Old 05-15-2012, 12:39 AM   #226
maxxxy
maxxxy's Avatar
Re: maxxy's 81 bagged c10 build
Well as of yesterday, Dunday May 13, 2012, I am a high school graduate!!!
Now I don't have anything getting in the way of me and my truck! (until I have to get a summer job to pay for it lol)
Well I haven't got much done recently, but I've started accumulating some minor parts and painting up some new ones and sandblasting and painting some old ones.
First here's a picture of my new rotors made for a 91 camaro 1LE performance package. Same measurements all around and uses the same bearings. Only difference would be the 5x4.75 bolt pattern, which opens up my wheel choices. Here they are after I painted them.
I'm getting adapters for the rear. Any suggestions on where to get them?
I also painted up my oil pan and some interior parts, then I painted, then baked on the paint on my exhaust manifolds. Heres a before and after. Now they're both done.
Word of advice, don't use your moms oven to heat cure exhaust paint. It turns out it makes them very, very unhappy. Lol
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 05-18-2012, 02:54 AM   #227
texastruckjunky
texastruckjunky's Avatar
I just got done reading your entire build, Your welding has improved 100%, good job there. And your truck is coming out awsome, can't wait to see it on the road. You will deffently enjoy it more cause you built it yourself, there is always more pride in that. Keep up the good work i'm really enjoying your build.
Life is to short to drive anything else
texastruckjunky is offline   Reply With Quote
Old 05-20-2012, 05:43 PM   #228
kev2809
low n' slo
kev2809's Avatar
nice build!
hey, i wanted to ask you about those manifolds your running on the motor...do you have driver side dipstick?
i have those same manifolds on mine, but they pinch the crap out of the dipstick tube and i cant even get it back in. wondering what your using...thanks
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 05-23-2012, 12:42 AM   #229
maxxxy
maxxxy's Avatar
Thanks Texas truck junky! I really appreciate the praise.
Kev2809: I'm still assembling my engine and I don't even have a dipstick tube yet. But have you thought about the braided flex dipstick tubes like you can get for a transmission?
I got my newly painted front suspension almost all reassembled minus a few little things. *I got new upper control arm bushings and all new upper an lower ball joints. Then I got my new camaro 1LE rotors installed.
Here's the reason I swapped to the camaro rotors.*
My buddy and I worked out a deal and I ended up with these: d'vinci Lox 22x9 rims with pretty good *265/35/22 tires. They're about 29"tall. Which is an inch or so taller. I need to do a little inner fender trimming which I expected. * *After that I should be able to drop another 5-6".
Max
Max's bagged 81
Old 05-23-2012, 12:56 AM   #230
grayharville
^^who I am^^ what I say>
grayharville's Avatar
Looking badass man! It sure has come a long way
70 chevy LWB 350/TH350 Barn find (AKA the 70)
http://www.67-72chevytrucks.com/vboa...d.php?t=406364
East Tx Squares
grayharville is offline   Reply With Quote
Old 05-23-2012, 03:08 AM   #231
mcboomport
mcboomport's Avatar
Good job buddy! I'm glad you're taking your time and paying attention to details.
mcboomport is offline   Reply With Quote
Old 05-23-2012, 09:11 PM   #232
maxxxy
maxxxy's Avatar
Thanks guys! I really appreciate it.
Max
Max's bagged 81
Old 05-23-2012, 10:02 PM   #233
grayharville
Whats the specs on that hood? is it fiberglass? did you build it?
East Tx Squares
Old 05-23-2012, 10:23 PM   #234
bbbc10
Diggin The SquareLife
lookin good do have the sectioned crossmember installed?
bbbc10 is offline   Reply With Quote
Old 05-23-2012, 11:21 PM   #235
maxxxy
maxxxy's Avatar
Yeah the cowl hood is fiberglass. I think earlier in my build I said something about it. I traded this older lady who ha just bought a square body suburban with the cowl hood straight across for my stock hood if I painted it the one I gave to her. But the cowl hood doesn't fit quite like I like. It's a little bowed in the middle and sticks about a 1/4" above the fenders.
I do have the sectioned crossmember in, but my new upper ball joints are binding and won't let me go down as much as before.
