Old 03-31-2024, 09:07 PM   #1
General23cmp
Blazer suspension swap, 1977
I just purchased a 1971 K5 Blazer project, and the guy said he swapped the front and rear suspension with a 1977. I cannot see where anything was modified, but if I read correctly, this suspension/springs would not have bolted right in (maybe different length springs or widths…not sure). I cannot get back in touch with him easily. What options are there to do such a swap so I can get a better idea of what he did here? Would old springs bolt in, and then it be bolt in? Would perches have to be moved, and if so, which ones and which direction?
It looks factory as best I can tell, but I know it’s not. Thanks.
General23cmp is offline   Reply With Quote
Old 04-03-2024, 10:50 AM   #2
1rippen6
Re: Blazer suspension swap, 1977
Is it possible he just swapped axles and not the springs?
1rippen6 is offline   Reply With Quote
Old 04-03-2024, 11:29 AM   #3
best view
Pictures would help
best view is offline   Reply With Quote
Old 04-03-2024, 03:06 PM   #4
General23cmp
I was able to get in touch with him. He said he reused the 71 springs which makes sense on it looking untouched. Would the 77 axles have the spring mounts in the same location as 1971? He owned it for 30 years and said he didn’t recall changing anything except the staggered shock mount on the rear.
Old 04-03-2024, 03:17 PM   #5
1rippen6
I know the front is definitely the same width and I'm pretty sure if the rear came out of a blazer then it's the same also.
Old 04-04-2024, 01:44 PM   #6
A1971Blazer
A1971Blazer's Avatar
I put a GM 10 bolt front axle out of an '87 Suburban in my '70 Blazer...itbolted right in
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 04-04-2024, 01:47 PM   #7
General23cmp
Attachment 2348137
And which springs did you use? Have to use the 70’s?
Old 04-04-2024, 01:55 PM   #8
A1971Blazer
I actually used Tuff Country EZ-ride springs that are for 69-72 Blazer/K10 pickup
They are the same length as the factory springs.
1967 C10 Step side
1968 C10 Step side
Old 04-04-2024, 09:09 PM   #9
General23cmp
