'm going to need those.
"If it ain't broken, fix it 'till it is!" |
05-03-2023, 09:16 AM | #7 |
Almost Satisfied
First world problems LOL
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
05-03-2023, 09:37 AM | #8 |
I know you are just joking...
I’ve worked my ass off for everything I have. Nothing has ever been given to me...besides advise. We all have the same 24 hours in a day.
05-03-2023, 09:54 AM | #9 |
Could you just drill new holes and move your motor mounts forward an inch or so? I assume you’re gonna be running electric fans so you should have room. Of course this will mean the trans mount needs to be drilled too. I know when guys do a big block swap in a 4wd the motor has to be moved a few inches forward to fit best. Otherwise you could modify the firewall. Don’t give up, you’re so close! Just curious if you tried lowering it in without valve covers on? I know you probably couldn’t get them back on if you do this, but you could maybe see if the motor fits without them, give you an idea how close you are
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
05-03-2023, 10:13 AM | #10 |
At the body shop.
Isn't there a forward position for the big chevy ?
The 454 in my 68 looks way forward than yours.
" That didnt make it any newer " " Dont antique the equipment " |
05-03-2023, 10:37 AM | #11 |
What are you gonna use for headers?
05-03-2023, 11:01 AM | #12 | |
Almost Satisfied
05-03-2023, 11:05 AM | #13 | |
Are you building this thing to go, or to stop?!?
05-03-2023, 11:17 AM | #14 |
Don't give up.
Maybe try to see if you can get one of those Slider SBC/BBC LS engine conversion mounts to work for you. |
05-03-2023, 11:59 AM | #15 | ||
After I remove the heater box, I will see how much clearance it has at the back corner. Headers were custom made by Dan Lemons. He asked every question about what I had for block, heads, oil pan, shift linkage, etc. And, they will be running inside the frame, not below. I also bought a custom transmission mount for this setup.
05-03-2023, 06:03 PM | #16 |
So since I am pulling my heater housing and core out, I won’t be using the heater hoses.
Can I just plug them off at the pump and intake manifold, or should I loop it together? My water pump does not have the 90* short hose from under the thermostat, to the top of the water pump either.
05-03-2023, 06:15 PM | #17 |
I am not 100% sure for this engine. The heater hoses were a duel purpose of heater and also a bypass of the tstat so you did not get a hot spot in the heads on some applications. Make sure you verify 100% if you need the by pass or risk knock and head gasket issues.
05-03-2023, 10:01 PM | #18 |
Just tried to put the rad back in with the electric fans...no-go.
The front accessory drive setup sticks forward way further than the v-belt pulleys did. I pulled the two 16” fans off, and slid the rad in so I could measure the distance between the rad and the serpentine belt accessory drive. Came up with 3”.....and that’s BEFORE I move the engine ahead about 1/2”. I will have to switch the fans to be pushers, instead of pullers. (They are rated, at 2500 cfm each.) I knew they aren’t as efficient as pushers, but I have no choice, as I’m not gonna buy slim fans that are rated at less than half the flow rate as these, and only have 1/2” of clearance between the fans and the engine. .....this is getting tiresome.
05-03-2023, 10:03 PM | #19 | |
05-04-2023, 06:36 AM | #20 |
All part of the hot rodding game, you'll get it figured out! Jamming a tall deck rat motor with a nice serp set up is definitely going to take up more real-estate than a 396 set up from the era. You'll get it, don't rush it, take your time and just stare at it a while, sometimes that's all it takes to find the little extra.
05-05-2023, 02:29 AM | #21 | |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" Last edited by Ironangel; 05-05-2023 at 02:52 AM. |
05-05-2023, 12:00 PM | #22 | |
05-05-2023, 01:37 PM | #23 |
MY 72 K20 frame had a set of 'forward' frame holes. Trans crossmember had a few holes forward too. I think I ended up drilling one new hole up front and maybe two at the crossmember.
05-05-2023, 04:32 PM | #24 | |
Have you bolted them on while positioning the motor fore/aft to check for interference anywhere? |
05-05-2023, 08:22 PM | #25 | |
I’m gonna do that before I move it forward any...just-in-case. Man, would that ever be the icing on the cake...headers not fitting...THAT, would be the “done deal” on this little escapade.
