Adjusting valve clearance on a 454 V8.
Good morning to you all.
I have a 1979 Chevrolet suburban and would like to check or properly adjust the valve clearance. I hope I am expressing myself correctly. Please excuse my bad English. The problem is that I hear a slight clacking sound on the left bench and I know it is coming from the valves. Can you please tell me what steps I need to take to get the valve clearance right? I only have found this https://brianbradburn.tripod.com/chevy454.htm I assume I have mechanic valve lifters. I read, that I need to turn the engine while adjusting. If I had a manual transmission, I would just put it in gear, lift the car to one side, and then turn the other wheel. But how do I do that with an automatic? Thanks in advance and have a nice Sunday
2 kids, 2 cars Sub2k - 5.3 ltr vortec Sub79 - 7.4 ltr big block Das Schiff ist im Hafen sicher, aber dafuer nicht gebaut. |
Re: Adjusting valve clearance on a 454 V8.
These are the tec specs of my car
Suburban 1979, 7.4 Ltr VIN: TCS269F528860 T - GMC C - Serie S - 7,4 Liter - 4BBL Carburator - 2 - 3/4 ton 6 - Suburban 9 - last digit of model year (1979) F - PlantCode (Chevrolet Flint) 528860 - Production Sequence Number CARBURATOR: 17059520 / 1449 CCP And maybe it is better to use this link https://youtu.be/5EGlb_VpTAw?si=fuzntC7Wnu-v9Z2-
![]() Join Date: Mar 2003
I always adjust them with the engine warmed up and running. Back off till clacking then slowly tighten until the noise goes away then another 1/2 turn. It can be messy but it works for me
You don’t need to adjust all the valves, just find the one that’s making the noise and fix it.
Pull the valve cover off and check all the rockers are moving the same amount. If you find one, let us know and we’ll help diagnose it. Ignore that YouTube vid. Lots of bad info there. |
Moderator
![]() Join Date: Jun 2017
Dont be surprised if you find a lifter and cam lobe has failed, especially if you use Synthetic oil in the engine.
Flat tappet cams and lifters need an oil that has ZDDP additive in the oil...(zinc) to protect the flat running surfaces. You can use an additive or buy an oil with zinc included in the mix. You need between 1200 to 2400 ppm of zinc to protect fully. ![]() ![]() ![]()
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
#6 | |
#7 | |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
![]() Join Date: Jan 2001
Both at the flange (the block side) and the donut (where it connects to the exhaust tubing).
Here's a trick that might help. Use a piece of tubing - it doesn't really matter too much what type or size) and hold it up to one ear. Move the other end of the tubing around the noisy side of the engine until you zero in on the noise. If it's a mechanical noise inside the engine, you can use a screwdriver with a long handle. Press it against your ear and touch it to the surfaces of the engine. As the noise grows louder, you're getting closer to the source.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
