Old 04-12-2012, 08:31 PM   #226
duallyjams
duallyjams's Avatar
Re: Project Goldilocks, '66 C10 SWB BBW Build
I like it.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 04-12-2012, 08:44 PM   #227
MalibuKasey
Artist
MalibuKasey's Avatar
Official Consultant huh... Im honored!!
66 Chevy C10 283ci~cough~ SBW Fleet Buttercup '66
MalibuKasey is offline   Reply With Quote
Old 04-13-2012, 08:54 AM   #228
MalibuKasey
Artist
How big of a turbo are you going to be putting on that straight 6??? I say after the first few Autocross passes... that youll be itching for a nasty little SBC.
Old 04-13-2012, 10:05 AM   #229
theastronaut
theastronaut's Avatar
No turbo, it'll be running triple side draft Dellorto's. I'll be happy if it runs in the 13's, don't care if it's high or low 13's. I think 350-375 hp is do-able with the six, and that should get it well into the 13's if it weighs around 3600 pounds. I think between the six cylinder and an aluminum trans I should be able to keep the weight down somewhat. I'm building a stroker motor for the Bug for when I want to go fast!
Going by an online 1/4 mile calculator:
325hp/3600LB= 13.68 ET
350hp/3600LB= 13.35 ET
375hp/3600LB= 13.04 ET
Of course that's assuming that it hooks up and is geared decent. Raising the trailing arm mounts and moving the tank to the back will help it hook, and it'll have 4.56 gears since a T56 is double overdrive.
theastronaut is offline   Reply With Quote
Old 04-16-2012, 01:35 PM   #230
theastronaut
Originally Posted by duallyjams View Post
I like it.
Thanks James!
Got the wheel from MalibuKasey in the mail today and the Nova rings are going to be perfect! The Nova wheel is identical to the truck wheel so the rings are a dead-on match for the rim profile. Now I'll have to figure out how to make indentions on the truck wheel to fit the rings...
Old 04-22-2012, 04:35 PM   #231
hill64step
Love how the steering wheel is turning out!
64 Stepside.. A work in progress..
hill64step is offline   Reply With Quote
Old 04-26-2012, 11:09 AM   #232
greg65
greg65's Avatar
subscribed
1965 c-10 swb
1997 c-1500 extended cab
2004 tahoe
1993 mustang gt
BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653
greg65 is offline   Reply With Quote
Old 04-26-2012, 11:38 AM   #233
theastronaut
Originally Posted by greg65 View Post
subscribed
Thanks guys!
Well, I took the worst roadtrip of my life yesterday evening. I found a cheap ($600 bucks!) T56 on craigslist tuesday night, and made a deal to buy it wednesday morning. Only problem was, it was in Cherokee NC, and I've been sick since tuesday with a nasty cold, so I didn't really feel like driving 240 miles round-trip to pick it up. I'm a sucker for a deal though, and sure didn't want anybody else to grab it before I did, so we decided to go ahead and get it last night. It started POURING rain about an hour before we got there, to the point of not being able to see 500 feet infront of the truck. About halfway home the dayquil wore off, making the trip even more miserable, but it was worth it. The scenery sure was nice when it wasn't raining. It's not in the pics, but it came with bellhousing too. It's from a wrecked '94 LT1 Z28 with 58,xxx miles on it.
Old 04-26-2012, 12:00 PM   #234
MalibuKasey
Artist
Like I said!! well worth the drive for a killer score! The deals are out there and you seem to finding some good ones. The direction your truck is going in... its going to get ALOT of well deserved attention!
Old 04-26-2012, 12:49 PM   #235
theastronaut
Been keepin my eye open on craigslist and ebay for 64-66 parts, and it's surprising how many good deals are out there if you look often enough. Last Friday I found a '66 only tach and air pressure gauge cluster for $245 shipped, Buy It Now on ebay. It had only been posted a few minutes when I found it so I jumped on it before anybody else did- it should get here tomorrow or saturday. There was a tach dash on ebay yesterday for $199 BIN or Make an Offer; it lasted less than two hours. Cleaned up, those tach gauge clusters have been going for $500+ so I was thrilled to find one half price.
I'll buy a set of decals to restore the gauge faces, get a new lens, blast/paint the frame and use it in Goldilocks. I may take the tach out though, use a modern 8k rpm tach and have a new face made that has the original look and fonts, but go to 8k rpm instead of 5k. North Hollywood Speeometer takes old gauges and puts modern guts in them, while keeping the old look so I may use them to redo the tach. The air pressure gauge will be perfect to keep check on the pressure in the air bag's tank.
Old 04-26-2012, 03:05 PM   #236
theastronaut
I did some digging around and found the gear ratios for the T56 and plugged them into a gear ratio calculator to figure out what r&p ratio I'll need. Looks like a 4.56 will be a good match if I use 29" tall tires. I'm just guessing on the tire size though. I plugged in 1500, 1800, 2000, 3000, and 6500 RPM to see what the speeds would be in each gear.
Old 04-26-2012, 11:00 PM   #237
duallyjams
duallyjams's Avatar
No wonder I can't find any ( tach dash ) man hope you feel better.
