#176 |
![]() Join Date: Jun 2002
Re: Previous owner '68
If you don't have one of these you should get one.
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
#177 |
Once the weather chased me inside I worked on my never-ending steering wheel project. Another 6 months or so of sanding, filling, and painting should get it looking okay.
#178 |
A rare photo of the early design of the 1968 rally wheel. Never made it into production. May be the world's only set that GM didn't crush.
Junk Bros., rare and vintage items, made while you wait.
#179 |
Since it's colder than I care to work in I stayed in the shop today. Not much got done but I did take a good look at the trunions for the tailgate. Not good.
#180 |
Found these flange bearings and made them fit. Had to weld nuts on the back sides, not an easy task.
#181 | |
![]() Join Date: Dec 2009
![]() Will you file flats on the inner race to hold it still , And make a Thin Wrench While torquing/Tightening the bolt?
#182 |
![]() Join Date: Mar 2011
ill take them....LOL they are coooool lookin
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#183 |
No, I found that I could wedge a small flat blade into the access hole and it would hold it enough for me to tighten. I was going to drill a hole in the nut and then use a small pin punch but the screw driver worked so well I hated to jinx it!
#184 |
As far as I know they are the only set that exists!
#185 |
I was joking about ...ill take them but I would if I could
#186 |
Active Member
![]() Join Date: Oct 2012
Roger, I enjoy watching your build and the constant progress you make. Well done.
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
#187 | |
You might enjoy this pic...
#188 |
Active Member
Ouch, is that why you got the full face shield?
#189 |
Ha! Nope, that was a while back. Never fight a cactus.
#190 | |
You're making good progress and I appreciate your take on things. Even mentioning the reality that sometimes we cuss at things that we say we enjoy doing ![]() |
#191 | |
I was in the Navy for 10 years, got out when Clinton was cutting back on the armed forces. I never regret joining the Navy and I never regret deciding to leave, I had changed and was ready for a different type of life. I don't cuss much at all unless I'm in the shop!
#192 |
You're supposed to hug them....they need love too....
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
#193 |
Not from me they don't!
No pics today. Welding and grinding, all day long. I got the truck grinding blues... ![]()
#194 |
I got one of those blue shields and I love it, especially when I'm wire brushing!!!
Take Care Troy |
#195 |
Did a bunch of wire brushing today. Took a wire to the left cojone...
#196 |
safety first we all been there your gonna need more PPE before you do something even worse ....I didn't put my safety glasses on. tonight when I first started cutting some metal ....and stopped put them on .....
#197 |
I'm pretty safety conscious as far as p.p.e. goes, but I refuse to wear a cup while wire wheeling! May have to throw my coveralls on top of my usual grubby jeans though, those wires are shockers.
#198 | |
![]() Join Date: Aug 2004
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#199 |
Finally got the rust patching to a point I felt that I could go ahead and treat the bed with some phosporic acid (Ospho). I know, old tech, but I'm old so there you go.
#200 |
Once that had dried for 24 hours I wire brushed the residue off and painted it with Chassis Saver (like POR15, but not). The gloss really spot lighted the areas that need attention.
