Old 10-06-2023, 07:40 PM   #226
Factory Guy
Factory Guy's Avatar
Re: My New Truck
Thanks everybody for the compliments!
Factory Guy is offline   Reply With Quote
Old 10-26-2023, 07:29 PM   #227
Factory Guy
Re: My New Truck
I have decided to repair my speedo cluster where the transmission selector broke that rides against the speedo housing. Unforunately for me the 50 year speedo housing cluster broke here last time I tried to install the little cable wire that controls the shift linkage cable. Thus, I have been trying to decide the best way how to fix it.
Yellow arrows.
Old 10-26-2023, 07:42 PM   #228
Factory Guy
Re: My New Truck
My way of correcting this turned out pretty well.
I first took some super glue (which I have terrible luck with) and installed the broken plastic piece back into to the housing and since I know this WON'T HOLD, I decided to reinforce it with a mechanical bond as well.
So I took a very small brad and made and hook into it. Then I laid it on a sodiering iron until it got quite warm then I pressed it into the weak portion of the speedo cluster to mechanically bond it back together.
Since I am still fearful this area is weak. I appied a fair amount Super glue and BAKING SODA to the back side of this area to make it nearly impossible to fracture at the cracked area again.
Old 11-16-2023, 04:10 PM   #229
Factory Guy
Re: My New Truck
So getting ready to start the truck and I realize that the trans cooler lines need to be hooked up AND since the front end is pretty much missing why not install a Tranny cooler, so we get started on this...
Guess I will learn about "AN" lines since I do not want a leak like I had before with the old tranny cooler.
Just ordered all the lines and fittings.
Old 11-22-2023, 10:03 PM   #230
Factory Guy
Re: My New Truck
The Auxiliary cooler/Fan is now mounted and installed just waiting for the AN lines to show up!
In case you are wondering why this Auxiliary cooler is down low and basically behind the front bumper, I DO NOT have any room in front of the radiator. Since this is a 1973, it has a very DEEP GMC grill.
I had previously installed the 75-76 GMC grill, and really like it better than the 73 grill. Now that I am installing the GM remote hood release (1977 year) on this truck, it doesn't PLAY well with my 75-76 grill, or a 73. The 1977 GMC grill is very SHALLOW and the center radiator support sticks much further out than the 73 Radiator Center Support.
But I think I will get it all to work together with my 75-76 grill (without hacking up the grill-or the supports for the front of the Radiator support). I am trying to get it to look as close as possible to being built by the factory.
Old 11-27-2023, 10:50 AM   #231
Shifty One
Shifty One's Avatar
Re: My New Truck
Nice solution for the coolers!
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 11-27-2023, 09:48 PM   #232
Factory Guy
Re: My New Truck
Ok Here's what you run into if you opt for the hidden hood latch (year 1977 truck option). The 1977 center radiator support is on the right, and with all those curves would require cutting up the grill if you want to use the early Squarebody grills.
The Center Radiator support for a 1973 is on the left so I took the 77 hood latch/catch mechanism out and just grafted the hood latch mechanism into the back of the 1973 center radiator support, it has both bolts and screws holding it into place (still have to figure out the secondary hood safety catch mechanism).
Old 11-27-2023, 10:08 PM   #233
Factory Guy
Re: My New Truck
Now off to making a TRUE COLD AIR intake like GM did when they designed the LS. So many people just place a KN filter on a tube inside the engine compartment and believe they have good system, yet this isn't as good (IMO) as what GM engineered into the LS, they pulled and placed into their vehicle.
A stock GM truck with a LS has a true cold air system pulling, air in, from in front of the radiator support, a much better design than the original Small Blocks.
I saw a Gale Banks video where they are making up some air scoops that fit underneath the bottom of the front bumper and duct air directly into the air box (to get outside air into the engine) of course this was for a Diesel, but I thought why can't we do this?
