Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 11-14-2015, 02:09 AM   #226
Captainfab
60-66 Nut
Re: SiX-fo SuBuRbAn
When you wired in the HEI, did you run a new wire to be sure it has a full 12 volts from the ignition switch? The original coil wire in the Suburban wire harness does not provide enough voltage.
Old 11-14-2015, 02:27 AM   #227
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: SiX-fo SuBuRbAn
I wired it to the "ignition switched" post on the fuse block, there are two of these terminals towards the left top... should I try wiring it to something else?
Old 11-17-2015, 08:10 PM   #228
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
I guess it says "ign. unfused"
still trying to fix it without spending lots of $$, and today tried changing the coil out, cursing that I didn't put the engine 1 inch forward, the dist. is super close to the firewall and a ***** to get off!
anyway that did not help, the spark is super weak: with the screw driver in the plug wire to hood hinge test it gives a pathetic little orange spark.
I might run a jumper wire from the battery to the dist. connection to rule out a wiring harness problem?
and I am about ready to "borrow" the cap and wires of one of my running trucks to see if that fixes the problem.
Old 11-18-2015, 01:54 AM   #229
Captainfab
60-66 Nut
Re: SiX-fo SuBuRbAn
That source should be fine. I just didn't know I you knew about having to have a full 12 volts to the distributor. Do you have good grounds to both the engine and body?
Old 11-18-2015, 06:57 PM   #230
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
that is something I should check, I am pretty sure I hooked those up, but might have missed them....
Old 11-19-2015, 01:39 PM   #231
hemifalcon
Re: SiX-fo SuBuRbAn
Originally Posted by aotte1 View Post
Jon,
The strap sounds good, once the engine is out, should be able to bend it to fit the cross member. Will try to heat up the strap with my TIG welder, getting it red just before it puddles, then bend it.
Les
Com'on man.. You have to have a torch in that shop somewhere don't you?
My '65 Suburban Resto build--
http://smg.photobucket.com/albums/v6...65%20Suburban/
And it's story of being 'saved'
http://www.jalopyjournal.com/forum/s...d.php?t=631495
hemifalcon is offline   Reply With Quote
Old 11-20-2015, 12:40 AM   #232
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
Double checked, ground straps are there. Pulled cap and wires off a running truck, and put them on, still no start, put a jumper wire from batt terminal directly to the battery, still nothing.
This wouldn't be so frustrating if it never ran, but last summer I fired it up for a few minutes, and the before I discovered the carb trouble I got it to run. Also, after the first carb cleaning I did get it to run for at least a minute.
The only thing I haven't changed is the plugs, so next I will try a new set of plugs-maybe with the gummed up carb and priming and such the plugs have been fouled.
I hope that is it.
Old 11-20-2015, 01:37 AM   #233
Captainfab
60-66 Nut
Re: SiX-fo SuBuRbAn
Try changing the module in the base of the distributor.
Old 11-20-2015, 09:17 AM   #234
piratexpress1369a
piratexpress1369a's Avatar
Re: SiX-fo SuBuRbAn
Just a shot in the dark ..had a jeep that would not fire up ..turned out the brass part in the boot had moved back to far on the coil ...had use a pick to move it back in place so it could get a better spark
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 11-20-2015, 05:48 PM   #235
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
will do
good tip, but this is an hei.
got the plugs, haven't put 'em in , but had to laugh at the parts store today.
"I need plugs for a '66 396"
"truck ? "
"sure"
"1/2 or 3/4 ton?"
"1/2"
"2 wheel drive or 4?"
"hmm, lets say 2"
pause....
"they don't show a 396 for a truck"
"Oh yeah, forgot.. make that an impala,66."
"Hmmm, 250?"
"No..... a 396."
"oh OK here they are..."
Old 12-12-2015, 10:40 PM   #236
1955 mancave
1955 mancave's Avatar
Re: SiX-fo SuBuRbAn
ok I need more info on this project, and did you ever get it to fire up if not let me know I hade an issue with my 57 and it turned out to be and its been a long time agao but I think I shorted out the coil , not sure if that helps but now my brain will have to try to remember what the heck it was I will get back with you.
1964 1 Ton flatbed service truck (sold)
1964 C-10 panel (project complete frame up build)
1957 210 post pearl orange
1955 mancave is offline   Reply With Quote
Old 12-13-2015, 09:14 PM   #237
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
it got cold outside so I quit messing with it for a while...
I never did get it to run, started changing the plugs out, and got a few done, then a friend stopped by and we messed with it for about a half hour, we got it to fire a little bit, and adjusted the timing, it was real touchy, a tiny bit advanced, or retarded and it wouldn't fire at all....on a warm day I am going to get the rest of the plugs, and chase the rest of the system if needed.
Old 07-29-2016, 06:05 PM   #238
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
.... well the warm day finally came- yesterday I pushed this 'burb into the garage, installed the rest of the new plugs, threw a battery in it, primed it, and it fired up like there had never been an issue at all!! -go figure
now I can get going on finishing up the sheet metal work.
Old 02-05-2017, 01:51 PM   #239
1972RedNeck
1972RedNeck's Avatar
Re: SiX-fo SuBuRbAn
How's the project coming along?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 05-04-2017, 01:37 PM   #240
1962 Panel
1962 Panel's Avatar
Re: SiX-fo SuBuRbAn
Following if the project is still going on
1962 4x4 Panel Delivery. 327 / 300 HP, Orig. SM420, Rockwell T221, 10 Bolt Rear/ Dana 44 Front. Project.
1977 Ford LTD, 302/C4, 18,000 mile survivor, daily driver.
That's right, a Ford. I'm bi-partisan.
1962 Panel is offline   Reply With Quote
Old 01-14-2018, 09:49 PM   #241
pimpston65
pimpston65's Avatar
Re: SiX-fo SuBuRbAn
here is some progress.. rust repair on the lower door pillar, on the rh side I had to make patterns and fabricate the rusted away piece, luckily there was enough left on the left side to use as a pattern.
the inside of the rockers.. they are a little surface rusted , but not too bad, and the patch on the rh floor brace, where it was cut up with the torch.
so glad you included pictures. i will be rebuilding mine soon...
pimpston65 is offline   Reply With Quote
Old 12-08-2019, 10:29 PM   #242
jonzcustomshop
1961 crewcab
Re: SiX-fo SuBuRbAn
I was looking at this thread, and realized I hadn't done anything to this in the last 3 years! I always intend to get to it, and something else always comes up! I'll keep trying....
Old 12-09-2019, 01:32 AM   #243
padresag
Re: SiX-fo SuBuRbAn
Jon; it is amazing how time flies by!
Ron
padresag is offline   Reply With Quote
Old 05-06-2020, 11:21 AM   #244
Bill66K1000
Re: SiX-fo SuBuRbAn
This has been great to read up on. I got on this forum a while back and have hit it up periodically since with little reading and a few questions. My project has been very slow going since I picked up my grandpas old farm truck in 2013, a 66 GMC K1000. I found your thread while seeking axle swap info and it took me a long time to find it again. I love your burb, especially the early hood, and would kill to find a decent one for my truck. I hope you managed some time to get back to it, see it's been a few months since you posted an update.
Bill66K1000 is offline   Reply With Quote
