Old 11-02-2015, 10:40 PM   #226
factorystock
factorystock's Avatar
Re: The 1960 - 1966 Chevrolet & GMC Pickups Factory Correct Restoration Thread
Originally Posted by sixpac View Post
The 250 (first year '66) was the alpine green
'66 was the first year for the 250, however your incorrect on the color. The '66 250 in pickups was the same color as the '63-'65 230, a blueish-teal, a color that is unfortunately not reproduced.
factorystock is offline   Reply With Quote
Old 11-03-2015, 01:03 AM   #227
62stepside longbox
62stepside longbox's Avatar
When I cleaned up the coil I found the original sticker under the bracket to be in good shape. I cleaned and painted around the sticker and lifted the coil out of the bracket an inch so that it was visible
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 11-03-2015, 02:10 AM   #228
66pnl
66pnl's Avatar
Echlin ic64 is a napa replacement.
66pnl is offline   Reply With Quote
Old 11-03-2015, 11:53 AM   #229
62stepside longbox
Too bad, I thought it was original just because of the 1/8 of an inch of grease on it
Old 11-07-2015, 02:44 PM   #230
armyman85
Hi. Im new to this and I purchased a 1961 Chevy pickup. I was wondering if anyone knows how to tell if the truck is either a C10 or an Apache? I looked on the actual title and I did a VIN search and it only states 1961 Chevy PU. Any help would be greatly appreciated.
armyman85 is offline   Reply With Quote
Old 11-07-2015, 02:54 PM   #231
armyman85
Hi. Does anyone happen to know if this truck is a C10 or an Apache? The title only says 1961 Chevy PU. Any help would be greatly appreciated.
Old 11-10-2015, 08:26 PM   #232
LT1 Burb
LT1 Burb's Avatar
Some interior pics of my truck I am restoring.
LT1 Burb is offline   Reply With Quote
Old 11-10-2015, 08:28 PM   #233
LT1 Burb
LT1 Burb's Avatar
One more of the wheel I just finished.
Old 11-11-2015, 03:01 AM   #234
oem4me
Super nice! Great job Kelvin.
Old 11-11-2015, 04:17 AM   #235
pimpston65
pimpston65's Avatar
best eye candy Ive have seen in awhile!!!
pimpston65 is offline   Reply With Quote
Old 11-11-2015, 08:15 AM   #236
corvettejim1968
corvettejim1968's Avatar
there is no denying that's a beautiful truck. sorry im just a purist with some things no offense. your truck is a 65 and the cluster is out of a 66. just curious why you chose to do it that way
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 11-11-2015, 11:35 AM   #237
LT1 Burb
LT1 Burb's Avatar
At the time I had numerous clusters and picked the nicest bezel, it was silver so I ended up going with it because I think it looks better.
Old 11-25-2015, 11:27 PM   #238
65chevysub
65chevysub's Avatar
I have a question concerning the deluxe wheel center. My holes on the back are stripped and when I turn the wheel, it "clicks". One screw is larger than the other so I would like to carefully re-tap the holes but not sure how to go about it or what size of tap to use. Can someone give me some advice please?
65chevysub is offline   Reply With Quote
Old 11-26-2015, 12:00 AM   #239
pimpston65
pimpston65's Avatar
how about using a helicoil
Old 12-04-2015, 10:34 AM   #240
LT1 Burb
LT1 Burb's Avatar
I had to send my repop heater core out and get the tank swapped. The lines coming out were at wrong angle and to short. On the positive side it now has a GM part# on the core.
Old 12-05-2015, 05:20 PM   #241
jbgroby
jbgroby's Avatar
Do you have a source for the tubing braces. I need a set.
jbgroby is offline   Reply With Quote
Old 12-06-2015, 10:51 AM   #242
LT1 Burb
LT1 Burb's Avatar
Had a little bit of a setback, didn't realize that someone back in the day decided to screw the voltage reg to the inner fender. I ended up welding up the holes and putting it back where it belongs.
Old 12-19-2015, 09:56 PM   #243
aotte1
What is the Shape of the Leaf Springs Ends
Shape of leaf spring ends, photos below are of 1964 K10 built in St Louis, rear springs. Were the leaf spring ends cut square or were they rounded/tapered some. They could have been both ways depending on supplier and/or where the truck was made.
The last photo shows other rear spring parts.
Note: The bottom helper spring does not look original, in photos 1 and 2 below. Will post photos of front springs next, they are not as rounded, however, not cut square either.
Les
aotte1 is offline   Reply With Quote
Old 12-20-2015, 05:03 PM   #244
aotte1
Front Spring End Shape '64 K10
Below are photos of front spring end shape, they are cut straight at ends and have a straight taper on the sides length wise at the spring end. This makes the end of the spring narrower.
Old 12-24-2015, 01:01 PM   #245
Blake985
Anyone know if these snaps came on these trucks?? Or why someone would go crazy adding them?
Blake985 is offline   Reply With Quote
Old 12-24-2015, 01:19 PM   #246
Greg63
Enjoy your truck
Greg63's Avatar
Whoa!
They are not factory.
Greg.
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 12-24-2015, 05:16 PM   #247
63burban
Chevy addict
Did this truck have a camper on it??
63burban is offline   Reply With Quote
Old 12-24-2015, 08:02 PM   #248
Blake985
Not when I got it but who knows??
Old 12-24-2015, 10:48 PM   #249
kippnidaho
kippnidaho's Avatar
Ok can any body tell me if this is a stock paint scheme. 1966 Base model fawn interior brown dash and grey glove box ashtray and radio delete.
Going through the truck and wondering how to paint the interior.
KippnIdaho
Twin Lakes, Idaho
1966 K10 SWB Stepside
2003 Jeep Rubicon
2011 Camaro SS Rag Top
kippnidaho is offline   Reply With Quote
Old 12-24-2015, 11:02 PM   #250
66pnl
66pnl's Avatar
Don't know about the gray but dark fawn dash is correct for 66.