Since I will be using the LS Stock air box, I figured what the heck, lets see what I can mock up.
The silver tube will pull in outside the engine compartment air (as I DO NOT want to cut up my original Radiator Support).
So...
Old 11-27-2023, 10:12 PM   #234
TKCR
TKCR's Avatar
Re: My New Truck
I don’t blame you for not wanting to cut your core support.
Old 12-26-2023, 08:27 PM   #235
Factory Guy
Re: My New Truck
Well I keep getting distracted. I started reading about how these Squares have a tendency to crack the frame at the steering box, ESPECIALLY on the 4WD models. Fortunately for me mine is both 2WD and NOT cracked, but to ensure it does not get cracked I installed this Steering box/frame stiffener from Offroad design. Unlike the 4WD models this one goes ahead of the front cross member, rather than behind it.
Since a good chunk of the front end was/is still off the truck I decided to order this and get it installed. Made for a pretty easy install.
Old 12-27-2023, 01:12 PM   #236
Shifty One
Shifty One's Avatar
Re: My New Truck
That's still on my list of things to do...
Old 01-02-2024, 08:04 PM   #237
Factory Guy
Re: My New Truck
Yes I know that feeling!
Old 01-28-2024, 08:34 AM   #238
hewittca
hewittca's Avatar
Re: My New Truck
I'm following along to see how that air intake setup comes together. I have one of those "filter on a tube" intakes and don't really like the look or sound of it as it sucks in air. I also like that frame stiffener for the steering box. I've never seen that before.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 01-31-2024, 11:54 AM   #239
Factory Guy
Re: My New Truck
Cool...No worries I will post when I have more. So far I have been traveling so much I haven't had a chance to spend ANYTIME in my garage in the last month or so.
Old 02-05-2024, 06:40 PM   #240
Factory Guy
Re: My New Truck
Finally got back to making some progress on the Truck. I decided since the front end is still disassembled I would get the AC condenser installed. So I order a condenser off of amazon, as others had decent luck making it fit on their trucks. I got the condenser and there was no way it was going to fit on my truck. Sent it back. I ordered the Vintage Air condenser kit and it turns out to be a really nice kit WITH a drier as well. Thus got it installed. This fits really well in a 1973!
Old 02-05-2024, 06:44 PM   #241
Factory Guy
Re: My New Truck
So now we can finally place the radiator/electric fans in the engine compartment for the last time, and bolt it into place.
Old 02-05-2024, 06:50 PM   #242
Factory Guy
Re: My New Truck
Since the radiator is in, now I can start reassembling the front end!
Old 02-06-2024, 02:07 PM   #243
Shifty One
Shifty One's Avatar
Re: My New Truck
That looks slicker than baby snot on a brass doorknob!
Old 02-06-2024, 02:55 PM   #244
SCOTI
SCOTI's Avatar
Re: My New Truck
I love the clean work getting done on this thing
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 02-06-2024, 08:54 PM   #245
Factory Guy
Re: My New Truck
Old 02-08-2024, 07:48 AM   #246
hewittca
hewittca's Avatar
Re: My New Truck
This last batch of photos/updates makes your engine bay look SO clean and factory fresh. I like it... alot. Maybe that's why they call you Factory Guy.
Old 02-10-2024, 12:14 AM   #247
Factory Guy
Re: My New Truck
Thank you!
Old 06-10-2024, 08:09 PM   #248
Factory Guy
Re: My New Truck
So now the 51 Year old Squarebody now has a Fuel injected engine and she runs!
https://youtu.be/KcL-vaPME3g
Old 06-10-2024, 08:22 PM   #249
MusicMan70
MusicMan70's Avatar
Re: My New Truck
Video says PRIVATE
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 06-11-2024, 08:59 AM   #250
SCOTI
SCOTI's Avatar
Re: My New Truck
Originally Posted by MusicMan70 View Post
Video says PRIVATE
x2.
Can't view it because of the settings.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
