Old 06-26-2015, 08:22 PM   #226
Mechanic77
Re: Project Pro Touring "Ole Blue"
Originally Posted by Rob Fisher View Post
I really like what you are doing with your truck and the fact that you are doing all the fabrication yourself, very nice work.
I went the easy route and put Porterbuilt suspension font and back.
Would you share some information about the sway bar setup that you used in the rear.
How long are your end brackets, what bar diameter, etc.....
Supplier and part numbers would be great.
Thanks in advance for your help.
Rob Fisher
Man, you're going to test my memory.....I went out and measured the bar I have, and it's a 1.25" dia hollow bar with .25" wall, and the arms are 10" center to center in the shortest hole and 13" center to center on the longest hole (4 holes total, 1" between each), I made them adjustable so I could tune on it if need be. I'm going to start with the arms as long as possible and shorten them up until I get the truck balanced. If I remember correct, I came up with that size by using a chart that Speedway Engineering has for their sway bar torsional stiffness and I believe an 80% differential between the front and rear bar stiffness. I think I got the 80% from Rob off the Make it Handle thread....I believe the length of the bar makes a difference too on the stiffness....it's been way too long to remember for sure....
Yep....here's a link to the page with all the charts: http://www.1speedway.com/sb_rates.htm
...the length does play into it, so you have to keep that in mind. I know mine are different lengths front to rear, so I had to figure that in.
If you need anything else, let me know.
Pro Touring 1964 C10-Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=441627
Project '65 Short Step Daily Driver http://67-72chevytrucks.com/vboard/s...d.php?t=661948
Mechanic77 is offline   Reply With Quote
Old 08-10-2015, 07:05 AM   #227
rhd_c10
rhd_c10's Avatar
great fab work
my rhd build.. http://67-72chevytrucks.com/vboard/s...d.php?t=468712
1964 CHEVROLET BISCAYNE 350CI/TH-350
1968 CHEVROLET C-10 SWB LS1/4L60E
rhd_c10 is offline   Reply With Quote
Old 09-20-2015, 03:44 PM   #228
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Originally Posted by Mechanic77 View Post
Ok, now for an update.....
I've actually been working pretty hot and heavy on the truck.....I've shortened the bed and I'm hoping to finish the fuel tank this weekend, and maybe, just maybe , get the framework for the bed floor done too....
And now for some pictures
Before I cut the left bedside.....which, by the way, I just picked up from Joedoh (thanks!!)....much better than the one I was planning on cutting up
Attachment 796355
.....and mocked up for the first time
Attachment 796356
.....and as it sits right now
Attachment 796357
Attachment 796358
More pics to come......
Did you do 12" out of the front and 8" out of the rear?
66 C20 Service Truck:
Old 09-21-2015, 12:10 AM   #229
Mechanic77
No, I actually cut 9" out of the front and 6" out of the rear....I felt like the short bed was a little too short, so I made it just a bit longer....
Old 11-08-2015, 08:09 PM   #230
thumpros@yahoo.com
thumpros@yahoo.com's Avatar
Mechanic77, That looks bad ass brother. Which front and rear shock absorbers are you running on your frame pictures?
Thanks/
Rod
68 C10 LS SWB LM7 5.3 700R4 http://67-72chevytrucks.com/vboard/s...d.php?t=692803
thumpros@yahoo.com is offline   Reply With Quote
Old 11-09-2015, 01:32 AM   #231
Mechanic77
Thanks/
Rod
Thanks thumpros....I'm running single adjustable QA1's on the front (fit an 1984 C10 front end) and Edelbrock IAS shocks on the rear (stock application). I might end up changing the rears out for some QA1's....we'll see....
Old 02-26-2016, 11:00 PM   #232
laid67
laid67's Avatar
I know all about falling off of a project, but I really wanna see this thing rolling, curious how much your chassis bracing helps with the frame twisting, i'm looking to do something similar. Great build so far though!
1967 c10
build finally in progress!
http://67-72chevytrucks.com/vboard/s...d.php?t=575626
laid67 is offline   Reply With Quote
Old 08-10-2018, 11:44 PM   #233
CousinTone
Just wondering...
CousinTone is offline   Reply With Quote
Old 08-19-2018, 10:07 PM   #234
1965life
Following the build awesome job
1965life is offline   Reply With Quote
