Old 08-05-2010, 11:03 PM   #226
mcbassin
Still Learning
mcbassin's Avatar
Re: 86 Silverado Father and Son project
Originally Posted by Jonboy View Post
Looks great, Mike.
Thanks!
Originally Posted by 1972SuperCheyenne View Post
Looks great man. I wish I knew where I could get me a nice set of drop shackles like those!
Thanks! sorry, I had to jump on those shackles.
Originally Posted by SIC-K5 View Post
WOW. i just read through this whole thread. i cant believe the outcome. looks great.
Thanks! It has been a long journey! still working on it.
Originally Posted by scotts62 View Post
Wow I haven't checked in in a while, looks awesome and nice work guys!!!!!
Thanks Scott.
Originally Posted by DBLSPRT68 View Post
I agree!!!!!
Thanks!
mcbassin is offline   Reply With Quote
Old 08-05-2010, 11:12 PM   #227
mcbassin
Still Learning
mcbassin's Avatar
Update:
I purchased a pretty much complete interior from guy on Craigs. It is in really good shape. The carpet is new and the door panels, and seat are really nice. Unfortunately, there wasn't a dash pad. We will get some pictures as soon as we get it installed (just a pile of parts now).
Also,I scored an electronic speedo cluster from RandyP. (thanks!)now I'm trying to make it work with the oem harness and it's not working out too good. For some reason GM changed the flex on the back and basically none of the gages work.
Old 08-06-2010, 09:11 AM   #228
Jonboy
Slots go on anything!
Look at the wiring diagram on the Autozone website for a 91 Suburban. You will just have to move the wires in the connector around a little bit, but most of them will work. I ran a wire directly to the output on the PCM to the speedometer. Just use the end of one of the wires that you dont use and lengthen it to go to the PCM. The colors will correspond to the later pinout, they are just in different locations.
Here is the diagram: http://www.autozone.com/autozone/rep...00c1528008f3ce
I know I printed these, and I also had the factory wiring diagram for my '79 (thanks, ebay!). I did get the connector and about 6" of wire when I got my cluster, so that made it a lot easier. I was looking over that diagram, and I don't see the VSS output wire in the schematic. I know there are some diagrams on www.73-87chevytrucks.com also. All of my stuff is in storage, so it will be a little bit before I could dig it out to see the notes I made.
1974 Jimmy- 5.3/4L80e/NP241
Old 08-06-2010, 09:35 AM   #229
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
I got your PM, and I'm sending you an email with the pinouts for the electric cluster and some other info.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 08-06-2010, 09:54 AM   #230
glock35ipsc
That is weird. I was looking them over too, and even selected a few different ones, and none of them even came close to how my electric cluster was actually set up.
Best bet, when in doubt, is to follow each circuit from the gauge to the connection and note what goes where.
Bob
Old 08-06-2010, 10:08 AM   #231
RandyP
Getting Old; Going Broke
RandyP's Avatar
I should have cut the connector off when I yanked that cluster.
I don't even remember how/where the VSS was attached on that thing. I just remember getting it out and going "wow, this is different" and buying it anyway.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 08-06-2010, 11:43 AM   #232
Jonboy
There is a DRAC module that went under the radio originally in the truck. I am pretty sure the buffer is in the ECM, as I wired mine directly to the ECM without any trouble.
Old 08-06-2010, 12:16 PM   #233
mcbassin
Still Learning
mcbassin's Avatar
Did you use the brown wire A10 or B3? on yours
Old 08-06-2010, 12:58 PM   #234
Jonboy
I really don't remember. I did mine about 8 months ago, and the first cluster I had, the speedometer didn't work. I went back and rechecked everything, and it still didn't work. The odometer worked, but no speedo. The funny thing is, I swapped that cluster for one that the speedo worked, and the odometer did not. I figured that was the lesser of two evils. Mine also had an LT1 in it, so the PCM is different. I found the VSS output wire in the PCM, and wired it directly to that.
Old 08-07-2010, 11:32 AM   #235
mcbassin
Still Learning
mcbassin's Avatar
I hooked A10 up to the speedo and it didn't work. I wonder if the speedo is bad or I connected the wrong wire?
HERE is the diagram I used for the ecm.
Old 08-08-2010, 06:01 PM   #236
mcbassin
Still Learning
mcbassin's Avatar
Well it has been a busy week. Got quite a bit done on the truck. We gutted the interior to prep it for paint and the new to us interior. Still working on the speedo issue.
here are the pics:
Got all the interior removed:
Lots of junky parts:
Prepped the headliner for new material and used Elmers wood glue. We tried
THIS but it just fell back down. I used the wood glue back in the day and it worked great so I went back with it.
Turned out really good:
Painted the interior:
Old 08-08-2010, 07:22 PM   #237
joe231
joe231's Avatar
Nice!
CHEVY ONLY
Old 08-08-2010, 10:07 PM   #238
mcbassin
Still Learning
mcbassin's Avatar
Originally Posted by joe231 View Post
Nice!
