03-06-2019, 09:15 PM | #251 |
Re: 64-66 door weatherstrip-EUREKA!!!!
Hate to be the only one to mention anything negative on this thread, they are great fitting seals, but has anybody tried cutting that unnecessary inner flap off?
05-17-2019, 11:46 AM | #252 |
i did... with a razor blade and a steady hand it came off no problem. and looks good.
1971 K5 CST Blazer 1965 Chevelle Malibu 283 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
05-17-2019, 12:09 PM | #253 |
For what its worth. I tried several different gaskets and the Honda gasket was the best fit for me. Left it in the sun for a bit and it snapped into place perfectly. I put the sharp corner in the lower front and it looks and fits great. The other gaskets made for this truck made my doors too difficult to close. The Honda rubber seemed a bit more collapsible. I did not trim the inner lip as it provides a buffer/pocket for my custom lower vent panels.
05-17-2019, 12:33 PM | #254 | |
09-10-2019, 06:24 PM | #255 |
I've been checking the new online inventory at my local Pull-a-Part salvage yard for the last 6 months, waiting for 2006-2009 Honda Civic Coupe, hoping to get a set of door weather striping.
Finally a Civic coupe came in. I shot down there, and scooped up a set of the push on door rubbers, in nice condition, for $10.00 + 60 cents tax. I'm happy about that. Last edited by kens65fb; 09-10-2019 at 06:46 PM. Reason: ..... |
09-25-2019, 09:48 AM | #256 |
subscribed.
Thank you for posting this. |
10-23-2019, 09:02 PM | #257 |
I got a better price on a gray set. The seal is still black rubber but the extended lip is Atlas Gray. Part #72355-SVA-A01ZB left and #72315-SVA-A01ZB right. Goes nice with my silver interior. Takes a firm push to close but I don't have any glass in yet so the door is pretty light.
10-24-2019, 07:33 AM | #258 |
If any of you purists do not want to fill in the short pieces at the bottom, I have had good luck with Steel Rubber Products on my 53 Chev truck, they make a kit for these trucks, their rubber is much better that the door slamming chinese stuff you get from the major resto sellers, but alas it is $90 for the pair and it needs to be glued.
1953 3100 261cu in, sm420, 3.55 torque tube, omaha orange 1964 GMC 1000 series,custom, 305E, sm420 |
10-24-2019, 08:04 AM | #259 |
Just to clarify, these seals are one piece and are the perfect length for 64-66 without needing any cutting or piece added.
10-25-2019, 08:34 PM | #260 |
06-22-2020, 01:16 PM | #261 |
Thanks for the info on the Honda door seals. It saved me from searching for it. I have spent many hours adjusting the door gaps and I believe 2 people on this job would have been much easier. I've got them real close for the first attempt. The truck has not been painted yet so I'm going to get the seals on temporarily and the striker, make any adjustments, then drill and pin the door position before removing the doors for paint.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
06-22-2020, 04:20 PM | #262 |
So, these will not fit a 63, without cutting?
1963 C20, small window, long bed 292, 4-speed |
06-22-2020, 04:39 PM | #263 |
The 60-63 opening is bigger than the 64-66 so the Honda seals come up short. I think you could buy 3 seals and cut one up to fill the gaps
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
06-25-2020, 01:22 PM | #264 |
I put them on my 63 and love them. And yes I bought three. Cut a piece for each door to fill in the gap. cut about 1/8 inch or so bigger so it squeezes together nice enough not to notice the seam.
--Life looks better through a curved windshield-- |
01-27-2022, 01:59 PM | #265 |
Ok..Digging up and old thread...so without reading 11 pages of posts...Does anyone know if these seals are still available for purchase? and if i go to the scrap yard or order...what year/model civic am i looking for? Im thinking 06-09 civic, but does it matter if a 2 door or 4?
01-27-2022, 03:03 PM | #266 | |
Posted via Mobile Device |
01-27-2022, 04:12 PM | #267 |
I went with the auto wrecker and I think it was like $4 or something on a 1/2 price day. Plenty fine for my junker and a lot better than the bought foam stuff that I threw in the trash. I don't think they made custom door seals for our trucks at that time.
01-27-2022, 05:28 PM | #268 | |
01-27-2022, 06:26 PM | #269 | |
I don't know about the Steele gaskets, but I bought the Civic Gaskets from Amazon for $44.54 each. They fit like a glove, and work perfectly |
01-27-2022, 06:34 PM | #270 | |
Right side: 72315-SVA-A01ZA --- A for Black (or B for gray) Left side: 72335-SVA-A01ZA |
11-22-2022, 09:13 PM | #271 |
Hats off to Rob Fisher (the OP) for letting the world know about this discovery.
If I may be bold enough to add my own discovery. The 2010 Honda ACCORD coupe door seals are also the correct size. I bought a pair from the local salvage yard for $16 for the set. They are the perfect size for my 1965 C10 doors . . . and . . . there is no “corner” in the 2010 Honda Accord coupe gasket. Here’s a video of what I did to install them in my 1963 cab. I hope this helps someone. https://youtu.be/61p_8To5Ygc
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
07-31-2023, 10:31 AM | #272 |
My drivers door is hard to close on my 66. Read the entire thread and decided to buy new Honda seals. I think my old (new) ones were Precision. I found no change and ended up reinstalling my old ones.
07-31-2023, 11:45 AM | #273 |
I bought used passenger-side Civic ones from the junkyard for my '61, cut off the "corner" and added an extention section under the sill plate. I did look at a lot of other seals while I was at the wreckers, but the Civic ones are quite thin, which is what makes them work.
The doors close MUCH better than with the Precision seals I had bought, but I don't like the rubber edging of the Honda seals. I'm going to try and slice off the outer inner "grip" of the Precision seals to help them lay closer to the door flange and see if that helps.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
07-31-2023, 02:20 PM | #274 | |
Couple spots that were really tight in the Precision seal I sliced the backside of the O part of the seal so it lays flatter. If that makes sense?? |
07-31-2023, 02:42 PM | #275 | |
