09-05-2023, 12:51 PM | #1 |
headlight buzzer
Should very truck have this even if they do not have the "buzzer" option? I cannot find this and all I have resembling the buzzer is a 4 pin module plugged in on the upper left of my fuse panel.
thanks in advance Eric |
09-06-2023, 07:55 PM | #2 |
Re: headlight buzzer
Our trucks never had a buzzer for anything, as far as I know. I did swap out my module with one from a newer truck, like 88 and up. Now I do have a buzzer if the headlight are left on.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
09-07-2023, 07:11 AM | #3 |
All mine have had buzzers...cant stand em..so I pulled them
09-07-2023, 09:30 AM | #4 |
Thanks TKCR and mongocanfly for the responses
Here is what I currently have. A 4 pin module and 4 pin plug.(at top of the pic on top of the fuse bank) The module looks a lot smaller than the 7 pin module When I turn my key all the way forward ,the buzzer comes on and the seat belt light comes on in the dash. I removed the module, neither work. My truck is n 82 but there was a donor truck used by the previous owners. They did a frame off, but I'm not sure if the harness is the original. thanks |
09-07-2023, 10:41 AM | #5 |
If you go to the SEARCH button, and type in headlight buzzer, you’ll get a bunch of threads on the subject. You will probably find your answer quicker than waiting for someone to chime in.
09-07-2023, 10:49 AM | #6 |
"chime in"..LOL Pardon the pun
Actually, that's where I started and all I can find are comments referencing the newer 7 pin modules. The only pics I've found online, that match my module, are a 76-81 camaro ignition/seatbelt module |
09-08-2023, 10:28 AM | #7 |
TKCR,
One more question. You stated you added a buzzer module. Did you have the module socket assembly that i show in the first pic I posted? thanks |
09-08-2023, 06:45 PM | #8 | |
The module I used from the newer truck was a 6 pin module.
09-09-2023, 09:19 AM | #9 |
Actually, that first picture is not
Mine. I found that on the forum. I can’t find that module setup in my truck. Mine is the pic of the fuse panel and the 4 pin module. That’s why I asked because it seems on more modern vehicles, all the harnesses are the same, the factory just doesn’t hook up certain things depending on the package you order with the vehicle. I thought they may have done the same in the 80’s but I just don’t see that module panel. Maybe the PO cut it out or it was never there. It’s not clear on wiring diagrams either. |
09-09-2023, 10:07 AM | #10 |
If you use Option T63 in your search that will help.
I had a truck (or 2) that had that seatbelt buzzer and headlight buzzer stuff. Here is one link I found. Link: https://www.67-72chevytrucks.com/vbo...d.php?t=763202
09-09-2023, 10:14 AM | #11 |
Yes, I saw this thread as well. I do not have that option, but as I mentioned, I thought the panel may be under the dash without the buzzer module. If the option was added on the truck, they would just plug in the module. It would make sense not to have a variety of wiring harnesses.
09-16-2023, 08:17 AM | #12 | |
I want to say the 4 pin module is seatbelt buzzer, I've got one in my removed but save parts drawer, but I can't remember if I yanked it out of my 83truck or my 73nova. |
09-16-2023, 09:46 AM | #13 |
I guess mine never had the socket (first pic) either. I think my 4 pin is sweet belt and key on buzzer. I may just have to add the aftermarket headlight buzzer that I’ve seen others do on the forum.
Thanks for your input |
09-21-2023, 11:29 AM | #14 |
I think the direct plug and play for the buzzer started in 84. The socket was mounted to the pedal assembly just to the left of the gas pedal. I just did this to my 85 2 days ago and it worked like a charm. There are a couple threads on here showing how to wire them in relatively easily if you don't have that socket. I pick up a few extra modules. They are posted in the for sale section. There was a dealer sold plug and play option sold for the earlier trucks.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
09-21-2023, 11:37 AM | #15 |
Just so I'm clear, are you talking about wiring in the socket as shown in pic 1 or an after market? I've never seen the socket in pic 1 sold anywhere and it looks like its in the harness.
I' have seen the threads on the aftermarket buzzer. |
09-21-2023, 12:00 PM | #16 |
Yes the wiring in the first picture is factory. GM did sell a buzzer kit for the four pen plug like you have.. Was not aftermarket but a factory GM piece
09-21-2023, 12:04 PM | #17 |
Well, I would certainly buy one of your modules if I could use it.
Thaks for the info |
09-21-2023, 12:17 PM | #18 | |
my 77.
09-21-2023, 12:26 PM | #19 |
I've got the 4 pin (as per pics) but its just the key turned on, possibly the seat belt as per comments i've read. I had my interior ripped out to install sound deadening and i don't remember seeing the wire for the seatbelt. That doesn't mean it's not there. I'm installing a subwoofer under the seat soon, so I'll look for it then. I really wanted that headlight module/buzzer. I'm getting a bit absent minded ..LOL
09-21-2023, 12:33 PM | #20 | |
09-21-2023, 12:34 PM | #21 |
Ahhh, got it
