01-07-2010, 10:59 AM | #226 |
Rods
Re: 66 frame off resto-mod
Will do
Just keepin it simple. 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
01-07-2010, 11:02 AM | #227 |
Rods
And by the way great job on the air box i may do some of the same on mine but try to make it a little more low profile
01-18-2010, 12:27 AM | #228 |
Well, the day finally came, I drove my truck for the first time in months! Granted it was only up to the exhaust shop, but it got there under its own power. Lots of little things to finish up and one big one (the bed), but I see the light at the end of the tunnel.
01-19-2010, 12:47 PM | #229 | |
More pictures please? BTW, what was finally decided upon for wheels? I just re-read your entire thread and you mention consierding using the slots but that stick on weights hit the brake calipers when mounted in back. How wuill you address that, or are you changing to another wheel? With your stock color I Vote (as if it matters!) for nice deep Rally wheels. I think they'd look great on your truck. Either that or old fashioned gray centered Torque THrusts, not the full polished ones. Can we see those pix, can we, huh, huh, huh? |
01-19-2010, 01:12 PM | #230 | |
I hope to get some more pics this weekend when I go out to RRC. |
01-30-2010, 10:21 PM | #231 |
Here are some more pics as requested:-)
01-30-2010, 10:33 PM | #232 |
Member of the longbed union.
Looks good Tom.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
01-30-2010, 11:28 PM | #233 |
Slots go on anything!
Looks good, Tom. I vote polish those wheels and run them.
1974 Jimmy- 5.3/4L80e/NP241 |
01-31-2010, 10:20 AM | #234 |
Working on the Turn signals, can anyone identify the 2 "hot" wires in the below pic? The color codes are not even close to the diagram...
I must have a replacement switch or the wire have faded in a strange way! Problem is, it was take apart so long ago, and that they don't have the old harness or anything to ID them! Little advice, take a LOT of photos when you are taking things apart... |
01-31-2010, 10:24 AM | #235 |
Oh and one more Pic (thank you Goatnut for helping with a patch panel)!
Before: After: |
02-01-2010, 12:21 PM | #236 |
Looking good Tom. I'm happy to have helped with the panel!
Scott
1947 Art Deco Chevy truck 1964 C20 Custom cab 1965 Tempest Wagon 1967 GTO 1972 Luxury Lemans http://www.cardomain.com/id/a67goatnut |
02-12-2010, 05:35 PM | #237 |
1965 Chevy C10, 2005 4.8L/4l60
What did you ever do with the AC, did you use a sanden or the stock 5.3l compressor? How bout that air box? I didnt know someone else was doing that. Too cool!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
02-13-2010, 02:04 AM | #238 |
We used the stock compressor and the old heater box for the Air Box. I will be going out to hopefully pick up my truck tomorrow so I should be able to post more picks once it is in my garage!
02-24-2010, 10:11 AM | #239 |
Well, I got my truck back and I am in the debugging phase. The check engine light is on because of a 315 code (Crankshaft variation not learned), and I had a MAF issue that was solved with a another new ECM. I have to thank Current Performance as they have been great to work with and they truly stand by their service!
Other issues include some various coolant leaks from the radiator core (fixed with a new radiator) and the drivers head steam vent (still have to get to that one). I had a speedometer issue where it could not read from the ECM output but that is fixed by tapping into the VSS sensor directly (I could do this as Speedhut gauges present a 100K ohm load on the input vs an Autometer speedo that presents a 10 ohm load and would cause shifting issues) Other things I know I have to do include color sanding and buffing, wood bed finish and install (temp plywood is in), verify fuel pressure, and setup a better fuel filter setup. I figure the list will get longer, but at least my truck is running and driving! |
03-17-2010, 08:08 AM | #240 | |
05-05-2010, 08:19 PM | #241 |
05-05-2010, 09:50 PM | #242 |
Thanks Tom. It looks great! Bet you are so happy to be driving it!
Appreciate you sharing the build. |
05-05-2010, 10:12 PM | #243 |
05-06-2010, 12:39 AM | #244 |
60-66 Nut
Yes that turned out very nice
Are you getting good mpg with the truck?
05-06-2010, 08:46 AM | #245 |
05-06-2010, 11:20 AM | #246 |
Wide Eyed User
Great looking truck!! My 350 gives me 14 mpg... I thought that was good...lol
1962 Chevy P/U SB Fleetside 350/350 2.5/5 static drop My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723 Final (as final can be ) Pics: http://67-72chevytrucks.com/vboard/s...d.php?t=393441 |
05-07-2010, 02:50 PM | #247 |
Love the green, wheels are just right. good gas mileage.
"I feel the need for speed!"... as soon as I am done with my nap. |
05-08-2010, 10:39 PM | #248 |
Really cool build! but it makes me worry when I take my paint and body off. Your truck came out super cool!
05-09-2010, 02:52 PM | #249 |
Hey Y'all!!
That's a nice looking truck Tom. Glad it all came together for you.
Just hopin' I live long enough to finish something!!! |
05-09-2010, 03:37 PM | #250 |
US Army Veteran
Amazing truck, Tom! Really enjoyed the build thread!
1972 C10 Highlander - The making of a daily driver |
