Old 04-22-2012, 04:14 PM   #226
omodified
omodified's Avatar
Re: Omodified's 1970 SWB Custom/10
BTW, I laughed about our silver being called "argent" because everybody here is convinced that is what it is called. Now, that may very well be the case, but every silver paint I can find says argent on it because that is the french word for silver. Red also said "rouge" and black said "noir". It was pretty consistent. So, I laugh because I really wonder if "argent" is the actual correct shade of silver for our many applications...
Board Member #87725
Old 04-22-2012, 04:18 PM   #227
omodified
omodified's Avatar
For months I have been looking daily on craigslist for a set of BFG 275/60/15's. I really didn't care if they were used or new, they just needed to be cheap. Well, I was starting to think that it was an impossible find. People here in Charlotte are posting WTB ads for them. But then this popped up in nearby Greenville, SC...
You better believe we drove down to SC right away. These things still have the stickers and nobbies on them! Unbelievable steal!!!
Board Member #87725
Old 04-22-2012, 07:53 PM   #228
3970010
Originally Posted by VA72C10 View Post
Sorry to hear about the issues but some nice parts replacing the old ones!!! Really like the overflow container...I might have to copy you
I also like the overflow idea... Plan to do the same with my truck!
3970010 is offline   Reply With Quote
Old 04-22-2012, 08:30 PM   #229
VA72C10
VA72C10
VA72C10's Avatar
Looking good! Engine bay and front end look great! Nice improvement!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 04-22-2012, 08:47 PM   #230
omodified
omodified's Avatar
Does anybody know what this is???
Here is a hint. It used to look like this...even with the engine running.
Well, I didn't know what the first pic was either until today. It's a working ammeter gauge! I saw where somebody was selling a new gauge here today and it got me thinking about mine not working (well I wasn't real sure if it did or not). So, I did my research here and found that I should check two inline fuses under the hood. I couldn't hardly get the housings to come apart. I ended up busting the fuses in the process. What was left of the fuses seemed to be welded in place. It took some patience to remove the carcasses but I got them out. I went up to Autozone and bought two new 4 amp mini fuses. Installed them with dielectric grease and EUREKA... a working ammeter gauge!
Board Member #87725
Old 06-04-2012, 08:32 AM   #231
omodified
omodified's Avatar
Made some progress over the last few days. I bought a used tailgate band from a board member with the intention of restoring it. As you can see, mine was a bit tattered...
Well, the one I received was in worse shape than mine so I set out to restore my original. First I straightened out the area that was bend up and nearly broken off. Then I hit it with 3M 3 minute epoxy. Next I stripped off the old wood grain tape with acetone.
Next, I stripped off the old black paint. This was a bit harder to do than the woodgrain, but the acetone works really well and did not mess up the finish underneath. I ended up with a nice new surface to work with.
I roughed up the new surface with scotchbrite and got to taping. I found a new spray paint from VHT called chassis and rollbar paint that I wanted to try out. It has epoxy mixed with the paint so there was no need for primer. It sprayed on really well. I went with 5 coats total. No runs and it sprayed really even. I polished up the old metal letters and attached them to the band with the 3 minute epoxy. Here is the finished product!
It looks just like a new one! I am super happy with all the money that saved. Now I have to do the rest of the trim to match!
Board Member #87725
Old 06-04-2012, 08:35 AM   #232
omodified
omodified's Avatar
Notice in the picture below, a wheel with no tire. I dismounted my old tires and took my wheels to be blasted. Time to take the wheels to the powdercoater for some fresh gloss black!
Board Member #87725
Old 06-04-2012, 08:41 AM   #233
omodified
omodified's Avatar
I ordered some new shocks today. I am super tired of hitting my head on the roof when I go over larger dips in the road. I pulled the old shocks off and they are junk. When I measured the available travels I only had 0.75" in the front and 1.25" in the back. After doing much research, I went with CPP house brand they have for a 3/5 drop. I have no idea how much my truck is actually dropped, but when I measure my shock lengths as they sit static on the truck, the 3/5 drop shock makes the most sense. I may go back an order the rear shock relocators and the super trac bar too. We'll see!
Here is the old front shock I took off...
Board Member #87725
Old 06-04-2012, 08:44 AM   #234
omodified
omodified's Avatar
I got the wheels back from the powder coater. I wasted no time getting the tires put on. I need some new trim rings, but here it is for now. What do you think? I like it so far!
Board Member #87725
Old 06-04-2012, 09:13 AM   #235
jeffg1010
jeffg1010's Avatar
Tailgate band looks GREAT. I may need to try to find one for my Blazer.
And the wheels are looking good too.
Jeff
1972 Blazer CST 2wd- My son Sam's Project "S" Project "S"
1970 Suburban - SOLD "One Bad Burb" Photobucket Album
1986 C30 Crewcab - 63K original miles, original paint
Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP...
jeffg1010 is offline   Reply With Quote
Old 06-04-2012, 09:41 AM   #236
gcburdic
Restoration Virgin!
gcburdic's Avatar
This thing is turning out better and better everytime you work on it!!!
BTW...I see in your sig that you are board member #31,051.....but when I roll my mouse point over your user ID it shows you as #87,725....
