Old 04-03-2024, 11:45 AM   #1
THI
Active Member
THI's Avatar
Re: Inline Tube brake line sets
I got a set from them for my 1978 C20 and it fit perfectly, as did the one for my 1977 Big 10 many years ago, and the set for my 1997 K2500 Suburban - have not installed the set on my 1978 K25 yet, but from past experience they will fit fine. I only once had an issue with lines from InLine Tube and that was a set of transmission lines for a 1996 Tahoe - they did not have the flaring to attached to the transmission, they sent me a new set right away!
There is a 9.5" semi-floater 14-bolt installed on later 3/4-ton trucks, but that should not make a difference in the axle lines, the brake drum size would.
THI is offline   Reply With Quote
