02-02-2024, 06:40 PM | #1 |
Center caps
What center caps do I have? I just bought them and look to be NOS but not sure.
Carl 1971 GMC short bed, (Henry) Options I've added, tilt, ac, 8k tach, Electric speedometer conversion for LS swap, 6.0 with 823 heads and BTR stage 4 truck cam, 4L80e, posi with 3.73 rear end, Power steering and power brakes Lowered 5/7. Frame up build. |
02-03-2024, 03:56 AM | #2 |
Re: Center caps
Just an edjucated guess, I would say those are 1967 - 1968 caps with out the paint. They also look like they might be for a C20, guessing by how deep they look on my computer screen. What is the overall diameter?
1968 C10 327, 3 speed manual, LWB stock height daily driver. 1968 C20 327, 4 speed manual, LWB stock height custom camper with heavy duty leaf springs rear, 50th anniversary edition. Hoping to press into daily drive status soon. |
02-03-2024, 06:00 AM | #3 |
Re: Center caps
10 3/4” outside to outside, 10 1/4” inside to inside and 2 5/8” deep
Carl 1971 GMC short bed, (Henry) Options I've added, tilt, ac, 8k tach, Electric speedometer conversion for LS swap, 6.0 with 823 heads and BTR stage 4 truck cam, 4L80e, posi with 3.73 rear end, Power steering and power brakes Lowered 5/7. Frame up build. Last edited by CarlsLQ9SS; 02-03-2024 at 06:18 AM. |
02-03-2024, 08:45 AM | #4 |
Re: Center caps
What you have are hubcaps. Center caps are what are used on styled wheels. Lil hoodlum is correct. These are 67-68 C/10 hubcaps. The hubcaps for 20/30 series look from the from identical to the 10 series, same diameter. But those are different on the back due to having an inner ring used to accept the clips on the wheels for mounting
02-03-2024, 08:53 AM | #5 |
Re: Center caps
Those are 1974-1990 Chevy car poverty caps, mostly used on police package Bel Airs, Impalas and Caprices..
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
02-03-2024, 12:15 PM | #6 |
Re: Center caps
Thanks everyone for your replies and knowledge. I agree with 1970cstblazer, they are identical to the pictures you posted. I was thinking they was 67-68 hubcaps but my question is will they work on 68 Chevy truck wheel?
02-03-2024, 12:41 PM | #7 |
Re: Center caps
I don't think those will work. They require the stamped nubs on the wheel to attach.
02-04-2024, 11:16 PM | #8 |
Re: Center caps
IF you have the stock nub style wheels, then yes, these will fit
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
02-05-2024, 07:40 AM | #9 |
Re: Center caps
These will work on 5 and 6 lug truck wheels the same as they work on car 5 on 4 3/4" wheels. The same is true for all Chevy car hubcaps that mount by nubs, which began in the early 50s.
'54 car caps on 5-lug truck wheels
02-05-2024, 12:43 PM | #10 |
Re: Center caps
Most passenger car & 1/2 ton truck caps are 10 1/4 ID & fit on both wheel pattern wheels (5x4.75" & 5x5").
Later 3/4 ton trucks utilize the larger 12" ID caps. Early smaller trucks (chevy Luv) used a 9" cap.
02-06-2024, 09:50 AM | #11 |
Re: Center caps
yep, that's the gospel there. The 9" are what you'd find on the 4-luggers like Corvair and Chevy II. On my trailer, which has 5 x 4 1/2" lug pattern, I have Mopar (which used the 9" caps) 15" wheels with LUV hubcaps
02-06-2024, 06:04 PM | #12 |
Re: Center caps
i was told theyre s-10 caps square body style
1967custom |
02-06-2024, 08:35 PM | #13 |
Re: Center caps
Nope.
S10's & Sonoma's had their own specific caps. The ones posted initially were full-size B-body Impala/Caprice caps.
02-06-2024, 10:46 PM | #14 |
Re: Center caps
I tried these on a rough old truck wheel. This wheel is a Chevy 5 on 5 and they fit perfect, thanks everyone for the replies.
