Re: 1968 C40 to K40 pickup project BlueMule
I cut the 2 skins with 6.375" extra, and used my flanging tool to flange .375" of the blue panel along all the flat sections. After quadruple checking my measurements, I tacked it together. Once I was happy with the fit and overall dimensions, I moved to welding the seam on the front of the panel. .
I have messed up some good welds by getting too impatient, so I took my time, putting a stitch weld about every 3 inches along the length of the seam. I then hit it with air until cool to the touch before making another pass. I'm pretty happy with the result. I test fit the skin onto the door frame, and it fits very well. I will pull it back off soon to test fit the full glass panels and the seals once they all come in. (wing window seals on back order)
Mike 67 Camaro "Amber" 72 K10 Longbed "Old Green" 68 C40 to K40 project BlueMule Build 2006 GMC Sierra "Lello Truck" |
Roadtrip!
![]() Join Date: Feb 2003
You have skills! Looking good.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
![]() Join Date: Nov 2022
Subscribed!
Thank you, I appreciate the comment. However, we shall see over the course of this project. I am having fun with it, and hopefully I'm not making a huge mess that I have to haul off to the scrap yard. Either way, I'm learning a lot along the way.
BTW, that's an impressive list of vehicles in your Signature. Welcome!
Been a little while since I posted but I have been working on the doors.
I took a bunch of video of the door skin stretch and re-assembly, so I may to post that to YouTube and will post a link if so. I finished up the passenger door skin, cleaned up the welds as best I could and reassembled the door. Re-bending the hem material of the skin back onto the door was a pain. The 1968 panel (blue) I had only bent 30 to 45 degrees, but it split in several places when bending back down, so I had to weld the door edge after I got it all back together. I didn't have any issues with the 1972 panels, even where I had to bend them up to 90 degrees to get the panel back on the frame. I then used a surface conditioning tool to remove all the old vinyl sign material. You can see on the last post that the doors had some magnetic signs on them over the old vinyl too, so there is some rust that got between the magnet and the door. I wanted to expose all of that, and get it cleaned up and treated. I also took the rest of the paint off the skin. Then I test fit the door onto the cab. It will need a little work on the drip edge gap.
Tags |
1968, 427, c40, c50, k40 |