Max
Max's bagged 81
Old 05-24-2012, 05:19 AM   #236
bbbc10
if u have stock arms jus pie cut them if u havent....looks good btw
Old 05-24-2012, 11:11 PM   #237
luifer76
luifer76's Avatar
truck looks good maxxxy nice job man... X2 on pie cutting the uppers really easy thing to do....
nOtHiNg LiKe ThE gOoD oLe ChEvYs....
luifer76 is offline   Reply With Quote
Old 05-24-2012, 11:25 PM   #238
luifer76
luifer76's Avatar
i pie cut the uppers on my 77 a while back and i got rid off the binding and this was the test afterwards....
Old 06-02-2012, 02:02 PM   #239
CuRtdOgG
CuRtdOgG's Avatar
Can't wait until you and I can take these babies on a cruise!
CuRtdOgG is offline   Reply With Quote
Old 06-02-2012, 03:49 PM   #240
Shady Chevy
Shady Chevy's Avatar
Cool build. Question about the front rotors. I don't know anything about the 1LE package. Are these rotors different than a standard '91 camaro rotor? Where did you buy the rotors? I would like to do the same. I assume you are using the rest of the stock 81 truck calipers and pads?
Shady Chevy is offline   Reply With Quote
Old 06-04-2012, 07:21 AM   #241
made2drag
made2drag's Avatar
it's looking really low....you have to do the pie cuts! i think you cut slits near the upper ball joint let your truck sit naturally then weld the slits back. i think its done while everything is still together. luifer76 can help you with pics im sure
made2drag is offline   Reply With Quote
Old 06-05-2012, 09:30 AM   #242
Slave1
Slave1's Avatar
Amazing build maxxy, liking your progress and it will be nice to see this rolling! I also wouldnt mind seeing some pics of the pie cuts as im probably gonna have to do the same!!
Steve
Slave1 is offline   Reply With Quote
Old 06-05-2012, 05:38 PM   #243
luifer76
luifer76's Avatar
is really easy to do bro im sure you won't have a problem doing it but yeah maxxxy if you need pics let me know i'll send you some...
Old 06-07-2012, 05:12 PM   #244
maxxxy
maxxxy's Avatar
Shady Chevy the 1le rotors I think are thicker than regular camaro rotors. I just got them from autozone. But at autozone they are listed as camaro performance rotors or something like that. But you should be able to order them anywhere. You still use the stock truck bearings, calipers and pads.
Luifer it would be great if you could take some pictures of the pie cuts for me. I'd really appreciate it.
Max
Max's bagged 81
Old 06-07-2012, 09:46 PM   #245
stepside83
stepside83's Avatar
looking good man,cant waitto see more
stepside83 is offline   Reply With Quote
Old 06-07-2012, 10:06 PM   #246
texastruckjunky
That would be kool camaro rotors up front, and a late model disk brake rear. wheel options would be a lot better, and easier to find.
Old 06-08-2012, 08:45 AM   #247
Shady Chevy
On the front rotors: I called around to local parts stores and you are right. They list them as 91 camaro "performance option" rotors. I think I am going to try this on my truck. Now, I wonder how the width of the camaro rear compares with the truck? How many of the camaro's had rear disk brakes?
Old 06-10-2012, 04:05 PM   #248
maxxxy
maxxxy's Avatar
For the rears I am just using adapters. I used wheeladapter.com. Great service! I emailed them and within 30 minutes the owner called me. He's an older gentleman but he called me and we just talked for half an hour just about life, and boy does he have an interesting one. He used to be a world reknown race car driver back in the day. He's really knowledgable and he will make you any size/pattern/thickness adapters you need from scratch. Well worth the 150 bucks I think.
But the camaro rear end would be cool. I've heard something about using 4x4 s10 rears before. But don't hold me to that. Lol
Max
Max's bagged 81
Old 06-16-2012, 07:33 AM   #249
Slave1
Slave1's Avatar
hey maxxy, just a question about the sectioned x-member, did you have to modify any brackets once fitted like the upper arm bracket because on mine if I was to section it, it would mean that the bolt holes would be above the frame??
Steve
P.S......Awsome build by the way
Old 06-17-2012, 12:05 AM   #250
maxxxy
maxxxy's Avatar
Thanks Steve! I sectioned it 1.25" so I didn't need to make any brackets. It was really really close though. I just bolted it in with the 3 bolts per side on the bottom of the frame, marked through the side bracket holes, then re drilled. One hole on each side was so close that I couldnt use the factory washers on the inside.
Max
Max's bagged 81
1981, bagged, c10, custom, oklahoma
