12-24-2023, 02:26 AM | #151 |
Re: Playing the long game!
Ah, did not catch that detail, cool.
1970 C10 Custom longbed 350/350 |
12-28-2023, 04:29 PM | #152 |
Thank you.
Their constant involvement might just make this my favourite build yet.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
12-28-2023, 04:32 PM | #153 |
Cab on and back on the ground. Love the look of the red and yellow side by side.
GM sure had some great colours back then.
12-28-2023, 04:42 PM | #154 |
Changed up the GM power steering box for a 500 series unit from CPP. I did the same upgrade on my Blazer about 7 years ago. Totally forgot that it didn’t accept the factory rag joint spline. In 1967 the columns have a single shaft that runs from bolt to rag joint, Had to swap in a 69-72 column that uses an intermediate shaft.
Went with a solid DD shaft. Didn’t realize that Borgeson makes a collapsible shaft, so looks like ill have to upgrade that soon.
12-28-2023, 05:01 PM | #155 |
Test fit an old fender to see what the fender gap looks like, looks like it’ll need to go down a bit more to sit level. Wont make any adjustments until the body is fully assembled.
01-28-2024, 08:44 AM | #156 |
I'm still here following along! I love the mockup shot. How do you plan to "adjust" the ride height up front if needed? Also love that your kids are still getting out there and helping. Mine do too from time to time. Makes the build more special when you can share it with them. That steering column looks nice as well. When I did my power steering swap I basically bought every coupler ever made and still had trouble picking the right one! This is going to be one of the nicest long beds out there. Now, when are you going to shorten it!? Juuuust kidding.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
03-27-2024, 01:01 AM | #157 | |
Blazer had a 26.75” tire setup up front. Tom has a 29.30” tire setup up front. So that will make things a bit different as well.
04-22-2024, 02:38 PM | #158 |
It's coming a long nicely. Very cool that Tom is still involved and up to speed. Don't know if you're using a hazing effect with the pictures you take. But if not, sometimes I have to clean my phone lens.
