Old 01-23-2024, 02:13 PM   #1
67OLDSTYLE72
High hump to low hump pan
I have searched the internet trying to find any one out there making a bolt in low hump floor pan like you would have in a 2 wd. truck that are part of the one pcs. floor.
I know that they were only a bolt in a high hump version but I thought maybe some one made the conversion the other way so you could use it to go from a high hump to the flat floor.
I was trying not to cut a good cab up or a whole replacement floor to make one myself, any information is appreciated thanks Jay
Jay Snyder
Leechburg, PA (Northeast of Pittsburgh)
72 Chevy Cheyenne 4x4 camper special #matching
'71 Chevy Dually 4x4
'69 Chevy Pro Street swb.
'72 Chevy camper special 4x4 402 v8 (not factory) just cool. (truck puller)
70 Chevy swb 400 v8 400 turbo
72 Chevy suburban 4x4, 396 4spd.
68 Chevy shortbed 50th Anv. 327.
72 Chevy 2 wd. Blazer
69 Chevy swb 4x4 327 4spd.
58 Chevy Apache 4x4 swb.
71 Chevy CREW CAB swb 4x4 396 4spd. (just finished)
WE BUY AND SALE TRUCKS AND PARTS
67OLDSTYLE72 is offline   Reply With Quote
Old 01-23-2024, 03:29 PM   #2
TotallyHucked
TotallyHucked's Avatar
Re: High hump to low hump pan
There's no bolt in low-hump on the market that I'm aware of. Everybody is typically needing more clearance, not less, hence the high humps being made
1985 GMC Sierra Classic
Chopped down wrongbed
Cammed LH6 5.3/T56/3.90
Walker Tuned
5/8 drop
US Mags
TotallyHucked is offline   Reply With Quote
Old 01-23-2024, 03:36 PM   #3
dagnabbitt
dagnabbitt's Avatar
Yeah I've never seen an aftermarket one. A buddy and I cut one out of a cab to use, though: it was not hard.
Don't feel bad, there are lots of cabs getting crushed and you might as well get a trans hump out of one of them. The nice thing about them is that they are usually so soaked in grease that they are rust-free!
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 01-23-2024, 05:34 PM   #4
pjmoreland
pjmoreland's Avatar
I've got a low hump listed for sale. You'd have to weld it in though.
https://67-72chevytrucks.com/vboard/...d.php?t=847910
pjmoreland is offline   Reply With Quote
Old 01-23-2024, 06:14 PM   #5
Rg500gamma
Junior Member
If you could locate a dented up hood that would be perfect for the floor pan.
Next I would try and find a hi hump truck and make a template for the size and bolt locations. Weld in the nuts required and rust encapsulate the underneath. A roll of seam caulk and you will be looking factory
Just my humble solution I would do
Mike
Rg500gamma is offline   Reply With Quote
Old 01-24-2024, 09:58 AM   #6
67OLDSTYLE72
thank you all very much. I have 3 cabs here at my place in western Pa. and they are really hard to get in half decent shape. I would be interested in the pan that is for sale. I surely do appreciate all of the comments and help that I have received over the years. Thanks Jay
Jay Snyder
Old 01-24-2024, 01:44 PM   #7
c30
Junior Member
c30's Avatar
Easy enough to make one. years ago I wanted access into that area so I cut out the original floor following the factory stamped beads. Added a 1" flange around that. I used some captured body nuts and bolted the original piece back in.
c30 is offline   Reply With Quote
Old 03-03-2024, 10:19 PM   #8
jjzepplin
jjzepplin's Avatar
I had a fella on here that wanted a high hump. I traded him for a cut out of a junk cab floor. I have a body lift so the low hump is low enough. I had him cut it out larger than needed and just cut to size and drilled holes. Works great.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 03-04-2024, 01:05 PM   #9
67OLDSTYLE72
The one i bought on here worked out really well for me also. thanks for the comment, every bit helps
Jay Snyder
Old 03-05-2024, 11:03 AM   #10
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
I cut the low hump out of a floor a buddy bought for the rockers. I then took the high hump and traced the hole layout and edges onto the low hump and trimmed it up and drilled the holes so it will bolt down like if the factory did it. then seam sealed it up before putting the carpet down.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
