Old 03-24-2024, 11:52 PM   #1
Luke87gt
What is the hub diameter on a 1969 6-lug 2wd?
Is anyone able to help confirm this? Thanks
1969 C10 Shortbed
Wanted (pm me):
- Pair of 275/60/15 tires
Luke87gt is offline   Reply With Quote
Old 03-25-2024, 12:09 PM   #2
70STOVEBOLT
70STOVEBOLT's Avatar
Re: What is the hub diameter on a 1969 6-lug 2wd?
Are you looking for the measurement on the rear axle registers (diameter of the step that the rim fits over)?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 03-25-2024, 11:40 PM   #3
Luke87gt
Diameter of the hub that the rim rides on
1969 C10 Shortbed
Wanted (pm me):
Old 03-26-2024, 08:31 AM   #4
70STOVEBOLT
If it’s the same for a ‘70 I can measure mine after work today.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 03-26-2024, 08:21 PM   #5
Luke87gt
Thank you. Is it 6lug?
1969 C10 Shortbed
Wanted (pm me):
Old 03-26-2024, 08:34 PM   #6
dmb
Active Member
dmb's Avatar
11 inch
Old dogs and children and watermelon wine
dmb is online now   Reply With Quote
Old 03-27-2024, 01:24 AM   #7
Luke87gt
Oh wow
Let me try asking this another way
What is the oem wheel bore diameter of a ‘69 6lug c10 wheel?
1969 C10 Shortbed
Wanted (pm me):
Old 03-27-2024, 06:45 AM   #8
70STOVEBOLT
I will measure mine after work today and post the measurement.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 03-27-2024, 07:17 AM   #9
My wheels have a center bore of a hair over 108mm or a hair over 4.25 inches. I also founds from and saved some notes from some tire place that it is 108.1mm since all the tire folks seem to use the metric stuff no inches for measurements
Old 03-28-2024, 05:55 PM   #10
Rust_never_sleeps
Rust_never_sleeps's Avatar
The spacers I used on the '70 show the i.d. as 3.08".
15" steel wheels
1970 C10 Custom longbed 350/350
Rust_never_sleeps is offline   Reply With Quote
Old 03-29-2024, 12:54 PM   #11
Rocketir
Looks like 108.1mm was pretty standard in 1969.
https://www.wheel-size.com/size/chevrolet/c10/1969/
Rocketir is offline   Reply With Quote
Old 03-29-2024, 05:21 PM   #12
Rust_never_sleeps
I must be looking at something else then :shrug:
Old 03-29-2024, 08:14 PM   #13
dmjlambert
dmjlambert's Avatar
I've been watching this thread and now feel it's time to contribute conflicting information and generally add confusion, which is sometimes my specialty! We need some chaos!
I converted by 69 C10 to 71-72 5 lug. I went out to the garage with a ruler to measure the center hole on my old 6-lug wheels still sitting there and it is 3.5 inches. The 6-lug wheels fit into the hubs on the truck very well, hub centric mount. Luke87gt does this match what you actually have on your 69 C10 if you remove a wheel or hubcap and measure?
New 5-lug setup has 3 inch center hole.
I thought long and hard on my truck whether to stick with 6 lug or do 5 lug, and I've got to say I highly recommend 5 lug if disc brakes or new wheels are in the future. With 5 lug and C10 you can use all stock parts from 71 or later, and the only conversion thing you would need is rear axel shafts, which were inexpensive. And wheels are less expensive and easier to find and easier to just know they are compatible with disc brakes. Converting to 5 lug will also get you to change your rear bearing and seals, change the differential oil, and fix the broken pinion shaft lock bolt. Oh boy, more stuff to fix, even better.
I don't know what's up with the other measurements here in the thread, because I expect myself to be right, but maybe I'm wrong, who knows. I've been watching too much Visegrip Garage, I don't know.
dmjlambert is online now   Reply With Quote
