06-06-2011, 08:04 PM | #226 |
Re: Jimbo's 67 Long bed step side build
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 06-06-2011 at 08:05 PM. |
06-06-2011, 08:06 PM | #227 |
On with todays post.
Pic 1 New 700R4 trans from Gear Star. Pic 2 My home made trans mount. Pic 3 Old 3 speed and parts.
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 06-06-2011 at 08:07 PM. |
06-06-2011, 08:12 PM | #228 |
Wasn't thinking forget the pics.
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
06-06-2011, 08:13 PM | #229 |
Installing Lokar shifter to trans.
06-06-2011, 08:17 PM | #230 |
Pic 1 Console mock up of side panels, etc.
Pic 2 Had to modify opening for trans and shifter. Pic 3 AC controller to stay close to stock location, add "T" nuts for mounting of console. Pic 4 Fiberglass filler added to console, for shaping.
06-06-2011, 08:21 PM | #231 |
Pic 1 Back of console with lauan panel glassed to console.
Pic 2 Checking fit to dash. Here you can also see the metal plates that are attached to console, this is how the side panel will be attached with clips. Pic 3 Another view of console to dash. Pic 4 With the side panel in position.
06-06-2011, 08:24 PM | #232 |
Pic 1 Back on the back panels, installing fiberglass mat to the corner area.
Pic 2 The other side panel, starting to sand down glass. Pic 3 Installing filler over fiberglass and smoothing things out.
06-06-2011, 08:27 PM | #233 |
Pic 1 A little filler to smooth out the side rail.
Pic 2 View from outside the cab, of side and back panels.
06-06-2011, 08:31 PM | #234 |
Pic 1 Working on cover panel for 10" speaker.
Pic 2 Here the old leather was removed from console. Old padding smoothed and console in primer. Pic 3 Here it has been sanded and smoothed out, ready for another coat of primer.
06-06-2011, 08:32 PM | #235 |
Will catch you tomorrow with another post......Jim
06-06-2011, 09:55 PM | #236 |
Ben, later talked with owner, seats out of late 80's Jeep Cherokee.
06-06-2011, 10:18 PM | #237 |
Endless cutting fitting shaping filling finishing , , , you guys are sculptors , , , (btw you have a tv show of sorts here in this thread)
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
06-07-2011, 05:18 PM | #238 |
Thanks Jim, I appreciate the thoughts. Finally got to look at your build, talk about detail, thats a lot of detail about what you did and how. Very nice truck you have there also......Jim
06-07-2011, 06:56 PM | #239 |
Pic 1 Home made speaker pod for kick panel area.
Pic 2 Will be installed in the old vent opening. Pic 3 Installed in opening. Pic 4 Speaker installed.
06-07-2011, 06:59 PM | #240 |
Pic 1 New opening for radio made, and a little filler work on dash.
Pic 2 Another view. Pic 3 Additional filler to dash.
06-07-2011, 07:03 PM | #241 |
Pic 1 Hole in the windshield area, that was found earlier, just now fixing.
Pic 2 New piece being bent to fit. Pic 3 Filler added to repaired area. Pic 4 Filler on pass. side where seam was welded.
06-07-2011, 07:06 PM | #242 |
Pic 1 Filler added to the front of cab.
Pic 2 Top of cab with filler added. Pic 3 Sanded and adding thin coat again.
06-07-2011, 07:08 PM | #243 |
Pic 1 Top sanded, ready for final check.
Pic 2 Another view. Pic 3 My son Mark blocking one more time.
06-07-2011, 07:12 PM | #244 |
Pic 1 Checking firewall one more time.
Pic 2 Close up of some spots. Pic 3 Back of cab. Pic 4 Back of cab again, with guide coat added.
06-07-2011, 07:13 PM | #245 |
Will post again tomorrow................Jim
06-07-2011, 09:03 PM | #246 |
PROJECT 7DEUCE
Wow you guys have really made some progress on this truck looks great..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
06-08-2011, 04:47 PM | #247 |
Thanks for checking it out; not to burst the bubble,but truck is already done. In the last 4 weeks, I covered about 1-1/2 yrs of work. So progress is probably about normal, just looks fast. Thanks again.....Jim
06-08-2011, 04:50 PM | #248 |
Pic 1 Firewall getting close at this point. Pic 2 Back of cab almost ready.
06-08-2011, 04:52 PM | #249 |
Pic 1 Grandson and daughter-in-law helping
Pic 2 Additional sanding on lower section.
06-08-2011, 04:55 PM | #250 |
Pic 1 Patching holes where speaker brackets were mounted.
Pic 2 Some pin holes in upper lip area. Pic 3 Stainless cover for the AC lines.
