Old 05-12-2023, 02:15 PM   #1
briandownunda
Junior Member
new brake lines 1972 Chevy C20
Hi Folks,
I have a 1972 3/4 ton (C20) Chevy truck (Cheyenne super) with coil springs in the rear, power front discs, and would like to replace all of the brake lines. I see that there are some stainless sets at summit racing, they say they will fit my truck.
My question is, are the brake lines the same on the 1972s for the C10s and the C20s, or are they different? Does anyone on the forum have experience replacing the brake lines on a C20?
Thanks in advance!
Brian
briandownunda is offline   Reply With Quote
Old 05-12-2023, 02:31 PM   #2
PbFut
Re: new brake lines 1972 Chevy C20
I did mine last summer. The engine was out so it made the replacement very easy. If the engine is in and you don't have a lift, it's going to be a struggle but doable. You may want to look at this site as well. https://classictube.com/
I was impressed with the parts received and packaging. Todays proportioning valve is not 100% same as original. The bleeder port at the front has been replaced with an inverted flare port on every replacement unit I have seen.
PbFut is offline   Reply With Quote
Old 05-12-2023, 03:52 PM   #3
briandownunda
Junior Member
hi, is yours a C20 or a C10?
Old 05-12-2023, 04:42 PM   #4
Smitty
Smitty's Avatar
Check out inline tube! https://www.inlinetube.com
Looked it up and think that the c-10 and c-20 are the same. P/N CTB7208 11 piece steel for $155.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 05-12-2023, 04:43 PM   #5
67C10Step
67C10Step's Avatar
I used Inline Tube for my 67 C10, but they have listings for a 72 C20.
https://www.inlinetube.com/collectio...l=c20%20pickup
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 05-12-2023, 06:02 PM   #6
briandownunda
Junior Member
It looks like there is a stainless version set for $189. Is there a reason to go with the plain steel other than the lower price?
Old 05-12-2023, 06:17 PM   #7
DA71Grande
DA71Grande's Avatar
I used inline tube for my 71 c20 with coils.. everything fit fine except for the rear axels, The rear tee on the axel was located in the wrong spot for the Dana 60. not sure if there are any differences in between the Dana or Eaton axle tee locations
Doug
71 Sierra Grande C25
16 Sierra 2500HD All Terrain
23 Chevy Tahoe Z71
https://paypal.me/digdug7131?locale.x=en_US
DA71Grande is offline   Reply With Quote
Old 05-12-2023, 06:44 PM   #8
briandownunda
Junior Member
hey Doug,
How can I tell if I have the Dana or the Eaton?
Thanks,
Brian
Old 05-12-2023, 06:55 PM   #9
wrangler94
Originally Posted by briandownunda View Post
hey Doug,
Thanks,
Brian
is the diff cover round or more hexagonal shaped? if it's round it's Eaton, otherwise Dana 60
wrangler94 is offline   Reply With Quote
Old 05-17-2023, 11:53 AM   #10
briandownunda
Junior Member
looks like I have a dana, see attached
Old 05-17-2023, 04:32 PM   #11
DA71Grande
DA71Grande's Avatar
I think that would be a Eaton.. this is a Dana 60
Doug
23 Chevy Tahoe Z71
