Old 03-17-2024, 11:23 AM   #76
yuccales
yuccales's Avatar
Re: Purchased a 1969 C10 Short Bed - Pleasanton, CA
Originally Posted by Luke87gt View Post
This is turning into quite the hassle. Thanks California!
Don't give up!
yuccales is offline   Reply With Quote
Old 03-17-2024, 03:07 PM   #77
Luke87gt
Did pick up a very nice set of 15x8 (4.0” BS) Rally wheels locally here today.
Now I need to find a set of 275/60/15 tires to go on em.
Luke87gt is offline   Reply With Quote
Old 03-17-2024, 04:23 PM   #78
Rust_never_sleeps
Rust_never_sleeps's Avatar
Originally Posted by zicc1835 View Post
I’m sure your board neighbors from Ca will chime in here I have purchased 3 trucks in the past from your state and the titles / registrations need to be current I can’t think of the name of the designation at the moment I suffer from CRS ….. or you go through the BS your going through now Good Luck with getting it done be patient with the AUTHORITIES Lord knows they have the authority
Perhaps you can register it as a non-running vehicle to get things up to date, then upgrade that when it's ready to roll.
You can also get "moving permits" from the DMV to make it legal to roll from shop to shop, but most folks don't bother.
At least the office in the mall is pretty quick and they've always been courteous there
1970 C10 Custom longbed 350/350
Rust_never_sleeps is offline   Reply With Quote
Old 03-17-2024, 04:50 PM   #79
Luke87gt
Huh? No bulb or wiring? Any ideas?
Old 03-17-2024, 05:56 PM   #80
Rust_never_sleeps
'69 has reflectors rather than actual lights from the factory.
.....or maybe an option depending on the package: https://67-72chevytrucks.com/vboard/...d.php?t=503138
Old 03-17-2024, 06:14 PM   #81
Luke87gt
Thank you for the confirmation
I was worried lol
Old 03-23-2024, 12:06 PM   #82
Luke87gt
I was able to get the truck registered yesterday and received plates.
After providing the vin verification form (which cost me $160), I went back to the dmv. I was anticipating that they were going to send me to the scales and I would need to figure out how to get the truck there when it isn’t running well.
When we got to that part (I was holding my breath), she asked me how much the truck weighed, I told her my estimate, she entered it into the computer, and she handed me plates/sticker.
Phew, dodged one there!
1969 C10 Shortbed
Wanted (pm me):
- Pair of 275/60/15 tires
Old 03-23-2024, 07:49 PM   #83
68bowtie
68bowtie's Avatar
Nice!!
I live in California, but identify as a Texan
"If a job's worth doing, it's worth doing well"
Survivor "Lil’ Mint" (67 c10 40k mile light green original paint)
Old 03-24-2024, 11:27 AM   #84
Luke87gt
Just for reference, annual weight registration fee:
0-2999lbs: $8
3000-4000lbs: $24
4001-5000lbs: $80
5001-6000lbs: $154
What a joke CA
1969 C10 Shortbed
Wanted (pm me):
Old 04-01-2024, 11:58 PM   #85
Luke87gt
I picked up a pair of 275/60/15 BFGs this weekend. Now I need to find a couple more and then I’ll get the truck rallys on.
Also, I’m going to try to get the i6 250 running well. But if I can’t, I will try to find a complete 350 or 396 from someone that moved on to an LS swap.
I’m wondering if you guys could steer me to what to look for, what to stay away from when it comes to stock take-off 350 or 396 engines? Any years more desirable than others? Any years that will be drop in replacement as opposed to others?
Thank you
1969 C10 Shortbed
Wanted (pm me):
Old 04-02-2024, 05:46 AM   #86
MikeB
MikeB's Avatar
About the oil. The industry went to multi-grade for a reason. Cold 30W oil is thick and moves slowly throughout the engine, not protecting parts as well as it should. I'd start with 10W-30, or 5W-30, but not straight 30W. Then if the oil pressure gets a little low when the engine is warmed up to 180-200F, jump up to 10W-40 at the next oil change to compensate for large clearances.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 04-02-2024, 05:56 AM   #87
MikeB
MikeB's Avatar
When I saw the condition of the floors, door jams, and doors, I knew I was going to make an offer…
My 69 doors didn't look that nice 35 years ago when I bought it! Rust was already at work on the bottom inside of the passenger's door. And both rocker panels had perforations.
Mike
Old 04-07-2024, 05:55 PM   #88
Luke87gt
So today I decide to take my 5yr old son out to help me change the oil in the C10.
