#226 |
Re: Nsane 52' Chevy Truck!
DeWayne, Here are some pictures. I used a DD to spline coupling to couple the sidewinder box to the steering box. Made a plate to mount the sidewinder box to the frame that way you can remove the cab without removing the box. It worked out really well. I used the stubby column with double drops. I mounted the motor behind the cab (crew cab) I am making the ramp bed out of tubing for the structure. The sides will be painted with interal boxs and to deck will be polished alum. The rear beaver tail (ramps) flip up because my buddy wanted to also be able to pull a goose neck trailer with it. If you need anymore pic let me know.
Shannon |
#227 | |
![]() Join Date: Jul 2010
![]() Quote:
DeWayne |
#228 |
I started the repairs on the passenger door today, I'll post more pics tomorrow after I blast the inside of the door and finish the repair.
#229 |
I finished repairing the front fender today. The drivers door should be finished tonight, then into the booth! DeWayne
#230 |
Do you always do some of the welds and grind them before adding more welds, or was that to show us amateurs how smooth you can make a panel joint without using filler? Is that tig welds?
Beautiful work, very inspirational. Keep the pics coming. |
#231 | |
#232 |
More pics! I finshed the passenger side front fender today, and started setting the hood gap. DeWayne
#233 |
What do you charge per hour As i may be Needing your Services On a 3 window cab that i well am trying to make look ok but everytme i see your work i want to cry and hang my head.
Jaime |
#234 |
#235 |
Here are a couple pics of the cab everything is in the bodywork stage right now. I'll post more pics when we have the color on it.
#236 |
56 - autocross
this is art work!
#237 |
Thanks! Here's a little teaser pic, straight out of the booth. DeWayne
www.nsanehotrodz.com customerservice@nsanehotrodz.com 865-761-0460 Tennessee's #1 HotRod Shop! |
#238 |
Looks good! What is that color called?
Renegade |
#239 |
this might be a stupid question but im new so do you weld with a tig?
#240 | |
Thanks, its called Laser Blue.
![]() DeWayne
#241 |
I like that blue dodge had a similar color in the early 80s that I really liked
beautiful work! |
#242 |
6>8 Plugless........
![]() Join Date: Sep 2007
Man you do awesome work and you also work fast! Great job! Ryan.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#243 |
Can't wait to see some more paint. Going to look killer!
71 Ol' Blue: http://67-72chevytrucks.com/vboard/s...d.php?t=474752 Carving the Jake-olantern: http://67-72chevytrucks.com/vboard/s...d.php?t=679537 |
#244 |
Just wondering, if you grind after each set of welds, and if you weld the joints solid in the end, how much metal is removed from the original panels that are being joined? Wouldn't they be much thinner after all the grinding?
#245 | ||
Thanks! I'll post more next week. The key is to only grind the weld. Fit-up is very important. When I grind the welds the first round I leave them just a little higher than the base metal. Then finish them when it is completely welded. Thanks
#246 |
Between this and the Ironworks Truck we have some top notch builds going on! Cant wait to see more of the pieces in paint. That is a nice shade of blue!
#247 |
![]() Join Date: Oct 2009
have to agree with that, this is one nice truck, and an excellent lesson in welding!
#248 | ||
![]() Quote:
DeWayne
#249 |
DeWayne, dude, you have an unreal amount of talent as well! Don't cut your self short!
#250 | |