Thanks Joe!
I got everything but the dash installed on the inside, this is a lot more time consuming than it is taking it out. Also, I scored a nice rear bumper at Pull a Part today. Here are the pics:
Headliner installed:
Carpet, seat and everything else:
Like the new door panels:
New bumper:
Old 08-08-2010, 10:28 PM   #239
joe231
joe231's Avatar
Wow Mike!
Quite a transformation!!
Nice score on the bumper, what did it cost from pull-a-part?
I need to pick up a new front and rear bumper...
CHEVY ONLY
Old 08-08-2010, 10:54 PM   #240
mcbassin
Still Learning
mcbassin's Avatar
Wow Mike!
Thanks Joe for the props! The bumper was $30 with the brackets and bolts. I also got a few trim pieces, pass. kick panel with the vent assy., a pillar cover, DRAC module and two windshield trim pesces for the grand am and I spent a little over $55 total.
Old 08-08-2010, 10:59 PM   #241
joe231
joe231's Avatar
I love that place, as long as you can get to the good stuff before the jackasses tear everything up.
CHEVY ONLY
Old 08-08-2010, 11:12 PM   #242
mcbassin
Still Learning
mcbassin's Avatar
You got that right! I think they had just added a few trucks this week. I saw some stuff out there I would love to have for other projects. I have got to this one done so I can move on to the 69. Just need to rework the dash or buy a cover. New windshield, tag, fix the a/c again, and few odds and ends.........hopefully, by thursday.
Old 08-09-2010, 07:54 AM   #243
my67chevytruck
Under Construction
my67chevytruck's Avatar
Very nice progress Mike!, truck looks awesome, I know your son has a perma-smile
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 08-09-2010, 10:29 AM   #244
scotts62
One day...
scotts62's Avatar
Very nice
Scott
93 crew cab build
Project 62
Old 08-11-2010, 12:29 PM   #245
nuke1
nuke1's Avatar
Truck looks jsut amazing Mike. You have to be proud of what you have accomplished so far, just a little bit more and on to the next one! and yes it needs to some down just a little bit more now.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 08-11-2010, 01:07 PM   #246
0331grunt
Now what??
0331grunt's Avatar
Truck looks great! Bet that boy of yours is excited!!
69 Long Fleet - Project
06 Ram 1ton Cummins 4x4-DD
01 Tahoe- wifes
"The quality of a persons life is in direct proportion to their commitment to excellence, regardless of their chosen field of endeavor." ~ Vince Lombardi
"A dream doesn't become reality through magic, it takes sweat, determination and hard work." ~ Colin Powell
my, um, build
USMC OIF Veteran SEMPER FI!
0331grunt is offline   Reply With Quote
Old 08-11-2010, 01:42 PM   #247
mcbassin
Still Learning
mcbassin's Avatar
Thanks Heath! He is pretty excited, I just dropped the cash to get it tagged and insured. So now he can legally drive it.
Very nice
Thanks Scott!
Thanks James! Yep, I think 2.5 up front and 2 more in the back.
Thanks! Yes, he is pretty pumped!
Old 08-12-2010, 03:02 PM   #248
grayharville
^^who I am^^ what I say>
grayharville's Avatar
Nice truck,now it looks like all it needs is a trip to the exhaust shop! can you give more detail about recovering the headliner? I want to cover mine with a confederate flag, but not too sure how.
70 chevy LWB 350/TH350 Barn find (AKA the 70)
http://www.67-72chevytrucks.com/vboa...d.php?t=406364
East Tx Squares
grayharville is offline   Reply With Quote
Old 08-12-2010, 04:14 PM   #249
mcbassin
Still Learning
mcbassin's Avatar
Thanks and Yep, we are more than likely going to cut off the big chrome tips for now and put some tips that turn it down where they can't be seen. The future plan is flowmasters on both sides.
As far as the headliner goes. It's a pain in the tail but definetly doable. The main thing we had to do, get off all that nasty foam backing. You won't get anything to glue to that crap. You can scrape it off with a piece of cardboard or similar. The one in his truck is the fiberglass type. So the first night I put a liberal coating of the wood glue over the whole surface. Then let it dry overnight. This will seal the glass and give a good surface to glue to.
next day we glued the headliner on and worked it down flat. Keep in mind to give it slack as you lay the material, so not to stretch it. It seems to pull away from the backer if it stretched. Then just cut out for light and visors with a razor. I used a soldering iron to burn holes for the screws. It takes a few hours but worth it. Not sure how much a new one cost but we spen about $15 in material and $6 on glue. Good luck!
Old 08-12-2010, 04:49 PM   #250
scotts62
One day...
scotts62's Avatar
They are around $65 to get one covered, thats from Truman fabric off i-44.
I bought my stuff from them and got a roller from Lowes and as i sprayed it rolled it smooth, seems to be holding up through all this heat we have had here lately so i must have done something right
Scott
93 crew cab build
Project 62
