Old 12-12-2023, 06:53 PM   #1
MrBeast
high-Tech Red Neck
MrBeast's Avatar
1963 C50 Clutch issues?
Howdy guys!
I am currently looking at buying a 1963 C50 that I found for sale, the problem is that it has a non functioning clutch. Owner says that he replaced the Master Cylinder, apparently these trucks had a combined cylinder for the clutch and brakes?
He says he thinks the slave cylinder is bad, it sounds like he is tired of messing with it, but it is not a system I have ever messed with.
I am wondering if parts for it are available and if there are any upgrades that are recommended? Ideally I would like to just put a hydraboost on it with a separate slave cylinder, not sure if anyone makes off the shelf parts that can do this or if I would have to fabricate it?
The truck is really clean, almost no rust and just a couple of dents, but it is also 500 miles away from me which complicates things as it is a bit larger than any trailer I have access to (which is why I am looking at getting it to build a tow rig)
Any insight here would be greatly appreciated.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 12-12-2023, 09:20 PM   #2
62c30
Re: 1963 C50 Clutch issues?
If the slave and master is the same as my 62 c30 yes they are available. I have not messed with anything bigger though. Just make sure to get a new one or a reman that has been sleeved. I had put a rebuilt one on and it was pitted pretty bad and the fluid would bypass and it didn't work very good.
62c30 is offline   Reply With Quote
Old 12-13-2023, 07:16 AM   #3
Agv63
Funny this should come up for discussion.
I actually looked at a slave cylinder this morning on amazon forr my buddy as his one is worn out.
Link attached.
Adriaan.
https://a.co/d/h0P1q6c
Agv63 is offline   Reply With Quote
Old 12-13-2023, 10:36 PM   #4
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Thank you for the info.
Old 12-13-2023, 10:38 PM   #5
MrBeast
high-Tech Red Neck
MrBeast's Avatar
I was kind of surprised as this will be my first 60-66, The oldest I have had before this was a 67, and everything up till the 80's had a mechanical clutch.
I saw that CPP makes a vacuum booster kit, and found a video of the install, it seems to me I could do the same thing with a hydroboost, then would need to run new line which is a good idea anyways.
Old 12-14-2023, 03:39 PM   #6
Wrenchbender Ret
This system is easy to work on & is a good dependable system. You can put a kit in the present cylinder. These cylinders generally don't get pitted very badly as they get a full stroke every time they are used. A run with a wheel cyl. hone & a repair kit & bleed the system, should fix it up.
George
Wrenchbender Ret is offline   Reply With Quote
Old 12-15-2023, 12:29 PM   #7
Pick121
Pick121's Avatar
Mr. Beast! There is a ton of great info here on 60-66 but I also welcome you to raise the question on the Heavy Haulers Forum “Beyond C30…the Heavy haulers!” http://67-72chevytrucks.com/vboard/f...play.php?f=239
Those folks are very well equipped to answer C50 questions.
I also have a ‘64 C10 and a ‘63 C50 so I jump from forum to forum.
A photo of the firewall would help and also what engine and trans it has. My ‘63 C50 has a separate Master Cylinder and clutch but I have seen the combined MC and Clutch on ‘62 and earlier.
Here is how mine is, stock setup, the combo system will have 2 metal lines from the bottom of the MC
Pick121 is offline   Reply With Quote
Old 12-16-2023, 11:41 PM   #8
MrBeast
high-Tech Red Neck
MrBeast's Avatar
I am definitely going to have to dig into that forum! Think I have it figured out as far as the brake/clutch system goes. Have 3 different trucks I am looking at right now, we will see what happens, still need to get my 80 sold first before going and grabbing one.