Routine right? I’ve changed oil 100 times in my life on all kinds of makes/models.
Well, evidently the previous owner before me (or oil changers) decided to overtighten the hell out of the oil filter.
I put my oil filter wrench on the filter and instead of loosening, it just crushed the filter as I applied torque. Granted it was a cheap Fram filter which I’ve learned to never use because the casing is too thin. My life flashes before my eyes thinking of the hassle this could turn into. The more I try to loosen, the more the filter is crushing with the tool as it just slides against the filter.
I stare at it for 15min and come up with an idea… I put gritty sand paper between the oil filter tool and the oil filter along with a long pry bar. Thankfully it did the trick but badly bent the oil filter wrench.
When I took off the oil filter, I noticed that it came off because the threaded rod actually loosened from the engine. In 25yrs of wrenching, that was a first for me.
I put back and tightened the threaded rod as tight as I could get with with my fingers. Does anyone know the torque spec on the threaded oil filter rod? I need to torque that back down. Also, the size of the hex nut would be helpful to know too.
Next, once I drained the oil, I quickly noticed a very strong smell of gasoline in the oil. Can anyone provide any guidance as to what that could mean? I have been complaining that my garage smelled like fumes since I bought this truck but it got much stronger with the oil drain.
All is well, that could have turned into a massive hassle if the sandpaper trick didn’t work
I guess it’s all part of getting acquainted with a new classic
1969 C10 Shortbed
Wanted (pm me):
Old 04-07-2024, 06:17 PM   #89
54blackhornet
54blackhornet's Avatar
First thing I would do is replace that plastic filter with a metal version….
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 04-07-2024, 06:30 PM   #90
54blackhornet
The gasoline smell in the oil is from the carburetor is leaking internally, allowing unburned fuel to drain into the oil pan. Gasoline in the oil, if left to remain can and will wipeout engine bearings. You have a very nice pickup. I had one very similar but stupid me sold it. You will really enjoy how simple it is to work on…Jack
71 C-20
07 Magnum RT AWD
Old 04-07-2024, 06:32 PM   #91
Luke87gt
Here is a pic of the threaded bung that got loose as I loosened the oil filter.
Is there a seal there I need to replace? If someone can confirm the torque spec for that bung, that would help! Thanks
1969 C10 Shortbed
Wanted (pm me):
Old 04-12-2024, 06:13 PM   #92
Luke87gt
Well, my Jegs steering wheel arrived.
I love the look but can’t say I’m thrilled with the super cheap/hard plastic perimeter.
I’ll give it a shot but at $240, I’m really disappointed with the feel in your hand.
1969 C10 Shortbed
Wanted (pm me):
Old 04-12-2024, 08:10 PM   #93
Luke87gt
Duplicate
1969 C10 Shortbed
Wanted (pm me):
Old 04-12-2024, 10:33 PM   #94
pjmoreland
pjmoreland's Avatar
I installed one of those in my truck a year or two ago. It had a ridge of extra molded grip rubber sticking out around the perimeter that I wasn't too thrilled about. It has since worn off from use.
pjmoreland is online now   Reply With Quote
Old 04-13-2024, 03:49 PM   #95
Rust_never_sleeps
yeah, maybe go with the wood option for that style? IDHAFC what they cost though
Old 04-13-2024, 04:05 PM   #96
Luke87gt
I actually had wood and it was fine but thought black fit my truck better. Didn’t realize the perimeter would be so cheap.
1969 C10 Shortbed
Wanted (pm me):
Old 04-13-2024, 04:44 PM   #97
Steeveedee
Who Changed This?
Steeveedee's Avatar
The wood ones are about $300 from LMC. Mine split at a glue joint after a year. I'm looking for an old school leather wrap to cover that abomination.
~Steven
Simi Valley, CA
Old 04-13-2024, 04:54 PM   #98
68bowtie
68bowtie's Avatar
Any more pictures of the truck?
Old 04-13-2024, 10:02 PM   #99
Luke87gt
You know, I actually haven’t fired it up or had it out of the garage since the day it arrived. Here are a couple more pics. I promise I’ll take some proper pics once it’s running well enough to drive around the neighborhood confidently.
I did manage to get the oil filter on today and started draining the coolant in anticipation of the radiator arriving tomorrow.
Oh, and rear bumper arrived. Just need to find time to slowly make progress on these things.
1969 C10 Shortbed
Wanted (pm me):
Old 04-13-2024, 10:37 PM   #100
68bowtie
68bowtie's Avatar
Looks good!
