Old 10-14-2013, 04:20 PM   #226
Fastest32
Fastest32's Avatar
Re: Post Pics of your Static Drops!!
Originally Posted by Ospguy View Post
Z'd front and rear suspension plus a 3 " spring drop on rear. Lot's of work but full suspension travel and drives like a new truck.......
So beautiful.
BaBaBooey BaBaBooey
GO SPURS GO!!!
Fastest32 is offline   Reply With Quote
Old 10-14-2013, 04:22 PM   #227
forestb
forestb's Avatar
Awesome truck. what is that on the tailgate and can we get a closer photo of it?
forestb is offline   Reply With Quote
Old 10-14-2013, 04:32 PM   #228
Ospguy
The bed is boxed in - solid tail piece (no tailgate). The panels are aluminum that I had machined to match the fins on an M/T Valve Cover. Panels are recessed into the tail piece. I'll see If I have a better pic and will post.
Ospguy is offline   Reply With Quote
Old 10-14-2013, 04:57 PM   #229
Ospguy
Few more pics.
Old 10-14-2013, 09:25 PM   #230
TxRat
TxRat's Avatar
4-6 drop
TxRat is offline   Reply With Quote
Old 10-14-2013, 11:46 PM   #231
Fastest32
Fastest32's Avatar
Originally Posted by TxRat View Post
4-6 drop
Sweet.
BaBaBooey BaBaBooey
GO SPURS GO!!!
Old 10-15-2013, 04:57 PM   #232
familyfast64
familyfast64's Avatar
Wink Re: Post Pics of your Static Drops!!
I'm posting again, at least I think I already posted, because I've learned more about what is actually under it since the trade...
Drop spindles -2.5" cheap single piston...I think 75 mm, stops alright tho.
Drop springs? Still unsure but the front cross member is only about 3.5-4 inches from the ground.
9" ford rear end with leaf springs under Axel tubes
Air shocks with the upper mount relocated(not enough imo)
There's prolly 2"-3.5" depending on psi in air shock between Axle tube and frame. Also the same distance between to of rear end housing and floor. If the shocks are empty or low it'll bottom out but it does good when there's a lil psi added. She does lean to the back passenger side a lil, I'm assuming it's just worn leaf springs..?..
Anyway, I want to get seat belts, then some good sway bars for sure.
Live and let live
familyfast64 is offline   Reply With Quote
Old 10-15-2013, 07:00 PM   #233
C/10 King
C/10 King's Avatar
7/8
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 10-24-2013, 01:54 PM   #234
AllenKarber
Sharp truck my man!!
This whole thread is full of them!
AllenKarber is offline   Reply With Quote
Old 10-25-2013, 04:13 AM   #235
19666Trucker
19666Trucker's Avatar
1.5 cut coils in the front, cut .5 in the back with 2" blocks 1966 c20 custom camper daily driver.
19666Trucker is offline   Reply With Quote
Old 02-01-2014, 12:22 PM   #236
Desert.Chevy
Desert.Chevy's Avatar
4-6 drop
Good Looking Truck.
How did you drop it 4/6, parts or cut?
What size tires do you have?
Desert.Chevy is offline   Reply With Quote
Old 11-22-2014, 12:49 AM   #237
endlessearth
endlessearth's Avatar
Finally got that low and level look that I was seeking.
endlessearth is offline   Reply With Quote
Old 11-26-2014, 12:43 PM   #238
endlessearth
And again...but now with smaller diameter tires.
Old 11-27-2014, 02:18 AM   #239
endlessearth
Still working it...
Old 11-27-2014, 09:32 AM   #240
60-66
60-66's Avatar
Originally Posted by endlessearth View Post
Still working it...
Really starting to like the lowered longbed look, Very nice truck there Endlessearth , love your style !
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 11-27-2014, 12:01 PM   #241
endlessearth
Thanks man! I think that a long bed that has been lowered and has a very flat stance (with little or no rake) is a pretty cool look.
Old 12-14-2014, 12:34 PM   #242
of13swc
Beautiful truck. Awesome job.
Originally Posted by DaddyMack View Post
Mine is torsion bars...
2.5 inch drop spindles in front and 5"drop coils in rear. that's all.. no frame cutting or anything...
of13swc is offline   Reply With Quote
Old 12-15-2014, 08:27 PM   #243
carp1329
carp1329's Avatar
64 with spindles and 1" springs in front 5" springs in back.Tires are 235/75/15 on van rallies and truck rallies in the first picture.
carp1329 is offline   Reply With Quote
Old 12-16-2014, 10:14 PM   #244
rusty1962
rusty1962's Avatar
My 62. when I bought it it had the torsion bars cranked all of the way out and heated springs in the rear. 2nd pic is matching set of tires still same height, 3rd picture is with 2 1/2 inch Western Suspension Drop Spindles, 10 rounds back in the Torsion bars, Same heated springs rear with 18x8 with 235/50/18 on the front and 18x 9 1/2 255/55/18 on the rear.
rusty1962 is offline   Reply With Quote
Old 12-16-2014, 10:37 PM   #245
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
It's amazing how much wheels make all the difference.
66 C20 Service Truck:
Old 12-18-2014, 05:46 PM   #246
Monte's62
rusty1962, man you got it right in that 3rd pic. The stance looks good and as mentioned, those wheels make a difference.
Monte's62 is offline   Reply With Quote
Old 12-18-2014, 06:02 PM   #247
rusty1962
rusty1962's Avatar
Thanks, Lot of work already done you can't see but Still Long way to Go!!!
Old 12-18-2014, 06:43 PM   #248
endlessearth
I like that last truck with the moon discs on it. I guess I am partial to those.
Old 12-19-2014, 09:05 PM   #249
contagious102
contagious102's Avatar
Just finished mine in July. Some where around 6" in the front, 6' to 8" in the rear. 540ci big block.
Go Fast and Have Fun.!!
My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185
contagious102 is offline   Reply With Quote
Old 12-19-2014, 09:19 PM   #250
endlessearth
Bad ass!
