Old 10-04-2023, 02:53 PM   #1
Tip70
Tip70's Avatar
1970 Jiffy Mount Tire C10 build
Hey everyone. Figured I'd finally start my own build thread for my truck. I will post some before and after pics (since I have worked on it since 2000 off and on) and also my future mods for the truck.
The Logo on the door is a company my Dad co-owned back in the 70s and I thought it would be a fun homage to him and fit the era of shop truck.
The seats I designed and sewed up. They are buckets out of a '99 chevy, if I remember correctly.
The ad is a remake from an older one, that you may have seen, pic replaced with my son washing the truck
Tip70 is offline   Reply With Quote
Old 10-04-2023, 03:12 PM   #2
68Gold/white
Re: 1970 Jiffy Mount Tire C10 build
I like it!!!
Tell us about that grill...
68Gold/white is offline   Reply With Quote
Old 10-04-2023, 03:25 PM   #3
Tip70
Tip70's Avatar
Originally Posted by 68Gold/white View Post
I like it!!!
Thanks! Yea its a phantom grille I got back in early 2000s. Wish I could remember the company I bought it from. I like that you dont see it done on many c10s now a days
Old 10-04-2023, 08:16 PM   #4
yuccales
yuccales's Avatar
The add with your boy is very Cool!
yuccales is offline   Reply With Quote
Old 10-05-2023, 04:28 PM   #5
Tip70
Tip70's Avatar
Ive been wanting to get it printed and up on the shop wall
Old 10-06-2023, 01:07 PM   #6
Tip70
Tip70's Avatar
Here are some pictures of my truck when I first got it back in summer of 2000. No engine, orange doors, no seats, diamond in the rough
Old 10-06-2023, 01:12 PM   #7
Tip70
Tip70's Avatar
Also found this pic of the behind the side marker gas cap. 2013.
Old 10-10-2023, 02:12 PM   #8
Tip70
Tip70's Avatar
Made a custom headliner to match the seats. I used magnet to keep it up, And it has yet fell down on my drives which is a plus
And it is nice that if Id like to go back, there is no damage/holes to the cab.
Old 10-10-2023, 03:47 PM   #9
loudchevy
Active Member
loudchevy's Avatar
Nice truck. I dig the headliner matching the seats you did.
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 10-11-2023, 12:39 PM   #10
clay68c10
clay68c10's Avatar
That headliner idea is great. A lot of new cars use the magnets to hold headliners. I never thought of doing that to one of these trucks.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 10-11-2023, 02:57 PM   #11
Tip70
Tip70's Avatar
Thanks! Yea, since my truck never had the option, it was the easiest/cheapest option for me to add one
Old 10-11-2023, 02:57 PM   #12
Tip70
Tip70's Avatar
thank you!
Old 10-11-2023, 11:11 PM   #13
chewychevy67
What kind of magnets did you use how many??
chewychevy67 is offline   Reply With Quote
Old 10-12-2023, 07:52 AM   #14
yuccales
yuccales's Avatar
Headliner looks great!
Old 10-12-2023, 12:00 PM   #15
Tip70
Tip70's Avatar
Im not sure the specs on the magnets I used. I pulled them from a bunch of gps antennas that my work was throwing out. I stacked 3-4 in each spot. Also, as you can kinda see in the photo, I used some name tag magnets. Basically I was trying to make this work with what I had on hand, without buying more magnets.
There are some good websites out there that you can buy magnets in all shapes and sizes.
Old 10-13-2023, 12:57 PM   #16
Tip70
Tip70's Avatar
My side marker light lenses were cracking and needed replaced. Instead of buying new ones, I decided to design up my own in Illustrator and engraved/cut them out on my laser cnc. 1/8" acrylic.
many years back I put these fender vents in. Another unique mod
I didn't want the M3 logo in there, so I was able to make these bubble c/10 badges by pouring epoxy resin. this was before all the SUVs, like the suburbans, started to run fender vents. I remember this, because people thought I was copying them.
Old 11-16-2023, 12:33 PM   #17
Tip70
Tip70's Avatar
Winter weather is close here in the pnw so Im gearing up for my winter project! Im going to work on my long bed to short bed conversion. I dropped all the wiring from the side marker lights and tail light. Then removed the air tanks, compressors, and wood to lighten it up. Next will be to get it lifted up to drive the truck out.
I will work on the bed sides first, then the frame. Wish me luck!
1970 C/10 LWB
build thread:
https://67-72chevytrucks.com/vboard/...d.php?t=847860
IG- Tip70
Old 11-29-2023, 05:05 PM   #18
Tip70
Tip70's Avatar
Got the first cuts done with the bed shortening. It was a bit nerve racking, but after a couple inches in, I was committed. No turning back right?
Only thing Id change would be to do the conversion before shaving the tailgate. But when I did that back in '07, I did not know that was an option.
Oh well, Ill get it done
1970 C/10 LWB
build thread:
IG- Tip70
Old 11-29-2023, 05:55 PM   #19
Shifty One
Shifty One's Avatar
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 11-29-2023, 11:22 PM   #20
wwboater
Looks great, that first cut is by far the hardest.... cant wait to see it going back together...
wwboater is offline   Reply With Quote
Old 11-30-2023, 10:47 AM   #21
loudchevy
Active Member
loudchevy's Avatar
Nice, I'll be following along to learn. Good luck
Scott
2003 Tahoe Stock
Old 12-01-2023, 02:44 PM   #22
Tip70
Tip70's Avatar
Yes for sure! stay tuned, hope ill have enough time to get this conversion complete in a timely manner. want to be able to drive it come summer
awesome! hope I can help out
1970 C/10 LWB
build thread:
IG- Tip70
Old 12-07-2023, 05:15 PM   #23
Tip70
Tip70's Avatar
Some more progress on the conversion. I was able to finish up the cuts on the bed and seem to be fitting back together alright. So that's a plus.
Next, some welding.. wish me luck! It's been awhile since I've thrown down some welds
1970 C/10 LWB
build thread:
IG- Tip70
Old 12-13-2023, 11:43 PM   #24
Tip70
Tip70's Avatar
So I started welding on my bed and it was a bumpy start since I haven't welded in a few years. But Im getting the hang of it. I have these photos that I took in the middle of what I have done. The one photo of the top edge, I have filled in. Since it didnt fit that well, probably due to some error I did, I used a metal clothes hanger to help fill the gap and now you cant tell it was even there.
Then I ran out of MIG wire, so that gives me time to catch up on some Etsy orders I need to get out! Its the busy time of year!
They are leather keychains/bag tags That I engrave on my laser and then hand punch and stitch. It helps feed my hobbies
more pics of the bed soon...hopefully!
1970 C/10 LWB
build thread:
IG- Tip70
Old 12-14-2023, 02:45 AM   #25
Scurry67
Looking good!
67 SWB First Build
http://67-72chevytrucks.com/vboard/s...d.php?t=777171
Scurry67 is offline   Reply With Quote
