01-06-2024, 10:13 AM | #1 |
Chev-odge: ‘71 K20 Cummins build
Welcome to the build of my Chev-odge. I’m Rob and I’ve always wanted a Cummins diesel truck and I wouldn’t want anything else except a 67-72 Chevy to house it in. I am thankful for this site and the resources it contains as I certainly will be needing them, and you. Thank you for your input and help ahead of time. Enjoy the fun and struggles with me that this will bring…and hopefully we’ll see a great outcome at the end.
So to start things off, here’s the 1989 5.9 Cummins I purchased with 400,000 miles. With this, I received the 5 speed Getrag transmission (no transfer case), the front and rear differentials (with 3.08 gears I am told, not verified), the driveshafts and to me, one of the most important items…the front clip of the Dodge. Right now my goal is to use the factory Dodge crossmember (with mod and fabrication) in the K20 frame. I think using the Mopar mounts will be slick. Has anyone else used a Mopar cross member? If so, what was your experience? Last edited by fishnixon; 01-06-2024 at 01:21 PM. |
01-06-2024, 10:54 AM | #2 |
Re: Chev-odge: ‘71 K20 Cummins build
Sounds like fun, Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
01-06-2024, 11:19 AM | #3 |
I will follow along.
Here are a Few threads. Link: https://67-72chevytrucks.com/vboard/...hlight=cummins Link: https://67-72chevytrucks.com/vboard/...hlight=cummins Link: https://67-72chevytrucks.com/vboard/...hlight=cummins
01-06-2024, 06:47 PM | #4 |
Looking forward to seeing the build.
NHRA Super Street 469C It only runs 10.90 at 156 mph |
01-06-2024, 11:24 PM | #5 |
Me too, this will be interesting!!
01-08-2024, 10:35 AM | #6 |
01-08-2024, 10:36 AM | #7 | |
01-08-2024, 10:37 AM | #8 |
01-08-2024, 10:38 AM | #9 |
01-08-2024, 11:08 AM | #10 |
I’m calling in reinforcements. Jim and John (father and son), know what to do…they do this for a living.👍
01-08-2024, 11:11 AM | #11 |
The stand is holding!
01-08-2024, 11:13 AM | #12 |
Manifold side done
01-08-2024, 11:15 AM | #13 |
To say the least, a new water pump is needed.
01-08-2024, 11:16 AM | #14 |
Dowel pin is still there even with 400k miles.
01-08-2024, 11:19 AM | #15 |
Intake side done
01-08-2024, 11:20 AM | #16 |
Getting ready to pull the injectors
01-08-2024, 11:22 AM | #17 |
Off with it’s head!
01-08-2024, 11:24 AM | #18 |
Found a small bolt in oil pan…yikes!
01-08-2024, 11:27 AM | #19 |
Inner bolt from timing cover housing.
01-08-2024, 11:31 AM | #20 |
Bolt got wedged between housing and cam gear, chewing up the housing.
01-08-2024, 11:33 AM | #21 |
Everything is coming out…
01-08-2024, 11:36 AM | #22 |
Gutted and ready for magnaflux testing and then machining.
01-08-2024, 03:14 PM | #23 |
Active Member
Awesome build, I'll be following along. Do you have the K20 already?
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
01-08-2024, 03:51 PM | #24 |
01-09-2024, 04:04 PM | #25 |
Brought some parts home to clean up and prime…the pistons are home for good as they won’t be used. We’re going .020 over on the block.
