Old 02-13-2024, 03:42 PM   #1
54blackhornet
54blackhornet's Avatar
Heater Delete Plate For Dashboard ?
A fellow member that once produced the delete pieces for under the hood was also going to make one for the dashboard, did he ever offer them ? I emailed him but didn’t hear back ?
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 02-13-2024, 05:42 PM   #2
weq92f
weq92f's Avatar
Re: Heater Delete Plate For Dashboard ?
Went down the rabbit hole on this...there were factory delete plates..but rare indeed. Here's one that appears to be rather crude:
https://www.a2metalfab.com/products/...l-delete-panel
Ebay has heater control rebuild kits that you could maybe use to build your own:
https://www.ebay.com/itm/15407149443...Bk9SR9yhx8a0Yw
There's one factory radio delete panel on eBay, but it's gonna be smaller than the heater control panel.
Hth,
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 02-13-2024, 06:11 PM   #3
54blackhornet
Thanks so much for the link !
71 C-20
07 Magnum RT AWD
Old 02-14-2024, 07:59 AM   #4
On an early truck, I used the opening from the heater controls and mounted a DIN style radio/stereo unit. I then used a radio delete and mounted my 3 round knobs for the Vintage air controls. I can't find the pictures on this computer. I do remember that I welded two metal tabs on each side of the opening as the heater is slightly wider than a DIN hole.
Found a couple pictures.
Old 02-14-2024, 08:21 AM   #5
landarts
landarts
I am using a standard radio delete plate in that location. Moving controls for custom AC/Heater install into the panel below I made from an extra glove box. Panel will have ac/heater controls, two air vents, and LED rocker switches for 4x4 lighting.
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 02-14-2024, 09:20 AM   #6
raggedjim
raggedjim's Avatar
Nice work on the new gauge panel. The radio delete fits surprisingly well. Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 02-14-2024, 09:38 AM   #7
70STOVEBOLT
70STOVEBOLT's Avatar
WOW!!!! I love that idea! Nice work!
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 02-14-2024, 09:51 AM   #8
landarts
landarts
Thanks! It is a good fit for sure.
I did not want to cut up the dash so this was a way to make it look almost factory using the bottom of a glove box lid. This allows someone to put it back to the stock if they wish. The vents are from an Old Air Products Ac install I am doing.
Here is a picture of the start of the panel.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 02-14-2024, 09:59 AM   #9
raggedjim
raggedjim's Avatar
So, what does the bigfoot button do???
Roger
'70 GMC Jimmy 2wd
Old 02-14-2024, 10:59 AM   #10
Extended Power
Extended Power's Avatar
I used a 1/2” piece of aluminum to make a filler panel.
I then used it inside of the stock heater control panel, and then decided to put the Dakota Digital control panel in it, along with my electric fuel, and fan bypass switches.
"If it ain't broken, fix it 'till it is!"
Extended Power is offline   Reply With Quote
Old 02-14-2024, 11:23 AM   #11
sfont66
sfont66's Avatar
X2 on the radio delete plate as a heater delete plate
Check out the factory run/sag in the paint on the ashtray
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB.
Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project
sfont66 is offline   Reply With Quote
Old 02-14-2024, 12:39 PM   #12
54blackhornet
You guys sure have the touch when it comes to fabrication ! Congratulations to you all !
71 C-20
07 Magnum RT AWD
Old 02-14-2024, 12:57 PM   #13
68 C10 Driver
Where did you get the illuminated on/off switches? I like those!
68 C10 Driver is offline   Reply With Quote
Old 02-14-2024, 07:50 PM   #14
custom10nut
custom10nut's Avatar
You’re looking for the proverbial “Unicorn, with a Golden Horn,, and Mermaid on its back”.
They exist, but I’d venture to say that the Heater Control delete Plate is the rarest of rare options/parts.
To my knowledge, they only went in a few fleet trucks, destined for tropical markets.
custom10nut is offline   Reply With Quote
Old 02-16-2024, 09:59 PM   #15
Extended Power
Local auto parts store.
I’m sure they can be found on Amazon as well.
Old 02-17-2024, 10:56 AM   #16
custom10nut
That is absolutely amazing work.
Old 02-17-2024, 12:12 PM   #17
landarts
landarts
They have several different switches here on Amazon.
https://www.amazon.com/gp/aw/d/B07HG...b_b_asin_title
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
