Old 10-06-2023, 08:12 PM   #1
72 Cheyenne K20
Anyone Ever Bent Their Trans Dipstick Tub
Hey Guys,
I Have an 80 Jimmy with a 350/350 & replacing the factory under spark plug exhaust manifolds to the earlier rams horn over the spark plug exhaust manifolds. I will be routing the spark plug wires to the back of the block & under the manifolds.
My only issue is getting around / over the transmission dipstick tube. Not sure if they made a different tube on earlier models to go with that setup or bending it is my only option.
Please way in if you have done something like this or have any suggestions.
Thanks Scott
72 Cheyenne K20 is offline   Reply With Quote
Old 10-06-2023, 08:16 PM   #2
72 Cheyenne K20
Re: Anyone Ever Bent Their Trans Dipstick Tub
Here is a pic of what I’m working on. You can see the black spark plug bracket and the position in relation to the dipstick tube. The way it is now, not gonna happen.
Old 10-06-2023, 08:45 PM   #3
72 Cheyenne K20
1 more
Old 10-07-2023, 08:01 PM   #4
Honest Bob
Honest Bob's Avatar
I have tried and ended up kinking it bad enough to have to buy a new one.
Can you rotate it to a better position?
Honest Bob is offline   Reply With Quote
Old 10-07-2023, 10:50 PM   #5
Dead Parrot
I would look at making a custom spark plug bracket over risking ruining a trans filler tube. Or look at mounting the 4 wire loom vertically facing the firewall so the wires go behind the filler tube.
Dead Parrot is offline   Reply With Quote
Old 10-08-2023, 12:34 AM   #6
mongocanfly
mongocanfly's Avatar
not the trans, but i tried bending my oil dipstick to clear headers, it broke
i wound up using a Lokar flexible on it, they also make them for the trans...you might look into that
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 10-08-2023, 08:12 AM   #7
cadillac_al
Half of my trucks have a shorter dipstick tube, probably from a car. That would be my solution. I bought an aftermarket dipstick tube for my car that seems to work pretty well, doesn't leak.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 10-08-2023, 09:26 PM   #8
72 Cheyenne K20
Thanks for the input & suggestions! I'm headed to a local junk yard here in a few days. Ill look for a shorter version.
Scott
Old 10-09-2023, 12:57 AM   #9
Accelo
Accelo's Avatar
Yes It will break if bent.
Consider installing a spacer between the tube attachment point and the back of the block.
If you have the room you might be able to go in front of the tube that way.
Difficult to ascertain how much room you have before the tube impacts the cowl.
Cheers
Accelo is offline   Reply With Quote
Old 10-10-2023, 11:17 AM   #10
kwmech
I've bent them before --ever so slightly by using an electricians conduit bender. but you have to remove the tube from the vehicle
Old 10-14-2023, 10:57 PM   #11
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
I bent a 6l80 tube with a tube bender to make it fit a little better. If you have the correct tube bender, then it will more than likely bend no problems. But if you don't have a bender, expect it to kink. If you have a 3d printer, you can print yourself the dies and make a home made bender for a few bucks. I made a set of 3d printed dies to bend some aluminum tubing for an a/c line project. I got the idea to 3d print a set of dies from youtube, these guys 3d printed dies to bend 1.5" steel tubing in a hydraulic tube bending machine... pretty cool
https://www.youtube.com/watch?v=R7y5MIux_uQ
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
