#551 |
Re: 8 lug wheels - what's on YOUR truck?
Thanks bud. That was back in 2015.
Nobody made a 17" wheel that could hold a factory hubcap so I had no choice by to figure it out and make my own solution. I've seen posts now that US Wheel makes one now (Series 664)... 17 x 9 and 17 x 10 with positive offsets which is nice. They don't have the 4 small factory "windows" but most people would probably not even notice that small detail. -G
1972 K5 - 502BBC/4L80E/Magnum205/Mog-9s/5.26s/38" BFG KM2s Find me on INSTAGRAM @MIGHTASWELLK5 '72 K5 - Greg's "Might As Well™" Build Last edited by -Greg72; 07-14-2023 at 10:05 AM. Reason: typo |
#552 |
Where did you find the 17'' hoops?
#553 |
Here is my initial setup .....
Have a second set in the works as well!
1972 K5 Build - plans - LS3-6L80e-One Tons..... 1971 CREWMAX Build.....at body shop for couple more years ![]() |
#554 |
Junior Member
![]() Join Date: Apr 2013
I’m looking for some 16” steelies. Anyone know about the US Wheel OE series? They offer powder coating in a Sky White color for $35/wheel, but I’m not sure how that stacks up to the factory color.
#555 |
The Niner
![]() Join Date: Nov 2010
My 70 C/20 originally came with 16 x 6.5" rims with 265/75/16 Back Country A/T tires.
Swapped those out for 16 x 7 F#rd rims with 265/75/16 Michelins and the appropriate hubcaps.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
#556 |
Yah, Accuride here too.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
#557 |
#558 |
This is the route I took. I had them powder coated as Coker didn't offer them in white.
#559 |
here's my 72 truck with it's original 16.5's repainted and the spare wheel with 5 new Firestone Transforce 9.5x16.5 10 ply tires and a set of hubcaps i restored.
#560 |
#561 |
#562 |
![]() Join Date: Sep 2013
Here are mine: 19.5" Kelsey-Hayes which were an option for these trucks.
John 1967 C20 2WD Longbed 2001 2500 HD 4X4 Extended cab long bed ![]() |
#563 |
#564 |
#565 |
#566 |
![]() Join Date: Feb 2009
I installed Western Wheel cyclones 8.25x16.5 cyclones. Polished and powder coated. They were the best conditioned parts on the truck. I sold the truck last year.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#567 |
![]() ![]() Both Wheel Vintiques 16 x 8, both powder-coated.
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
#568 |
Thanks Factorystock. I prefer them even though they are not a common or popular choice.
#569 |
The GREAT BIG blue rally looks so nice.
#570 |
![]() Join Date: Dec 2017
Are those the stainless trim rings from Wheel Vintiques as well? Or factory GM from OBS truck? Looks like the rings that were factory on a 88 I had at one time. Ive got a full set of the Ford 16x7 wheels on now, but considered going with a 8 inch wide wheel on rear (tough to find salvage 16x8). I like a wider/slightly taller tire on the rear of a 2 wheel drive, especially on a 3/4 ton with a big block. It used to be common to run wider off road tires on the rear of 2 wheel drive. Guess I am showing my age. |
#571 |
They are OEM OBS from the stock skinny wheels.
