Old 08-17-2008, 01:46 PM   #226
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: PROJECT "Father/Son" C-20 Rolling Chassis Build
Oh, what was the powdercoat finish called?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 08-17-2008, 02:02 PM   #227
rcrahn
rcrahn's Avatar
The frame is powdercoating is called silver vein. It cost a bit more because a clear coat is required. I dig the industrial look it has, that's why I went with it. That and it is differnt than your everyday black.
rcrahn is offline   Reply With Quote
Old 08-17-2008, 02:34 PM   #228
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Originally Posted by thirdstreettito View Post
Nice! I love 8-lugged and slammed! Gorgeous!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 08-17-2008, 03:54 PM   #229
thirdstreettito
Resident of Here
Thanks and good luck for the rest of it!
~Bradley~
Miss having a truck
Old 09-05-2008, 12:43 AM   #230
64c20crewcab
64c20crewcab's Avatar
Wow I finally got a chance to view this complete build thread.
John - AWSOME workmanship and detailed info & pics There is no doubt that this C20 is gonna be a Bad Mo Fo when completed. Looking at this C20 gives me hope on my rig. I wanna lower it via bags and notch but not lay frame as well. Will use the the same technique when swapping my Eaton to late model 14 ff rearend swap later this year. Thanks for your work of sharing this build info!!
Rich - I see you converted to 8-lug disc prior to Johns work. Did you buy a "kit" or use stock later model spindles or aftermarket drop? I have disc on my Eaton rear end now and will trfr this to the recently aquired 14 bolt later. Before I do, I need to convert the front end brakes asap. I'd appreciate any info you could share.
Awsome build thread this is!!
Thanks!!
Norm
..............................._________
......___________//___[[___{\ _____
...../__(_(O)_)___/____/____/_(O)_/
1964 C20 Long Stepside 3 Door Crew Cab
- Armbruster-Stageway Conversion
Y2K INDN Chief
"ONE OF A KIND, NOT ONE OF THE CROWD"
Aug 2010 - Front end frame cleanup & engine swap done!!!
June 2011 - Rear end bagged
Sept 2011 - Rebuild motor top end
Sept 2012 - Parked and slowly working on it.
Aug 2013 - Front end bagged - finally!
Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas...
Here is my build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=335427
64c20crewcab is offline   Reply With Quote
Old 09-05-2008, 09:30 AM   #231
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Thanks!!
Norm
Thanks for the nice words Norm...Rich used a dropped spindles kit with disc conversion....so, yeah an aftermarket set-up.
I know the rear used front 3/4 rotors and calipers...with the mount from Balistic.
All my work is like that...well thought out, clean, and perfectionist style....
Later
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 09-05-2008, 11:57 AM   #232
64c20crewcab
Any idea as to details of what aftermarket front end stuff he used. Aftermarket C20 3/4 ton stuff is pretty rare - at least is what I been seeing. CPP is the only one I've seen.
MUCH THANKS!
Y2K INDN Chief
Old 09-06-2008, 09:36 PM   #233
rcrahn
rcrahn's Avatar
Hello Norm,
Thanks for the nice words about our truck. This is a father son project (with John's capable help) and thus far we are pleased.
Now, about the drop spindles. Early on when Justin started to work on this truck he started by getting these 8 lug drop spindles. I checked with him about where they came from. He said there is one company in S. CA that basically makes all the drop spindles (5 lug, 6 lug & 8 lug) sold by the various suppliers. He couldn't recall the name. But there were issues with getting the fit right, especially on the spindle shaft. He went through 2-3 sets before things were finally right. That was 2 years ago.
As far as what is out there today I believe that you can get an 8 lug drop spindle/ disc brake kit from Brothers and also performance parts.
Google "8 lug drop spindles".
Good luck,
Rich
PS: We normally use a place in San Jose called Power Brake Exchange for all our brake components. For example, the rotors and calipers we used on the 14 bolt (see thread pics) rear came from Power Brake Exchange. Cost $250. I do know those components came from a company named Centric, which is located in Industry, CA.
Old 09-07-2008, 01:03 PM   #234
64c20crewcab
Rich Thanks for the info. Since I'm located in SoCal - Brothers, CPP, Truck Shop & Classic Industries are all within a 1 hr drive. Will check to see whats available. I picked up my 14 bolt rear disc brake kit (which can be used on the Eaton) on ebay nearly 2 yrs ago. Could not find drums nor eaton conversion kit. But that thanks for the info.
I'm sure others here will be inspired by this build as I have. Too KEWL!
