Old 09-30-2004, 08:14 PM   #1
70c10
67-72 Addict!
70c10's Avatar
Arrow Need help identifying fuel sending unit
This is the old sending unit I pulled tonight from my dad's 70'. I bought a new one last year and installed it tonight but the metal line coming out of the top of the new unit is a little larger in diameter, comes out of the top where I'm pointing and the nut is bigger (3/4" compared to 9/16") and also longer. The new box is marked 67-71 8 cylinder. Could my original unit have been for a 6 cylinder?. If anybody knows the differences in sending units, I would appreciate any help!. Thanks
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 09-30-2004, 08:19 PM   #2
68 Stepside
huh?
68 Stepside's Avatar
It's very possible that your original sender was for a 6 cylinder. The 6 cylinder fuel sender lines are smaller than the V8 lines. Is the truck an original V8?
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 09-30-2004, 08:24 PM   #3
70c10
67-72 Addict!
70c10's Avatar
I don't know if it was originally a 6 cylinder truck but if you are sure about the size it probably was!. DAMN!. Is there any way to make this work?. Maybe I can buy some steel tubing and work from the sending unit back to the fuel pump with this new size line?. I guess it would be easier to buy the 6 cylinder unit,huh?
Jim
Old 10-01-2004, 01:57 AM   #4
longhorn71
longhorn71's Avatar
If Your Vin Starts With Ce..it Is A V-8 If It Starts With Cs... It Was A 6 Powerd Truck
longhorn71 is offline   Reply With Quote
Old 10-01-2004, 02:28 AM   #5
687980chevy
687980chevy's Avatar
Other differences in senders I6 vs V8
Is there any other difference beside the tube size? My truck had a V8 in it when I bought it.It was a 292 I-6.The reason I ask is because it's hard to start if it sits awhile(2-3 days). I was wondering if the pickup tube might be higher or lower on a V8?
68 K-10,79 K-10,80 C-30
57 chevy convertible
79 Z28
687980chevy is offline   Reply With Quote
Old 10-01-2004, 07:16 AM   #6
70c10
67-72 Addict!
70c10's Avatar
longhorn71, my vin on my truck starts with CE and I have the same sending unit as pictured. I think I might go to the junkyard and see if I can get this piece of line from the same setup, otherwise I might bend a piece of tubing and find a fitting to work.
Jim
Old 10-01-2004, 02:24 PM   #7
shadetree
shadetree's Avatar
Some trucks with the smaller v8's also used the smaller fuel lines. 70, you should be able to buy an adaptor, that reduces from one line size to another. The style of fitting used is SAE double flare, and fittings are available at all parts stores. The use of an adaptor should get your truck going, but the best solution would be to buy steel line, and bend up a new line (it's easier than you might think).
1970 long fleet, 355 4 speed, primer, walnut goodies
shadetree is offline   Reply With Quote
Old 10-01-2004, 05:08 PM   #8
pickupman
pickupman's Avatar
Jim, If your V8 had a 2bl on it originally it also took the 5/16 line and the 4 bl carbs took the 3/8 line.
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Old 10-01-2004, 05:25 PM   #9
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
You should be able to buy a reducer from the hardware store to make the new one work. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 10-02-2004, 07:32 AM   #10
70c10
67-72 Addict!
70c10's Avatar
Thanks Bill. Wes, the problem with the reducer idea is the two ends don't line up due to the new sending unit's tube location. It comes out of the top about 1/2" higher and can't be bent or I will damage the unit.
Jim
