Old 09-23-2011, 11:19 AM   #226
xpickup
xpickup's Avatar
Re: 1954 Chevy / S10
oldman3, Yes they are. The next couple weeks are going to be busy. This weekenk we have a picnic in the afternoon so hopefully I may sling some primer in the morning or not till sunday. I would like to get the whole front end in epoxy this weekend. Next weekend the cab. Then the truck will be leaving. Then after that I will be roofing for a while. Thank you for asking.
Shannon
xpickup is offline   Reply With Quote
Old 09-23-2011, 01:46 PM   #227
blitz'd
vintage car junkie
blitz'd's Avatar
Hey Shannon, do you go to the Carlisle swap meets? Any good? Hoping to find a few missing items for my 50 while im still in town. Im leaving next weekend so ill miss Hershey.
1950 chevy truck, s10 swap, bagged, v8, 18s
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761
blitz'd is offline   Reply With Quote
Old 09-23-2011, 08:50 PM   #228
xpickup
xpickup's Avatar
Blitz'd, I usaually do not go. I think that the stuff is priced way to high. And a lot of the time I think I threw away better things.
Shannon
Old 09-24-2011, 05:41 PM   #229
britnjc
britnjc's Avatar
Shannon,
love the builds you have going on. I hope your house is getting back to normal. This has been one wild year. Yall got a ton of rain and we got those tornadoes back in April. Insurance companies I am sure giving people some grief with all the money they are paying out. But on another note, you got mad skills...
britnjc is offline   Reply With Quote
Old 09-26-2011, 07:18 PM   #230
Fat Mike
Fat Mike's Avatar
When you get a chance can you give me a measurement on where your front and rear cab mounts are. I just need some kind of reference point! THANX!
Fat Mike is offline   Reply With Quote
Old 09-27-2011, 06:16 AM   #231
xpickup
xpickup's Avatar
britnjc, Thank you. Yes thing are finally getting back to normal. I got a insurance check so in 2 weeks I will be roofing. And just picked up the Durango yesterday and the insurance company is paying for that one too. It had clear water in the motor in which broke the rod. Nobody seems to know how it got in the motor. It came in while it was not running and the water must have blew it under the hood and found its way to the throttle body some how. I am sure everybody is tired of these storms/rain. I know I am!
Fat Mike, I will tonight. Do you mean on the cab or the frame. Let me know.
Shannon
Old 09-27-2011, 08:38 AM   #232
Fat Mike
Fat Mike's Avatar
On the frame.
Old 09-27-2011, 02:09 PM   #233
Kabwe
Certified Car Nut
Kabwe's Avatar
Beautiful work you are doing buddy.
Kabwe is offline   Reply With Quote
Old 09-27-2011, 08:53 PM   #234
xpickup
xpickup's Avatar
Kabwe,Thank you. I should have it all primer after this weekend. Then it is going home. Good job on the cross member.
Fat Mike, My cab mounts are from the back of the factory front body mount. My mounts are made out of 3" tubing. The front edge of the front mount is 5 5/8" and the front edge of the back mount is 40 3/4". Also remember that my floors are not the factory floors. They are made out of 1" X 1" 1/8 wall tubing for the structure then 18 gauge sheet metal. Let me know if you need anything else.
Shannon
Old 09-28-2011, 08:42 AM   #235
AUSSIE54
AUSSIE54's Avatar
G'day Shannon,
Just a little question on the side, but what year is your panel?
Trently.
AUSSIE54 is offline   Reply With Quote
Old 09-28-2011, 08:48 AM   #236
Fat Mike
Fat Mike's Avatar
Where are they in reference to the frame. Like they are 47" from the front suspension shock hole. Thanks
Old 09-28-2011, 09:41 AM   #237
xpickup
xpickup's Avatar
Fat Mike. They are from the back of the factory front cab mount(s10). If you want I can measure from the front shock hole. I just did the factory front cab mount because it was close and on the same plain as my new mounts. Let me know.
Shannon
Old 09-28-2011, 09:46 AM   #238
xpickup
xpickup's Avatar
Hi Trently, The panel is a 1948. I should be soon working on it again. So there will be a build thread on it. Have a good one.
Shannon
Old 09-28-2011, 10:00 AM   #239
oldman3
oldman3's Avatar
Shannon, make sure to post on here that you are starting a new post thread, so we can subscribe.....Jim
oldman3 is offline   Reply With Quote
Old 09-28-2011, 10:09 AM   #240
AUSSIE54
AUSSIE54's Avatar
Thanks Cobba, I'll be most certainly looking forward to that thread!
Cheers, Trently.
Old 09-28-2011, 01:37 PM   #241
xpickup
xpickup's Avatar
oldman3,AUSSIE54, Do not worry as soon as everything is roofed there will be a build thread.
Shannon
Old 09-29-2011, 11:02 AM   #242
Fat Mike
Fat Mike's Avatar
Can you please measure them for me. Thanx!
Old 09-29-2011, 11:47 AM   #243
xpickup
xpickup's Avatar
Fat Mike, No problem. I will measure from the shock to the front of each body mount. I did not think of if you ground them off. I took them off with my plasm cutter so there was still about a 1/8 inch left of the factory front mount and I did not grind them off yet.
Shannon
Old 10-01-2011, 07:55 AM   #244
xpickup
xpickup's Avatar
Fat Mike,From the shock stud to the front of the front mount is 29 1/2 inches and to the front of the rear mount 64 3/4 inches. That is not to the holes if you want that add 1 1/2 inches. If you need anymore let me know.
Shannon
Old 10-01-2011, 04:54 PM   #245
xpickup
xpickup's Avatar
Well everything is in epoxy primer. Bottom of the cab, inside and outside of cab, inside and outside of the doors. radiator support, steering column, U joints and dd shaft. and other misc. stuff all primed. So hopefully tomorrow I can bolt it all together and it will ready for the owner to pick up. Here are some pictures.
Old 10-01-2011, 05:00 PM   #246
BlueJeep
BlueJeep's Avatar
Looking great!!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 10-01-2011, 06:30 PM   #247
Fat Mike
Fat Mike's Avatar
Thank you very much. Just what I needed!
Old 10-01-2011, 06:39 PM   #248
Kabwe
Certified Car Nut
Kabwe's Avatar
Somebody's been busy. At least you have.lol Good job its looking great buddy.
Old 10-01-2011, 07:33 PM   #249
xpickup
xpickup's Avatar
BlueJeep,Thank you.
Fat Mike, No problem, Need anymore let me know.
Kabwe,Yes it has been busy, Can not wait to see it all together.
Shannon
Old 10-01-2011, 08:37 PM   #250
oldman3
oldman3's Avatar
Shannon, everything looks great, I'm like you can't wait to see it together....Jim