Y2K INDN Chief
Old 09-07-2008, 05:31 PM   #235
watahyahknow
watahyahknow's Avatar
how could i've missed this tread for so long , i like it a lot aspecially the watts linksetup .
i was planning on doing a dually the same way with a rockcrawler diffcover and all
now i can show pics of wat i meant making explaining a lot eazier
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 09-10-2008, 07:12 AM   #236
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Originally Posted by watahyahknow View Post
how could i've missed this tread for so long , i like it a lot aspecially the watts linksetup.....
Thanks bro...
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 09-10-2008, 06:48 PM   #237
rcrahn
rcrahn's Avatar
Alert the media, the bed has been cut. Repeat, the bed is cut!!!!
Now let's see the whole truck
How about that tailgate. WOW! Chief does great work!
Nice looking underneath
More overall pics
Building a custom notched, bagged, shaved 67 Chevy LWB Fleetside 3/4 ton 8 lug with 14 bolt, custom watts link and Gen III engine - $$$$$$ Building it with your son - Priceless!
Old 09-11-2008, 09:17 AM   #238
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
SWEEEEEEETTTTT!!!!!
Man that thing is coming along nice....
Building with your son...definately PRICELESS !!!
So far, we (my son & I) have a modified 24volt POWER WHEELS !!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 01-23-2009, 10:22 AM   #239
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
What's up guys....Thought we'd bring this topic back up from the dead.
Two weeks ago, Mr Rahn called me and asked if I'd like to go on a road-trip to pick up an engine and tranny for the project. I said sure lets do it.
We set off to Pomona last Saturday morning (10hr round trip) to fetch this bad boy. It just so happened that that weekend was the Pomona Swap Meet, which is said to be the largest/baddest show/swap there is in Cali...and it was !!
Here are a few (and I mean a few) of the cool rides we seen out there:
We arrived way before the sun, at 3:30 in the morning:
After these people moved...we got a shot of this nice 64
There were a lot of good deals to be found...like these all leather SUV rear seats..perfect for an old truck cab..(just don't ask where they came from)...this guy was best buddies with "Steve the Repo Man"
This was and still is my favorite ride...I have own like 3 in the past...I sure miss them all...64 Impala 9-pass wagon:
Not sure what Rahn was looking at...mabey the group of men....I do see the 10ply tires I should of bought with wheels...for my SuperDuty..mounted on alum wheels for $300...My current tires are balder than me !!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 01-23-2009, 10:24 AM   #240
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
This had to be one of the cleanest old Burbans I have seen:
Here, Mr Rahn is tired, but still all smiles as we are leaving the swap and headed to pick up the engine/tranny. We must of walked at least 5-8 miles that day.
This truck was SICK !!!!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 01-23-2009, 10:25 AM   #241
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Now at least this pile was named correctly:
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 01-23-2009, 10:26 AM   #242
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I think Rich was actually trying to get a pic of the truck on the trailer...
Here it is the 2003 ESCALADE LQ9 and 4l80E transmission...low-mileage, and super clean !! Which picked this up for a SUPER DEAL...from a nice fellow named "Steve......Steve the REPO MAN !!!"
Complete with uncut harness, fly-by-wire pedal, air-box, ECM, rear O2's, etc...
And me, tired as heck, gave Rich a break from driving and actually drove the speed limit to get us home fast !
This will be the next chapter in the "Father Son Build"
MORE PROGRESS SOON !!!!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 01-24-2009, 05:23 PM   #243
rcrahn
rcrahn's Avatar
Thanks John for posting this....
The trip went great. The swapmeet was a blast but the real excitment was picking up this....LQ9/4L80E
Old 01-26-2009, 12:30 AM   #244
project 67 sub
project 67 sub's Avatar
i was their on sunday. i saw that cab and front clip on the flat bed when it was leaving the guy passed right by me. guy only wanted like $600
project 67 sub is offline   Reply With Quote
Old 01-26-2009, 03:44 PM   #245
440chevy
did i just get hit with deja vue?
440chevy is offline   Reply With Quote
Old 01-28-2009, 06:10 AM   #246
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Here are 80 more pics Rich...thought I has lost my phone, but I found it...here you go !!!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 01-28-2009, 06:12 AM   #247
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Rich was tired by the end of the show....he wouldn't even give the VW's any love...he just sped right through them...all he could think of was the LQ9....
Here's what a stock 69 Vette should look like...man it has been a long time....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 01-28-2009, 06:14 AM   #248
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 01-28-2009, 06:15 AM   #249
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
They wanted a crap-load for this 58 rusted out vert....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 01-28-2009, 06:16 AM   #250
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