James
IG duallyjams
Old 04-28-2012, 03:23 PM   #238
pdxhall
pdxhall's Avatar
A couple of great scores. I'm looking to pick up a t56. I'm a ways off from needing it but I'm always looking. I hope I get as lucky as you did. By the way, the steering wheel is looking great. I picked up a 65 car wheel that I'm restoring. I used the same epoxy and it turned out great. I haven't painted mine yet. Have you decided on what paint to use?
pdxhall is offline   Reply With Quote
Old 04-28-2012, 03:43 PM   #239
theastronaut
Ya snooze, ya lose! I'm pretty much back to normal, thanks!
Thanks, I'll be lightly spraying it with Bull Dog adhesion promoter first, then a coat of PPG DP90 over the whole wheel. I'll let that sit a day, scuff it, and then shoot Slick Sand over everything except the textured area. I'll dry sand the slick sand smooth with 120/180 grit, then spray a coat of K36 high build and wetsand it with 500. I think I'm going to use Spies Hecker just like I did on the blue '65 since I'm familiar with it and had good results with it on the '65s interior. I'll do base/clear on the wheel even though they weren't shiny from the factory; if I used a satin finish it would get worn spots and eventually turn shiny around the rim from use. This way it'll keep an even shine all over, and I like the contrast from the satin interior to the glossy wheel and column.
Here's the wheel and column in the '65.
Old 04-28-2012, 05:25 PM   #240
theastronaut
Got some work done on the gauge cluster. I dug around and found a repro lens that was left over from the blue '65 build. It had some pretty rough shelf wear when I recieved it, so the company sent me another one to replace it. I spent some time buffing it out and it actually cleared up all the way- I really wasn't expecting the plastic to buff out that well. The background panel was faded so I scuffed it and resprayed it with low gloss black, and I also masked out the gauge faces and repainted the needles with a pinstriping brush. I've got a set of decals for the gauge faces ordered so the gauges will look 100% new as well. The numbers on the odometer were flaking and peeling off, but I've got two parts gauges that have better odometers in them. I should have it back together later this week when the rest of the parts come in.
I picked these bulb housings up at a swap meet, they've got a narrow spot beam pattern for long distance visibility and take H3 bulbs. I'll put 100W bulbs in them and wire them up to come on with the high beams. I should be able so see pretty good between these and H4's with 80/100W bulbs! My VW has nearly the same lighting set-up, and I can easily see 1/4 mile down the road. Still gotta find some chrome housings to put them in. The "For Rent" tag was too cheap to pass up; been thinking about running it on the front bumper.
Similar, slighly smaller lights on my VW, with only 70W bulbs in the spot housings. I had them tinted yellow at one point with electrical tape X's over them (rally/road race style) but that blocked alot of the light output, so they're back to clear now. They help out some on the bug, but it's dropped so low (3" ride height) that probably 1/3 of the light is aimed down on the road right in front of the car.
Old 04-28-2012, 09:45 PM   #241
duallyjams
duallyjams's Avatar
Now I got spots in my eyes.
James
IG duallyjams
Old 05-01-2012, 08:18 PM   #242
theastronaut
They'll definitly burn some retina's on high beams! The driving lights only come on with the high beams, and the sharp cut off pattern of the low beams keeps any glare out of the eyes of oncoming traffic. The pic below shows the low beam cut off pretty well.
Here's an update on the wheel. I finished shaping the wheel repairs and sprayed it with a couple thick coats of Slick Sand. I didn't spray a coat of DP90 over it since I have a wheel resto book that said that polyester primer sticks extremely well to the plastic. I did spray a light coat of Bull Dog adhesion promoter over the wheel first to help make sure the primer sticks. I'm pretty happy with the way it turned out, and can't wait to sand it down to get the shape dead-on and the small imperfections out. I slightly reduced the Slick Sand so it layed out very smooth.
Old 05-02-2012, 07:23 PM   #243
theastronaut
First off, big thanks to chevyrestoguy for donating the super hard to find air pressure gauge decal!! Nobody is currently selling decals that include the air pressure or vacuum gauge decals, and chevyrestoguy had the air decal left over from a set he had. Thanks so much!!
I had a slow day at work after lunch so I got a good start on restoring the gauge cluster. I had already bought a decal set off ebay for the other gauges, and bead blasted the housing and gauge mounts. Krylon makes a green paint that is a very close match for the inside of the housing, and I cleared the outside like the factory did. The wiring cleaned up good with 3M adhesive cleaner, then I wiped it down with Duragloss Vinyl and Rubber dressing to bring the color out and darken the black peices. I've still got to make the "Tand'm Lock" and "Over Speed" lenses and get them installed, and put new bulbs in the bulb holders. The air gauge doesn't sit exactly level in the opening so I've got to straighten that out as well. I'm pretty stoked with how it's turned out so far!
Old 05-02-2012, 07:30 PM   #244
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Wow turned out very clean..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-02-2012, 07:33 PM   #245
duallyjams
duallyjams's Avatar
sweet
James
IG duallyjams
Old 05-02-2012, 09:00 PM   #246
likaroc13
Rollin' Old Skool
sweet, it cleaned up really nice
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 05-02-2012, 09:04 PM   #247
MisterC
MisterC's Avatar
That looks amazing! Great work.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 05-02-2012, 09:57 PM   #248
Frizzle Fry
Frizzle Fry's Avatar
very nice on all accounts!
Frizzle Fry is offline   Reply With Quote
Old 05-02-2012, 11:24 PM   #249
65Pickup
65Pickup's Avatar
65Pickup is offline   Reply With Quote
Old 05-02-2012, 11:41 PM   #250
theastronaut
Wow, thanks dudes!! Here's a few shots with the bezel on.
