08-04-2023, 01:54 AM | #1 |
Rear window rubber - small window vs large window
So I ordered a rear window rubber for my '64 small window C-10 but was given a large window rubber instead. Normally you'd send it back but I bought it about two years ago, so that's not an option. My question is: can I use the large rubber and trim it to size, or do I need to buy a small window rubber? Doesn't look like there's any corners on it, so I thought it might be ok to just trim.
If it is ok to trim it, does anyone have a good measurement of how big it should be? Appreciate your thoughts on this. |
08-04-2023, 02:57 AM | #2 |
Re: Rear window rubber - small window vs large window
Since the small window rubber is also cut to length,
you should also be able to use the large window rubber.
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 |
08-07-2023, 12:36 AM | #3 |
Good to know, thanks for the reply. Looks like I'll be cutting it up!
If anyone's got a rubber handy that they could measure that'd be helpful, otherwise I'll measure twice and cut away. |
08-07-2023, 01:39 AM | #4 |
Put the seal in the cab first, and have the "join" at the bottom. Make it so that the seal overlaps a couple inches on both ends, then stuff the "couple inches too long" seal in so the ends but firmly against each other.
I wonder if you could get two small seals out of one large seal. This was my install video:
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
08-07-2023, 03:16 AM | #5 | |