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 06-04-2012, 12:20 PM   #237
omodified
omodified's Avatar
Thanks Jeff. Pretty soon I might feel comfortable enough to leave my neighborhood with it. LOL
Thanks for the compliment Geoff. I did notice the board number thing. However, if you click on Member List up top, there are only 39843 results. So, apparently 73,419 have cancelled their memberships to date. So, 56,674 have moved their feet and lost their seat to me. Seems crazy that many people have left since 2010, but the math doesn't lie (unless my logic is incorrect). For arguement sake though, I will renounce my position as 31,051 and reclaim my place at 87,725.
Board Member #87725
Old 06-09-2012, 05:18 PM   #238
omodified
omodified's Avatar
The big brown truck brought me some ride control today.
Got all 4 installed and took her for a spin. It rides sooo much better, but I think the rear shocks are acting like a hinge. So, I went ahead and ordered CPP's rear shock relocator kit and a super trac bar kit. Also, my daughter talked me into taking it up to the local cruise in tonight. I still don't think it's ready for all that but she said if anybody had something bad to say, she would set them straight.
Board Member #87725
Old 06-09-2012, 05:59 PM   #239
jeffg1010
jeffg1010's Avatar
Not to hijack, but which cruise in?!?
Jeff
Old 06-10-2012, 10:48 AM   #240
omodified
omodified's Avatar
Kat's Patch, if you can call that a cruise in...
Board Member #87725
Old 06-10-2012, 02:35 PM   #241
lolife99
67-72 parts collector,…
lolife99's Avatar
Keeps getting better.
You will like the rear shock relocators and track bar.
Keith
Convert to disc brakes.
Old 06-17-2012, 10:37 PM   #242
omodified
omodified's Avatar
So, it's been killing me. I really want to know if my rear end has posi and what gear ratio it is. Considering this trucks history, I don't want to assume anything. I know I could do a burnout and count the stripes, but I am not to the point where I want to treat it like that(if I ever do get to that point). I also know that I can rotate the tire(s) and count driveshaft rotations, but that's guesswork. Since I am not sure when the diff fluid was last changed, I decided to go ahead change it. Of course this site was insightful on what fluids I would need. So I ended up buying a Felpro gasket and two quarts of the good stuff...
Time to dig in...
Board Member #87725
Old 06-17-2012, 10:44 PM   #243
omodified
omodified's Avatar
Update...
No posi-traction. Also, for documentation purposes, the gears are a 3.07 ratio. The fluid that came out seemed fairly new. I could see through it and it didn't smell too bad (at least I thought so). Gears all look good too. So, that's a plus.
Board Member #87725
Old 06-17-2012, 10:54 PM   #244
omodified
omodified's Avatar
I wanted this fluid exchange to be a quick turn around because I am leaving town for a bit. The plan was to clean up the diff cover and seal the new gasket to the cover for 24 hours. Then install and add fluids. Well, it didn't quite go that way...
So, the diff cover was really greasy and dirty as were the bolts. I also trashed the brake line clip during removal. I took all the parts to work intending to clean them in the parts washer. Well, the stupid parts washer was broken. So, I decided to go the brake cleaner route. Well, that got everything clean but it ruined the black finish. So, I had no choice but to go ahead a media blast it and throw the bolts in the trash. I got the cover home and sprayed it with five coats of that new roll bar paint. It looks a lot better! Now, the problem is that it has to dry and I have to leave town. I'll have to finish it up when I get back.
Board Member #87725
Old 06-17-2012, 10:59 PM   #245
omodified
omodified's Avatar
I have been gone for a few days now. My wife called today to tell me that it smells like something has died in the garage. I told her not to worry about it. I guess she doesn't like how my rear end smells...
Board Member #87725
Old 06-17-2012, 11:06 PM   #246
omodified
omodified's Avatar
I am back in town and I was greeted with a nice surprise...
The finish on the shock relocators is less than desirable. So, I'm gonna send them off to the powdercoater this week. So, Maybe I can install this stuff next weekend. I'm glad it's here anyways.
Board Member #87725
Old 06-17-2012, 11:15 PM   #247
omodified
omodified's Avatar
So I got the gasket sealed to the cover yesterday. Time to finish the rear end. My daughter decided to spend Father's Day helping me so we could take the truck out today. I picked up twelve stainless bolts yesterday to finish the job. Put a thin coat of gasket material on the diff and torqued everything to 20 ft lbs. I tried to use a few brake line clips that I had here but they were too small. So, I ordered a GM clip from EBAY. It was the closest thing I could find (1969/70 Camaro).
I'll have to install it when it gets here later this week.
Here is the finished product. I like it, but it sure makes the rest of the truck look bad. I guess that's what keeps us moving on to the next thing. I suppose the new track bar will help it look a little better back here.
Board Member #87725
Old 06-17-2012, 11:46 PM   #248
VA72C10
VA72C10
VA72C10's Avatar
Looking good! Nice progress!
Old 06-18-2012, 10:10 AM   #249
gcburdic
Restoration Virgin!
gcburdic's Avatar
Reading that you changed the rear gear fluid, brings back that wonderful smell!!! continuing to look good!!!
Geoff with a G
Old 06-18-2012, 08:09 PM   #250
Chvy2NV
Truck is looking real good. Great way to spend Fathers Day. Congrats!!!
Chvy2NV is offline   Reply With Quote
