Old 03-30-2024, 03:24 PM   #1
Rusty trucker
generator alternator upgrade
I am upgrading my 61 235 to power steering and alternator with a bracket kit from Davis speed equipment and I'm trying to figure out what Alternator to use. I would like to use a make it easy and use a single wire alternator. What one would work best for me?
Rusty trucker is offline   Reply With Quote
Old 03-30-2024, 04:04 PM   #2
bhap
bhap's Avatar
Re: generator alternator upgrade
Take a look at MadElectrical.com - lots of good information there on wiring requirements, alternators and suggestions on how to setup. I went with a CS130 and used the "sense" wire to a terminal between the battery, the alternator and the 12v wire to the cab. Which alternator depends on what your loads are going to be. Have fun!
bhap is offline   Reply With Quote
Old 03-30-2024, 07:43 PM   #3
Rusty trucker
Thanks bhap, I do not have much of a load on the system. The rest of the truck is stock.
Old 04-01-2024, 11:56 AM   #4
forestb
forestb's Avatar
I have been really happy with Powermaster. They good because they actually charge at low RPM. I have heard other one wire alternators don't. You will need to bypass the voltage regulator.
forestb is offline   Reply With Quote
Old 04-13-2024, 04:34 PM   #5
Rusty trucker
Thank for the info. I knew I had to bypass the regulator.
bhap, did you order anything from the Mad electrical? I want to order the wiring harness they sell to convert to a three wire alternator. I have not had a chance to call, just wondering if they still open.
Old 04-13-2024, 07:30 PM   #6
bhap
bhap's Avatar
I did not buy from them. I ended up buying some Packard 56 terminals and modifying my existing harness. I added a fused buss bar where the regulator was and increased wire size to the battery and the cab.
