04-13-2024, 04:18 PM | #1 |
Tranny lines?
I have installed a 4L80e into my Squarebody pickup and i had also installed the factory style 4L80e hard lines running up to the radiator. Now i am going to installed the AC compressor (now a LS based engine) and the hard lines are right in the way of the low mount AC bracket (which is exactly where i want the AC compressor to stay). I have tried bending the hard tranny lines out of the way but they continue to rub against things and I don’t trust them, long term.
I have ZERO interest in moving the AC compressor. So my ? To you, whats the suggested soft line to run for tranny lines? PTFE? Or is there a strong version of a rubber type line I can run for my tranny lines?
http://67-72chevytrucks.com/vboard/s...d.php?t=791250 |
04-13-2024, 05:17 PM | #2 |
Re: Tranny lines?
Simple solution is to make some brackets to hold the lines out of the way where you want them. Strap iron is cheap.
04-13-2024, 09:24 PM | #3 |
Re: Tranny lines?
04-14-2024, 02:41 PM | #4 |
Re: Tranny lines?
I've seen just plain ol oil/gas resistant 3/8" rubber (gas line ) used forever
If your worried about it not holding up you could upgrade to the 3/8" rubber fuel Inj hose.. Or whatever size your tubes are..
04-14-2024, 04:53 PM | #5 |
Re: Tranny lines?
On my LS swaps I just use the typical rubber lined -6 SS braided lines. My 98 Wrangler with a LS6/4L60E combo has 15 years on it using it with zero issues.
I use Russell hose and hose ends. |
04-14-2024, 06:46 PM | #6 | |
Re: Tranny lines?
Thanks!
04-14-2024, 08:11 PM | #7 |
Re: Tranny lines?
Use whatever folks use to add an auxiliary trans cooler. I used some to connect a cooler/condenser to the output of my air compressor pump. It is labeled on the hose "Transmission Cooler Hose". Or places like Jegs/Summit may have assembled sets ready to go.
04-15-2024, 10:15 AM | #8 |
Re: Tranny lines?
I like that!
