Old 08-03-2023, 09:05 PM   #1
72 Cheyenne K20
Alternator / Generator Date ?
I just received the NOS Generator for my 80 Jimmy and have a question about the date stamped in the housing. The part number is correct for my application but the date looks to have an extra number at the beginning. Was expecting number / letter / number, number. Not this. Any ideas?
72 Cheyenne K20 is offline   Reply With Quote
Old 08-06-2023, 10:26 AM   #2
Pontiac1976
Pontiac1976's Avatar
Re: Alternator / Generator Date ?
Am I read this wright, 95j29 would that be 1995 June or July 29 If that right then this have been renewed/ refinished. It was a factory case since casing# still on it must be the first refinish, some places sand off the casing# put on some extra ad to it or their own. Some do not but after the second or third time they come off if they still have them when sandblasting take place.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 08-10-2023, 09:16 AM   #3
MJN
MJN's Avatar
Looks like what was already posted except the month. J is for September, July would be a 'G'. year/month/day, so looks to be 1995 Sept 29.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
